Old 11-30-2012, 08:41 AM   #2881
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,901
[QUOTE=avconnect;20148327]
Originally Posted by shinysideup View Post
I like the Acerbis model because tire changes are very easy with it. It is affordable and easy to install. I have never seen anyone break or damage a front disk rotor so, in my opinion, the more robust carbon fiber units are a waste of money not to mention the extra hassle of removing them in order to pull the wheel.
The trick with disc gaurds is...If you smack a plastic gaurd hard enough to bend the metal disc underneath,how is the plastic stronger then the metal?
They both bend,the plastic bends easily. Its physics.
Disc gaurds are great for keeping brush out of the hub/disc area and they keep the disc from getting the air it should so brakes can run hotter if used hard.
Ive never bent a disc yet in many years of trailriding but I know it happens.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 11-30-2012, 10:34 AM   #2882
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,755
[QUOTE=Foot dragger;20149014]
I've bent the front disk on every dirt bike I have ever owned except my current one(5 bikes now). Must be the rocks around this place.
I do not run a guard on the front as it is a hassle. I do run a rear fin guard as rear disks are very easy to bend without falling.
toddler is offline   Reply With Quote
Old 12-01-2012, 09:38 AM   #2883
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,180
I've had branches get into the front caliper and push the brake pucks back. Then you have nothing. I run the Accerbis/KTM guard. Cheap, easy install.
"Son, you can't do both"
Old 12-01-2012, 04:17 PM   #2884
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
well long story short, my rear break line got snapped at the bend right before it bolts into the caliper. since I have to replace it anyway...can anyone recommend a good upgrade? i'm thinking somebody makes a braided line for these.
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 12-02-2012, 12:19 AM   #2885
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,067
I've had good dealings with Galfer for brake lines on 3 bikes now (soon to be 4... need a new front on the 690 too). They make them to order so there is no charge for extra length, different colors, etc. http://www.galferusa.com/brake-lines-for-off-road-mx/
The Letter J is online now   Reply With Quote
Old 12-02-2012, 02:50 AM   #2886
bill1960
Oddometer: 369
Seat mod 500xcw
I ordered the seat concepts standard height/density foam and cover for my '13 500xcw.
Its a nice product but only 7 1/2" wide at the widest point, the same width as the oem seat pan.
I liked it for short rides when standing most of the time but for joining trails with hwy stints of 50km + it wasn't comfortable enough for me
Since I'm in Cambodia it wasn't viable to send it back so luckily the labor to modify it is cheap here.
Browsing around I came across http://www.fishersaddlebags.com and decided I liked the design of their 9" wide seat using the OEM base and adding to the OEM foam
So the next step was to wander down to the local motorbike upholsterers and see what they could do.
Cant buy good quality foam here so we cut up the oem foam to add to the seat concepts foam
Coming together
They made a new (larger) cover from scratch and copied the lines of the seat concepts cover
Stretched nice and tight and well secured
Finished product
Spot on 9"
Cost was $15 for 3 hours labor and materials, plus a tip
Very comfortable.
bill1960 is offline   Reply With Quote
Old 12-02-2012, 04:40 PM   #2887
hoss314
hoss314's Avatar
Oddometer: 135
Wonder what happened during your install?....just measured mine and it is at 8 1/2".
Hands down the best seat right out of the box. I have them on three of my bikes...a must have upgrade same as a stabalizer in my opinion.
Sent from my ADR6350 using Tapatalk 2
08' KTM 690 Enduro (Black Rally)
06' CRF450X Plated
hoss314 is offline   Reply With Quote
Old 12-02-2012, 05:36 PM   #2888
bill1960
Oddometer: 369
Are you referring to the seatconcepts foam for the KTM 500 ?
If so, I have to disagree. My last post shows it measuring 7 1/2" at its widest point.
Old 12-02-2012, 05:48 PM   #2889
Geek
oot & aboot
Geek's Avatar
Oddometer: 32,053
I ordered a pre-built seat concepts last week.. I'll measure it and show a pic when it arrives for reference (the ready-to-go version they build).
Old 12-02-2012, 06:12 PM   #2890
Wentjo
Wentjo's Avatar
Oddometer: 421
I put my prebuilt seat on a month ago and love it, best thing I put on my bike by far.
Wentjo is offline   Reply With Quote
Old 12-02-2012, 06:16 PM   #2891
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,230
Powerlett and HDB
I may have posted this before....can't recall..... but, some folks asked for some more info on this setup, so I took some more pics to post up.....
I went with Powerlet due to their reliability and quality products for motorcycles.
Here is a listing of what I've put on my KTM 500 EXC
Low-Profile Powerlet Socket
PowerLet Fuse Block Assembly
Rigid Powerlet to Cigarette Socket Adapter
Micro USB Short Powerlet Charging Cable
Here is an image of the Fuse Block installed next to the Battery and next to the stock Fuse Block. This Fuse Block interfaces between the battery and the following:
Hard-wired GPS
Trickle Charger - That can double as a heater for a vest
PowerLet Plug - mounted on the HDB bar
AdvMonstor LED lights - To be setup
Here are some more pics of the full setup
Note: Upgraded version of the HDB top Clamp
As far as power drain, it's really a non-issue.
Generally any USB device (iPod, cell phone) pulls 5V, which is nothing compared to the 200W the system pumps out.
To get a rough estimate of your available power...
200 Watts divided by available voltage (12), allows for roughly 16.5 amps.
16.5amps is a lot of juice, plenty for any accessories you can slap on a dirt bike.
Anyhow, this is the current setup....soon, I'll be adding the AdvMonster lights....should be awesome.....
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO screwed with this post 11-22-2013 at 12:23 PM
SteveO is offline   Reply With Quote
Old 12-02-2012, 06:21 PM   #2892
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by CBejbl View Post
Met up with the big bike drop-o-rama crowd in the NE region on Sunday. We had a great time. Lots of mud, ice, water and rocks.
Just hosed off the 500 so I can put a skid plate on. Also went with the RAM mount mirrors. Just loosen and fold in.
A great bike!
Sweet ride,will have to check out your bike if/when I can make it to another ride. I think I was on one of those where I saw that bike?
leftystrat62 is offline   Reply With Quote
Old 12-02-2012, 06:23 PM   #2893
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,230
Originally Posted by SoilSampleDave View Post
On dirt bikes or carbon monoxide?
I'd say both!
Although I don't see this incident as a precursor to him sitting in a garage with his car running, just to get a wiff of the fumes...... Although, I do see him getting a bike in the future......
Old 12-02-2012, 06:25 PM   #2894
hoss314
hoss314's Avatar
Oddometer: 135
Yup...500EXC
One of the best upgrades I have installed. A ....."Must Have"
Just installed the BD Squadron headlight. Holy Shite that baby is bright! Looks like I am going to need to order the dimmer as well.
06' CRF450X Plated
Old 12-02-2012, 06:54 PM   #2895
bill1960
Oddometer: 369
Yup...500EXC
If you get time I'd like to see a pic of your seat measuring 8 1/2" inches wide.
As you can see, my seatconcepts foam measured 7 1/2"
Some here have mentioned a pre built seat. Perhaps they're different (or customized) to the option where only the foam and cover is supplied for diy fitment ?
Times are GMT -7.   It's 10:43 AM.
