Old 11-29-2012, 01:25 PM   #1
Herbivore63 OP
Oddometer: 37
Heavy Lines on OSM in Basecamp
I'm new to using Basecamp and a GPS with tracks. I've just managed to import an Open Street Map into Basecamp and it seems to be working fine except that there are heavy diagonal and vertical lines showing up making it almost unreadable. I've been through all the Basecamp settings, googled everything I can think of and still can't figure out the problem. I'm hoping someone can help. I'm also hoping that the screenshot link below works as I've never posted an image on here before! Thanks for any help...
http://herbivore.smugmug.com/Other/U...%20lines-M.jpg
Herbivore63 is offline   Reply With Quote
Old 11-30-2012, 12:29 PM   #2
BKMLWR
Wondering around...
Oddometer: 4,673
I have Maine/Quebec/New Brunswick/ Nova Scotia area in OSM and there are horizontal lines are in NB and Gaspe area of Quebec and parts of NS but not in Maine
Sometimes I get off the bike before it has come to a complete stop....
Another Proud Small Scale Faker......
Praise You In This Storm
LifeSong
BKMLWR is offline   Reply With Quote
Old 11-30-2012, 12:37 PM   #3
Warin
Retired
Oddometer: 2,224
Question Configuration file
Think those lines are to mark out different land use (National Parks, Cities, Forests, Farm land etc)
I don't know basecamp ... but in Mapsource (older Garmin software) there is a configuration file you can change that may change how things (like roads) are shown, it could change how land use is shown too?
Warin is offline   Reply With Quote
Old 11-30-2012, 01:59 PM   #4
Herbivore63 OP
Oddometer: 37
Thanks for the replies--I think you are correct. The screenshot is of southern Vancouver Island. If I scroll far enough up the island, the lines go away. I also included some of Washington State and the only lines there are for Olympic National Forest. It's interesting that the lines don't show up on the online version of OSM. Now, any ideas how to get rid of the lines? I've played around with the activity profiles and map display and haven't been able to eliminate them.
Old 12-03-2012, 07:09 AM   #5
BKMLWR
Wondering around...
Oddometer: 4,673
if so they have no idea of what Maine, New Brunswick and Nova Scotia are like
LifeSong
Old 12-03-2012, 09:42 AM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,769
Re your image - don't post it as a link; choose the images icon instead and you'll get something like this:
Old 12-03-2012, 01:50 PM   #7
Herbivore63 OP
Oddometer: 37
Emmbeedee...thanks for the heads up. That's much better. I didn't spot that icon the first time through. Now that everyone can see it, any ideas about how to get rid of them?
Old 12-03-2012, 04:41 PM   #8
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,769
My OSM map doesn't look at all like that when I check that area:
Maybe you should try downloading this one: http://www.osmmaps.com/canada.html
Old 12-03-2012, 05:40 PM   #9
BKMLWR
Wondering around...
Oddometer: 4,673
good link, my maps came from a .nl web address
LifeSong
Old 12-03-2012, 06:07 PM   #10
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,769
I think these come from the NL site but they're pre-assembled for your convenience. One file = all of Canada.
The only problem is that the file I linked to is what you put on the gps. It's not a file you install in Basecamp. (Remembered about that after I suggested it)
But with the right gps, connected to the computer via USB, the maps on the gps will be accessible through Basecamp anyway.
Question to the OP: what gps are you using?
Old 12-03-2012, 07:14 PM   #11
Herbivore63 OP
Oddometer: 37
I have just purchased a Montana but haven't even hooked it up yet. I was just trying to get Basecamp working with a map in it before tackling getting a map on the Montana.
Old 12-03-2012, 07:25 PM   #12
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,769
Great choice. I also have a Montana, a 650. If you download the map from the link I suggested you can rename it to OSM Canada.img and place it in the Montana's \Garmin directory or in the same directory on the uSD card if you have one. No need to keep its current name.
Old 12-03-2012, 09:29 PM   #13
Herbivore63 OP
Oddometer: 37
That sounds reasonably straight-forward--which seems rare when dealing with GPS-related things. I'll give that a try. Thanks for the help!
Old 12-04-2012, 05:42 AM   #14
BKMLWR
Wondering around...
Oddometer: 4,673
this is the link where I got the map tiles for NE US and Maritimes CA. with the lines.....
http://garmin.openstreetmap.nl/
when the world map displays I just zoom in and pick map tiles as needed....
LifeSong
Times are GMT -7.   It's 02:15 AM.
