Old 11-30-2012, 09:13 AM   #1
STANIMAL OP
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,944
Need help with an old Zuma carb
I have an old Zuma that was sitting for five years. I went through the carb , replaced the pilot , needle and float . Also replaced the vacuum operated petcock . It starts and idles for a few moments , then dies , as if the bowl is running out of fuel .
Does the air filter assembly need to be mounted ? I know some engines need it in place to run right . I have been in side the carb several times . All the orifices seem to be clean and flowing air . Any thoughts ?
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 11-30-2012, 02:29 PM   #2
kiznile
Scooter Commuter
kiznile's Avatar
Oddometer: 59
I dont know the zuma specifically, but a lot of these vacuum operated fuel pumps need vacuum...check to see how your fuel pump operates..Just a shot in the dark
Kyle Sutherland
'07 BMW F800ST (28,800 miles so far)
-OEM Top Case and Fender delete, Just Right
kiznile is offline   Reply With Quote
Old 11-30-2012, 02:38 PM   #3
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,097
If it's been sitting for 5 years, then it's likely the passageways in the carby are partially blocked by oxidation and/or varnish and crud, even if they look clean to the eye on first inspection.
A full strip down and soak in cleaner will do it wonders.
Same for the vacuum tap, maybe even more so. Fuel evaporates and leaves really stubborn varnishes.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 11-30-2012, 05:25 PM   #4
STANIMAL OP
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,944
The vacuum petcock is new and the carb has been cleaned , soaked and cleaned about a half dozen times . Like I said , every hole is flowing air . There must be something I am over looking .
Old 12-01-2012, 04:18 PM   #5
tbonestone
tbonestone's Avatar
Oddometer: 172
Just for kicks, did you put the air box on yet? Try it and see if that helps. I always put the bike together fully then test run and tune.
tbonestone is offline   Reply With Quote
Old 12-01-2012, 06:11 PM   #6
allstateclub
Oddometer: 54
Try a vibrator?
A few years ago I bought a hydrostatic cleaning gizmo from Harbor Freight. Cost was about $45-$50. I totally strip the carbs down, clean everything with carb cleaner, blow them dry with a pressure hose, then throw them into the hydrostatic cleaner that's filled with water. I was amazed at the stuff that came vibrating out of all those little holes. I've even vibrated the parts with solvent in the machine (NOT recommended by the maker). They seem to work a lot better without taking them off and trying to clean them again, then repeat again and again.
allstateclub is offline   Reply With Quote
Old 12-01-2012, 07:37 PM   #7
STANIMAL OP
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,944
That's what I am thinking. I had a few bikes over the years that had to be tuned like that.
Old 12-01-2012, 07:37 PM   #8
STANIMAL OP
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,944
Sonic cleaner , I should get one anyway.
Old 12-02-2012, 01:36 AM   #9
hayasakiman
Oddometer: 159
Did you remove the blocking plug and idle mixture control before cleaning?
I'm not so sure but I think Zuma has that as well.
hayasakiman is offline   Reply With Quote
Times are GMT -7.   It's 06:12 AM.
