Old 12-01-2012, 09:32 PM   #3721
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Originally Posted by Yellow Pig View Post
OK
Took the head off the bike and can't tell what is causing the oil consumption.
Have a look at these pics and tell me if you see anything wrong.
Cylinder looks great:
Compression ring looks good:
Oil ring looks good:
Do these valve stem seals look properly seated? Not sure about this one?
Intake side valves:
Exhaust side valves:
It's definitely burning oil, lots of buildup on the piston and the face of the valves.
The back side of the intake valves looks pretty gunked up leading me to thing the intake side valve stem seals are leaking?
Well, I finally got all the parts in and got it all buttoned up yesterday and did a quick 10 mile Motoman break-in and then an oil change.
Ended up going w/ a new Wossner Piston (94.97mm since my XC-W had a Type II piston) and rings. I put all new valve shaft oil seals in, cleaned up the head and the valves and did a valve adjustment.
I gave the cylinder a quick hone w/ a flex hone and for the first time used Total Seal Quickseat Dry Film Powder for the cylinder/rings installation. We'll see if it helps.
I used a Flex-Hone in 240 grit Aluminum Oxide, not a silicone carbide hone and did a lite pass to deglaze the cylinder.
Bike seems to pull really strong.
Today I did a 70 mile trail loop today and the bike is running strong w/ no oil consuption. I'll have to put on a few more miles before I can be realy certain everything is OK
Yellow Pig screwed with this post 12-01-2012 at 09:42 PM
Old 12-02-2012, 07:30 AM   #3722
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
Interested to hear how this works for you, Dan. My 530 has been strange... one ride it may go through an alarming amount of oil; like half the site glass in 40 miles. Then I can ride it 4 or 5 other days, hundreds of miles, and it uses nothing. Totally random; can't figure it out. I carry a little oil with me, just in case.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 12-02-2012, 09:29 AM   #3723
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,597
Any tip overs when you use oil?
Could be pouring oil down the crank case breather tube and burning it when dropped.
Other wise it might be the valve stem seals that are not seated properly.
Old 12-02-2012, 11:40 AM   #3724
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
No tip overs. Well, not every time. I haven't taken the time to check the seals; been riding too much. I will, though. They may be seating, and unseating randomly.
Old 12-02-2012, 01:27 PM   #3725
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,597
I you keep riding while burning oil you risk getting lots of buildup on the valves which could keep them from closing properly.
Old 12-02-2012, 01:49 PM   #3726
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
It needs to snow, then.
Old 12-02-2012, 02:43 PM   #3727
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,983
How about ice?? We went out yesterday for a few hours, and today, just the two of us rode in the freezing rain. The 350 EXC is very quick on ice, and is a little easier to ride, but the romp of a 530 can't be beat. The 530 with the BD headlight has a rather fecked rear tire, and is squirly, but is fun to hang out at 110 km/h. Good times, I'm whipped.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 12-02-2012, 03:14 PM   #3728
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
I've been riding a lot too.
Old 12-02-2012, 03:17 PM   #3729
wvridgerider
wvridgerider's Avatar
Oddometer: 576
That is awesome. I wish there was a lake around here to do that on. I wonder if Deep Creek in Maryland would be ok to do that on when it freezes.
wvridgerider is offline   Reply With Quote
Old 12-02-2012, 03:45 PM   #3730
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 421
If we get enough cold weather, sure. I've ridden sleds on Deep Creek years ago.
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 12-02-2012, 09:29 PM   #3731
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
Nice shots,very scenic riding you've got out there.
I got in 80 miles of singletrack last weekend in nor cal,the snow has melted off and riding is great! We had 18 guys show up for sunday's ride,split up into 3 groups. One gentleman of a certain age (70) went for a swim in one of the deeper water crossings,only his helmet and handlebars were sticking out of the water for a moment.
Not the thing to do in November really.
I was on my 300 and had an absolute blast racing nose to tail through the woods sat and sunday with a friend on a 530. Got away with only one minor tip over.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 12-02-2012, 10:45 PM   #3732
ian408
Oh?
ian408's Avatar
Oddometer: 14,576
I like this. A lot.
You so suck
ian408 is offline   Reply With Quote
Old 12-02-2012, 10:47 PM   #3733
ian408
Oh?
ian408's Avatar
Oddometer: 14,576
All I gotta say is you Canadians are crazy.
Old 12-04-2012, 10:17 AM   #3734
mineolaman
Adventurer Wannabe
mineolaman's Avatar
Oddometer: 61
nice
beautiful country and trails to ride!
mineolaman is offline   Reply With Quote
Old 12-04-2012, 12:04 PM   #3735
mineolaman
Adventurer Wannabe
mineolaman's Avatar
Oddometer: 61
Originally Posted by GreatWhiteHunter View Post
Just wanted to drop a note and say thanks to everyone that posted in this thread. I've absorbed it all (or like to think I have) and now I get the chance to put it all together. I picked up a 2010 530 XC-W with a street title and will be using the downtime this winter to make a few mods to the bike. The pointers in this thread will go to very good use.
Here's a pic, hope you don't mind that it's not an EXC.
Very nice bike!
Times are GMT -7.   It's 10:11 PM.
