Closed Thread
Old 11-30-2012, 09:03 PM   #1
beergut OP
Thumper
beergut's Avatar
Oddometer: 413
Why does the KLR engine suck in HP
KTM 640adv:
625cc, 54hp
KLR 650
649cc, 20hp
Honda XR650
644cc, 30-35hp
Suzuki DR650
644cc, 43hp
All of these are estimated and from QUICK google searches and are unmodified engine ratings. One thread said the XR can hit the 45-50hp target pretty easily, the DR isnt far off and the KTM makes everyone laugh.
WHy does the KLR suck so bad? What can make serious improvements?
beergut is offline
Old 11-30-2012, 09:30 PM   #2
Echo1
Oddometer: 278
I think the info you have is wrong. Here are some MCN dyno tested rear wheel HP specs from the 2012 edition of the MCN performance index:
'10 KTM 690 Enduro R, 46HP
'08 KLR650, 36HP
'07 Honda XR650L, 33HP
'07 Suzuki DR650, 35.6HP
http://www.mcnews.com/mcn/technical/2012JanPerfIndx.pdf
Echo1 is offline
Old 11-30-2012, 09:32 PM   #3
beergut OP
Thumper
beergut's Avatar
Oddometer: 413
it still sucks.
I own one and am trying to make it suck less
beergut is offline
Old 11-30-2012, 09:34 PM   #4
jtw000
Survivor
Oddometer: 567
Originally Posted by beergut View Post
it still sucks.
Sell it and buy a bike...
jtw000 is offline
Old 11-30-2012, 09:37 PM   #5
beergut OP
Thumper
beergut's Avatar
Oddometer: 413
yeah that option is looking very slim at the moment. I had intentions but they are slipping away and if I am going to make it half way not suck, now is the time.
beergut is offline
Old 11-30-2012, 09:37 PM   #6
ParaMud
ParaMud's Avatar
Oddometer: 628
You guys bought a klr to go fast??
lol
08 wr250r
04 xt225
ParaMud is offline
Old 11-30-2012, 09:40 PM   #7
beergut OP
Thumper
beergut's Avatar
Oddometer: 413
no
beergut is offline
Old 11-30-2012, 09:46 PM   #8
SloMo228
World Class Cheapass
Oddometer: 1,798
Not specifically about the KLR, but I have wondered along these lines - what is the reason for dirt-oriented bikes having these relatively low power outputs? I mean, just about any 650cc road bike has at least 20hp more than these numbers. I'm honestly not trying to start an argument here, just honestly wondering about what I perceive as an odd discrepancy. For instance, an 80s CB650 has at least 60HP at the crank, why would a Honda 650 dirt bike almost 30 years newer have just barely more than half that HP?
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline
Old 11-30-2012, 10:27 PM   #9
oldxr
oldxr's Avatar
Oddometer: 1,140
My Honda xr650r on the dyno.Top trace is the oem carb rejetted.Bottem is an edelbrock carb with a 21e needle.Most of the weak/poor driveability is from carbs jetted for emissions so the bike can be imported.The oem carb has poor throttle response at low rpms.I have since found a 20e needle for the eldo and pulled 43 mpg on combined highway/dirt road touring with a giant loop pack on back.I forget but I found a company that can build a 50hp klr motor some where on the net.Its is a modern dohc 4 valve engine.Problem is most klr riders dont want to drop $2k in the engine.Usually you deduct %20 for the difference between rwhp and crankshaft hp
oldxr is offline
Old 11-30-2012, 11:19 PM   #10
Tosh Togo
Oddometer: 1,594
Because the singles (1) don't have the ability to rev in order to make the horsepower that a similar-sized four-cylinder is capable of producing. It will, however, produce more torque than the multi, and have a broader spread of torque. (2) Singles don't have the valve area that an inline does. Same effect.
Fyi, I've ridden a few early 80's CB650... they're nice little streetbikes, if you don't mind a medium-bore that needs revs like a 250 Ninja does. It's the opposite of a KLR's powerband, and there's a very good reason for that.
Engines produce torque, not hp. The torque curve is what a dyno measures, and the shape of it is what your butt feels when you whack the throttle.
Mid-range rules, even if you don't have enough of it.
Tosh Togo is offline
Old 12-01-2012, 12:29 AM   #11
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,299
The KTM 690 makes 61hp stock.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now
Old 12-01-2012, 02:52 AM   #12
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,557
It's slightly faster in the 1/4 mile than a new Dodge Durango.... and a 2009+ KLR is 37 hp, not 20......
Your "fast google search" was not on task I am afraid.
The KLR will easily haul three times it's own weight. It's a donkey, not a racehorse.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline
Old 12-01-2012, 04:17 AM   #13
Grinnin
Forever N00b
Oddometer: 2,841
I think you've exceeded its GVWR.
The engine is VERY similar to the KLR600. When people say the bike has been around since '87, it is only warmed over from '84. It was a modest engine then.
As for improvements: I REALLY like the 705 piston. I didn't put it in expecting it to be like an inline 4 or even my revvy twin, but it does make the bike more willing. And fun. I'll admit it, I have fun on an underpowered old design.
I am not even considering hot cams, but there's more help there. Total cost of piston, sleeve, boring, and cams would be more than buying a different bike.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline
Old 12-01-2012, 05:38 AM   #14
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,467
I think you may be a candidate for a FCR PUMPER carb.
That will give you that initial hit from the accelerator pump when you twist the throttle that you are probably longing for.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline
Old 12-01-2012, 06:08 AM   #15
Wallachian Spikes
Wallachian Spikes's Avatar
Oddometer: 907
The KLR is still early '80s technology & it was designed with a "utilitarian" purpose, not as a race bike. When I got my first KLR an '00 in Marine Corps green I was shocked by it's lack of power & very dissapointed...... At first. The bike slowly grew on me & out of twenty different bikes the KLR is the only one I bought a second time.
As a KLR owner I'm painfully aware of it's short commings & lack of H.P. is way up there on my list. When I heard Kawasaki was finally going to upgrade the KLR in '08, I was thrilled to death. However the end result was a heavier bike that looked (IMO) bulbus & silly. It still had the Doohicky & Thermobob problems, it is still only a five speed & cranks out basically the same underwhelming power. I wish they had left it alone, as I prefer the old look & it was already too heavy from the start.
The appeal of the KLR is that it is the ultimate "Bargan bike" & I never fail to enjoy a ride on it. Sure other bikes are more fun at single purpose uses or at a much (KTM 690) higher price. Perhaps the Husqvarna 650 Terra will change that & hopefully Kick Kawasaki in the butt & be the inspiration to build the KLR I'd hopped for in '08.
As it stands now, you either "get" the KLR or you don't but, it's the guys that "don't" get it that keep so many low milage KLRs on the used market at bargan prices that make guys like me love them so much. Still after 25 years, a modernized KLR with improvements on the flaws that actually matter to me would be nice.
Wallachian Spikes is offline
Closed Thread
Times are GMT -7.   It's 02:42 AM.
