Old 11-05-2012, 02:40 PM   #3211
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 1,819
LexLeroy, those are some beautiful had made parts.
Nitro Acres, nice welds. I got no rhythm......
My son and I have a job shop. We tig as much as we can.
David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys
There is a seat for everyone.
David R is online now   Reply With Quote
Old 11-27-2012, 04:38 PM   #3212
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,969
Send a message via AIM to JAFO
So you remember those oxy-fuel cylinders I came across a couple months ago? Yeah- I also scored two sets of portables, cheap.
I hae been an oxy-acetylene cutting FOOL over the last month. Trying to figure out brazing now- I blew through an oilpan I was trying to braze a fitting onto. I think I should have used a welding tip, not the cutting head (duh!). To my credit, I didn't activate the cutting jet.
I still have to go get the big bottles filled. That's going to be a pain in the ass- local shops won't fill them if you don't have a pickup bed to put them in.
Did the gent that was trying to use a pressure reg on a Lincoln 3200HD ever get the code broken on settings and such? I would like to give gas-MIG another shot.
JAFO is offline   Reply With Quote
Old 11-28-2012, 12:10 PM   #3213
DiabloADV
Semi-Occasional
Oddometer: 1,534
I've got a Hobart 110v wire feed welder (with gas). I'm looking to weld up some exhaust pipes. I am NOT a highly skilled welder.
I'm looking for technique tips on welding mild steel pipes together. I found this YouTube vid that seems to make a lot of sense to me, at my skill level. Rather than try to lay a bead, the guy makes a series of tack welds around the tube. This strikes me as a way to really control what I'm doing.
http://www.youtube.com/watch?v=_v_6j...eature=related
Thoughts on this approach? Better suggestions...?
'74/'70 R98/6/GS Traveling Bike (construction under way)
'91 Bill Holland Steel w/Dura Ace
DiabloADV is offline   Reply With Quote
Old 11-28-2012, 03:45 PM   #3214
LexLeroy
Boring Old Fart
LexLeroy's Avatar
Oddometer: 814
Flux is your friend. When it turns glassy w/ no bubbles then it's hot enough to melt the filler metal - too much heat and you roach your flux. Use a flux that wets out at the right temp for your filler. For bronze or nickel silver I use Gasflux type "B" - similar to Harris #17 (that blue paste stuff).
"I don't want a nickel... I just wanna' ride my motor-sickle." Arlo Guthrie
LexLeroy screwed with this post 11-28-2012 at 04:17 PM
LexLeroy is offline   Reply With Quote
Old 11-28-2012, 04:55 PM   #3215
David R
David R's Avatar
Oddometer: 1,819
Laugh
A true tack weld is made to break off if needed or hold things in position to be welded.
A series of tacks would be a series of welds made to break off.
I weld exhaust with an SP100 turned down C 3 .
I start at the top and make my way down. One pass each side.
Make a dry pass to see where the gun will fit if its on the car.
David
Old 11-28-2012, 09:02 PM   #3216
fxstbiluigi
aka Road Monster
fxstbiluigi's Avatar
Oddometer: 10,634
Send a message via Yahoo to fxstbiluigi
David
David:
A 'tack' also needs to be strong enough to hold the parts in alignment and withstand the pressure of coaxing the rest of the weldment into alignment. And withstand the stresses of welding once the fit-up is complete.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 11-28-2012, 09:13 PM   #3217
DiabloADV
Semi-Occasional
Oddometer: 1,534
What I mean is to use a series of short welds rather than a long bead.
Old 11-29-2012, 08:59 AM   #3218
JAFO
JAFO's Avatar
Oddometer: 3,969
This will work fine, it's how I built the exhaust on my Jeep. Butt-welded tubes and short tacks. It's been bounced off of rocks and, while the tube has been squashed in areas, the welds have NOT failed.
Sent from my MB886 using Xparent Green Tapatalk 2
Old 11-29-2012, 09:00 AM   #3219
David R
David R's Avatar
Oddometer: 1,819
What I am trying to say is learn the machine. Set it so you can run a bead. It is the right welder for the job. .023 ER70S-6 wire and c/25 gas. I do a lot of exhaust.
If its too hot and you continually have to stop then turn the machine down. If you are almost blowing through then the heat is right.
Have fun and enjoy the machine.
Sent from the phone in my shoe. Maxwell Smart.
Old 12-02-2012, 04:44 PM   #3220
BobbySands
JockeyfullofBourbon
BobbySands's Avatar
Oddometer: 5,677
Originally Posted by fxstbiluigi View Post
David:
eh, don't confuse the two. You tack pieces together and give them a smack, maybe too. But a third or fourth time or too much movement and your pieces are going to be laying on the ground.
In other words, tacks hold together only when subjected to a small force. And when the gap isn't right, the fitter will simply break the tack and have the welder start over.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
BobbySands is offline   Reply With Quote
Old 12-02-2012, 05:12 PM   #3221
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,875
It's fine for exhaust, don't weld a roll cage like that or anything your life depends on. We call that WyoWelding(Wyotech teaches that and it's technically wrong), the weakest part of a weld is the start when it's the coldest and that technique gives you a full weld of cold starts...wrong, but fine for exhaust.
Old 12-02-2012, 05:26 PM   #3222
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 371
If a Tack was a Weld, it wouldn't be called a Tack....Tacks are to hold stuff together till you Weld it....a bunch of tacks stacked ontop of each other is Not a Weld.
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres is online now   Reply With Quote
Old 12-02-2012, 07:17 PM   #3223
fxstbiluigi
aka Road Monster
Oddometer: 10,634
It all comes down to what you are welding.
A tack can be anything from a quick zap from a wire machine, think exhaust system, to hold the parts together. Or an actual weld such as needed to hold two pieces of pipe in alignment for welding. Or a short weld to keep two pieces of sheetmetal from warping so far apart that they can't be welded. Or heavy (1") Plate from warping from the heat input.
Some tacks can be small and light and some need to be considerably more substancial it all depends on the application and circumstances.
Old 12-03-2012, 11:09 AM   #3224
dmaxmike
former quadtard.
dmaxmike's Avatar
Oddometer: 489
I never learned that there? Must be that west coast wyotech. Then again i only used a MIG machine long enough to pass the requirements for it then all I used was TIG because that’s what i wanted to learn and be good at. Most high end race shops don’t even have a MIG in the building. Its real fun tacking together a full class one car with a TIG torch, talk about sun burn!
i don't know how to ride a bike...yet
XT225 - short, fat, and slow; it’s my motorcycle twin.
F650 GS Dakar -little taller, lot heavier, and much faster.
dmaxmike is offline   Reply With Quote
Old 12-03-2012, 01:10 PM   #3225
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,918
Most (if not all) NASCAR chassis are MIG welded. A quality MIG weld is more than strong enough for roll cage work as well as suspension components. I've seen my share of crappy TIG welds in offroad racing. Multiple pass welds where the root pass is cold and fills gaps in poorly notched/fitted tube and then a "sic Bro weave" washed over the top. Total crap strength wise, but looks like a million bucks.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Times are GMT -7.   It's 04:28 AM.
