Old 11-25-2012, 07:24 PM   #2026
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Originally Posted by Yokomo View Post
Question: I have the Hero HD and it takes amazingly clear video with excellent sound. When I put vids together using MovieMaker I can make parts slow-mo if I wish. I have no complaints with it.
Is there any reason to get a 2 or 3?
There are deals on the 2 out there, now that it's not the latest and greatest, but if you're happy with yours, why change?
Actually, the iPhone/Remote app is one reason. It's awesome for lining things up and making quick configuration changes, or updating the camera date and time, etc.
Old 11-25-2012, 07:51 PM   #2027
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,313
Luckily I don't have an iphone, so it's one less thing to worry about.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 11-26-2012, 08:06 AM   #2028
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
I was noticing a lot of clicking noises in my video recordings so I started looking into it and found that the mount itself is likely the problem. I recorded a quick video showing the looseness in the mount.
This is the part I was using. It's got a slight rise which I like, but that play is a killer.
Old 11-26-2012, 08:51 AM   #2029
sallad
sallad's Avatar
Oddometer: 742
Try putting two pieces of electrical tape on the sticky mount. Kind of hard to describe so just take a look at the picture. Solved all of my clicky audio issues:
sallad is offline   Reply With Quote
Old 11-26-2012, 09:12 AM   #2030
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Thanks for the suggestion - that would fix it, but the other mount of its type has no play in it at all so if I tried to use the taped base, I would not be able to use the other mount.
I'll try the tape fix on the mount, instead of the base.
But it's too bad the part was not made right in the first place.
Old 11-28-2012, 08:10 AM   #2031
Jon_PDX
Oddometer: 1,119
Bummer about the H3 issues. I was thinking about upgrading from my original HD version to the H3 but I guess I'll let the bugs get sorted out first.
Good thing it's cold and wet here right now and I'm not doing any riding worth capturing on video.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 11-29-2012, 03:19 PM   #2032
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,197
Jon...
I recently finished a couple days of testing the H3B, after using GPs recommended procedures (not listed in the manual) I was able to narrow it down to bad batterys, turns out 3 out of the 4 batterys shipped with the cam were bad. This goes along with many of the problem symptoms I've read about with the H3B (shutting down, corrupted files etc...) It's not a charge level issue, the batteys are misreporting the level of charge to the cam.
GPs customer service is replacing them as we speak.
Two key issues not mentioned in the documentation:
1) Always format the micro SD card with the camera prior to filming.
2) Use a wall plug USB charger, 1a rating is preferred. Do not rely on charging via a computer's usb port, it does not supply enough current for the GoPro.
Definately buy extra batterys if you go with the new GP, the average runtime is a little over an hour per battery @ 1080P/60FPS, Wifi will reduce that a little.
If they come out with a skeleton case for the H3s I'll probably run a 64G card and a remote battery pack (4 hrs of video) The H2's 2 hr recording time has spoiled me.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak screwed with this post 11-29-2012 at 03:26 PM
RideFreak is online now   Reply With Quote
Old 11-30-2012, 08:43 AM   #2033
Jon_PDX
Oddometer: 1,119
Thanks for the info Chris. Sounds like by the time I'm ready to upgrade (next riding season) it will all be sorted out.
Jon...
Old 12-01-2012, 02:20 PM   #2034
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
At the risk of inviting Apple insults, I would like to mention that the iPod wall wart power supply I have here lists 1A output. But the Wasabi Power charger I bought with my two spare GP2 batteries puts out 500ma.
Just for the record.
Old 12-01-2012, 05:45 PM   #2035
Guerillah
Guerillah's Avatar
Oddometer: 101
Got the hero 3 black edition the other day, made a chin mount for my AFX FX39 helmet. It gives a great first person point of view, you see some of the handlesbars/tank and the rest is the road all the while maintaining a good horizon. Excited to hit a trail with it to get some good footage. Pics...
GoPro Hero 3 Mount by Guerillah, on Flickr
Cheers
Guerillah is offline   Reply With Quote
Old 12-04-2012, 11:33 PM   #2036
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,197
Good to know, thanks.
Chris
Old 12-05-2012, 11:37 AM   #2037
COXR650L
Oddometer: 1,540
So all the problems are they only with the Black?? I was going to get a white edition, is anyone having issues with it?
COXR650L is online now   Reply With Quote
Old 12-06-2012, 03:41 PM   #2038
tshelver
Oddometer: 568
I'd wait a while, I had some serious bugs with my 3 Black. They seem mostly to be fixed with the latest (first) firmware upgrade, but I have yet to find the time to test out the wifi issues I was having. Who knows what else is lurking in there once I get over my initial disappointment (total disenchantment would be more like it) and really start using it.
I doubt I'll see the Android app any time soon given GoPro's consistently late delivery of software, manuals and upgrades. It took them several days after I got my Hero 3 Black to get the correct manual released (initially the Hero 2 was linked), and it took them two days to get the support site set up to handle calls about the new series.
The bugs that I and several others experienced with charging and the Battery BacPac HAD to have been seen in any form of real world testing, yet they released the camera anyway and took well over 3 weeks to resolve the issues.
But it's not all bad, they seem to be (slowly) getting on top of the issues.
Advantages of the 3 in general include include the smaller form factor, and if you do underwater video, the new housing negates the need for the older specialized housing, which was an optional extra.
For the Black edition specifically, supposedly low light performance is much better, but still no great shakes. I'm not using the high resolution video features, my first experiences gave me very choppy video on my laptop (which is a few years old highly specced T400 Thinkpad), and I'm not about to invest in a new one.
Several others have noted the same issue, now that I have the firmware update in place and a little time, I'll do some more experimenting.
'11 Yamaha YBR125G (cheap and very cheerful
'12 Zongshen Fly / Motorstar MSX200-II (biggest-fun-to-dollar ratio of any bike I've owned)
'03 Honda VFR800 (sold)
'06 Husky TE610 (gone)
tshelver screwed with this post 12-06-2012 at 03:47 PM
tshelver is offline   Reply With Quote
Old 12-06-2012, 03:48 PM   #2039
tshelver
Oddometer: 568
GoPro seems very slow to provide updates (3 weeks to get the charging and battery BacPac integration issues resolved, days to get the correct on the website and to allow for Hero 3 specific support calls to be placed), so I'm not holding my breath for the Android app that was promised for December, and which is a big feature for me.
And when it arrives, likely it won't run on my older Android chinaphone anyway.
But it's not all bad.
Old 12-07-2012, 05:14 AM   #2040
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,378
I'd like to thank all you early adopters of the GP 3 Black for your beta testing of the latest camera. Your pioneering spirit is what makes American what it is. Rest assured that your contribution will be rewarded by the community. God bless you and God bless America.
The President of GP Inc.
Seriously, I was going to get one of these new GP's to replace my aging VIO video, which works just fine, but that would just be crazy.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Times are GMT -7.   It's 06:12 PM.
