Old 11-24-2012, 06:12 PM   #1366
japako
japako's Avatar
Oddometer: 592
Wow, you do have a nice "large" tool kit...
Seriously, you could cut off some weight by removing the redundant items.
I know you said it was for two bikes..
japako is offline   Reply With Quote
Old 11-24-2012, 09:05 PM   #1367
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Holy hell, a fawking hammer!?! haha. What kind of bikes are are you maintaining and how are you working on them? 15lbs is a pretty big toolkit...
jesusgatos is offline   Reply With Quote
Old 11-24-2012, 10:22 PM   #1368
rpet
Awesometown
rpet's Avatar
Oddometer: 820
that's a joke right? a knipex, plus 2 crescents, 2 vice and 2 ratchets?
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 11-25-2012, 05:17 AM   #1369
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,179
http://advrider.com/forums/showpost....57&postcount=2
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 11-27-2012, 08:43 PM   #1370
Bengt Phorks
Oddometer: 252
Originally Posted by LoneStar View Post
Picked up one of the Husky 1/4" x 5/16" mini ratchets couple days ago - pretty slick. Bought the Lowes version as well for comparison. Lowes was a little kit with several bits for $9 vs $17 for Husky at HD. Husky mechanism switch worked more easily and the actual bit socket is 6-sided vs the Lowes which felt crusty and has a spline bit socket.
Anyone sourced any 5/16 shank bits other than short Torx bits? Seems the Torx are all I can find online but I'd love to find some 3" - 6" long Hex and Torx bits with the 5/16 shank size...
I have a source for 1/4 inch torx and allen. 6 inch long bits:
http://www.mcmaster.com/#standard-al...r-bits/=kcrscp
http://www.mcmaster.com/#standard-to...r-bits/=kcrqhl
Bengt Phorks is offline   Reply With Quote
Old 11-27-2012, 09:58 PM   #1371
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,974
I'll play, fly & ride from Virginia to new Mexico.
The surgical hammer was used a lot especially tent stakes.
AteamNM is offline   Reply With Quote
Old 11-28-2012, 06:44 AM   #1372
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,221
Originally Posted by Bengt Phorks View Post
Cool! Thanks Bengt
LoneStar is offline   Reply With Quote
Old 11-28-2012, 09:36 AM   #1373
9mm
Oddometer: 102
air pump
Air pump? What? DIY?
um what ?
9mm is offline   Reply With Quote
Old 11-30-2012, 01:56 PM   #1374
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
I bought a set, never used em, I use the 1\4" ones since they are easier to find, no need for the heavier duty 5\16th shank bits.
Anyway, the set I have is Plews Tools 6 piece metric hex bit set 72-961
Has 4, 5, 6, 8, 10mm hex bits and a 3\8th to 5/16th adapter if you wanted to use them on a regular 3\8th drive ratchet.
They are made in the US and are very beefy, the package must weight more than the sockets I keep in my altoids tin complete with 1\4" bits, 3" extension and 8 and 10 mm deep sockets.
Can't seem to find them online, can't recall where I got this set, it was either ace hardware or ebay.
HaChayalBoded is offline   Reply With Quote
Old 11-30-2012, 03:55 PM   #1375
CollinsB
CollinsB's Avatar
Oddometer: 990
I'm working on slimming down my tool kits. Many will do double duty. Several slick combo packaged tools are out there..
Sears, Lowes and even Walmart carries some cool combo packages.
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 12-01-2012, 08:43 AM   #1376
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,221
Thanks Hacha - I was thinking the 5/16 might be a bit stronger than the 1/4 for the larger hex... not that the little ratchet would handle it better tho.
I'm currently going through my GS tool kit for a trip to S America next year and have the bad habit of buying a bunch of stuff to try out before weeding it out. Assembling a tool kit is like an eternal Rubik's Cube. 5/16 seemed like it might be a bit stronger for the larger hex and torx bits...
Old 12-01-2012, 09:11 AM   #1377
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
It's probably stronger but that doesn't mean the 1\4" isn't strong enough. I have yet to break one or bust the little husky ratchet. Probably had it for 5 years already and use it for 99.9% of ratcheting functions on the bike. Only time I use something else is to pull a wheel. And sometimes to break free some stubborn oil drain bolts.
I do carry, but only use for the two above instances, a 3\8th ratchet. It's a really slick telescoping ratchet. It doubles as a billy club.
Old 12-01-2012, 10:18 AM   #1378
jesusgatos
jesusgatos's Avatar
Oddometer: 2,394
Same here. That little Husky ratchet is surprisingly robust.
Old 12-01-2012, 04:43 PM   #1379
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,221
Thx Hacha and Jesus - glad to hear the little ratchet is so tough. Never used such a small one so have no reference as to durability and haven't used the quick bits other than for screwdrivers. Plan on using the heck out the little guy over the next few mos on the GS
Old 12-01-2012, 05:26 PM   #1380
Rotten Ronnie
Crash
Rotten Ronnie's Avatar
Oddometer: 354
I've used it to drop the forks on my KLR, but you'll need your gloves on.
I'd add a 1/4" drive extension bar, 3 to 6" along with a bit holder so you have more reach as a screwdriver.
Gear Wrench makes a set that they sell at the Canadian version of Lowes, but you'll need to replace all the sae hex with metric.
Bikes I haven't managed to destroy yet:
2009 Kawasaki Versys 650
Ride Reports and other drivel:
http://rottenxxxronnie.blogspot.com/
Rotten Ronnie is offline   Reply With Quote
Times are GMT -7.   It's 09:03 PM.
