Old 12-02-2012, 05:58 PM   #8341
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 671
If anyones been over there please chime in with any trail suggestions etc.
DR Ozzy is offline   Reply With Quote
Old 12-02-2012, 08:56 PM   #8342
PBee
_
PBee's Avatar
Oddometer: 9,233
Could possibly make it a regular thing.
Summer rides are scarce.
Do a Recon this Summer, it's mostly easy stuff but so what!
I've got a mate just west of Parndana with 140 acres, might see what he has to say.
KI Kaper.....................
Also Pt Lincoln via the Ferry is on my list this Jan/Mar sometime too.
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is offline   Reply With Quote
Old 12-02-2012, 09:14 PM   #8343
Fipsy
form. gonescratchin
Fipsy's Avatar
Oddometer: 489
Bull600 has posted a gps track of a trip he did there a while ago. From memory, the link to it is in his sig. There's a RR too somewhere.
Fipsy is online now   Reply With Quote
Old 12-02-2012, 09:57 PM   #8344
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 671
I seem to remember reading about a KI trip on here, probably that one.
Old 12-02-2012, 09:58 PM   #8345
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 671
Sounds like the go
Old 12-02-2012, 09:59 PM   #8346
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 671
I have a few vids up from the Flinders ride now if anyone wants a bopeep
http://www.youtube.com/user/Innocent...9?feature=mhee
Old 12-03-2012, 05:03 PM   #8347
Gasman_ADV
Oddometer: 387
Just a quick update for those interested in the Erzberg suspension thing...........
I measured up the oil level in the forks the other day .90mm from top
Book says 120mm to 150mm .advice was all WP forks run best at about 120/125mm
I set the level at 120mm from top
rear spring is a fairly heavy spring and was set at 30mm race........reset to 70mm race
Just came back from a quick spin around the neighbourhood .(and on a SE 950 it is a quick spin)..
finally it feels like a dirt bike ..............the front actually has some drop under brakes and I can get some weight on the front wheel........could probably manage a stoppie if I tried..........
I can also get both tippy toes on the ground whislt standing.....read ...mount the bike easier.
when I first bought the bike it was downright dangerous..........the forks were too high in the tripples and everything was too firm...............it was a shocker...........
anyway it feels a lot lot better just after a quick spin around the block ............and yes i might go and rip those baffles out today as well.
also for those interested in how the wrist is healing .....went and got a heap of xrays and CT scan the other day .....
looks like the liagament on the top side of the thumb is not attached and causing hyperextension of the thumb and little strength when gripping things .......booked in Jan for an op to tighten things up.......
cheers
A
Originally Posted by Gasman_ADV View Post
Thanks again Emu, Ozz and Kev
been thinking about the whole Erzberg suspension thing and what it would take for me to comfortably run with the pack.....
Watching the vid has confirmed how the bike felt, the front springs are too heavy (and I hate to admit it but I weigh 100kg dry) the front simply would not dive enough under brakes for the geometry to take over and put extra weight on the front wheel.........there was a whole lot of skills I couldn't use as I couldn't weigh the front wheel and also put the bike into a tighter steering geometry.............after having two TM's which have the best suspension/geomerty of any dirtbike on the market bar none...........its a bit of a shock.
and the rear spring which I assume is standard is too soft and felt as such over the limestone geeups (I just made that word up)..it was good to get some air on the big girl and landing was generally fine, but it became apparent that once the spring tension was overcome the valving on full compression was lacking, (front suspension) after talking with Kev and Con later I realize KTM have just taken the suspension from the "smaller/lighter" bikes and just put in heavier front springs and left it at that.
the smooth linear power with is the saving grace, wind the throttle on and all is forgiven.
rear spring is WP 140-215
I had the front preload wound right off and comp on 2 clicks
anyway Iam just putting my thoughts out there to help current and future Erzberg owners.
cheers
A.
Gasman_ADV is online now   Reply With Quote
Old 12-04-2012, 01:46 AM   #8348
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Oddometer: 1,537
Oh yeah will be going to KI in Febuary if anyone is interested, is about $160 return for the ferry one person and bike, temperatures should be about 10 degrees less over there than here so good summer trip, one, two or maybe even three nights depending on what time people can get off.
Just came back from K.I. this arvo, spent the last 6 days over there with the Mrs, we didnt take the KTM but we caught plenty of fish & caught lots of Marron & Yabbies too..
Great place, spent 3 days at Vivonne Bay & 3 at Island Beach in a rented beach house.
We did the Quad Bike tour at Vivonne Bay, if anyone tries it make sure you upgrade to the Honda TRX250 which goes pretty well, heaps of fun too.
Cheers, Sol..
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is offline   Reply With Quote
Old 12-04-2012, 01:49 AM   #8349
Sol Erzenberg
Lost somewhere
Oddometer: 1,537
Some of the National Parks have 4WD tracks that would be suited to ADV bikes, I was told there are quite a few throughout the Vivonne Bay NP. I'm sure there would be heaps more elsewhere.
2009 KTM 690 R
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1978 Suzuki RM 100.
ARIEL MCC
Old 12-04-2012, 01:58 AM   #8350
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 671
Cool, did you get the fish off the beach?, I was thinking I might even take a rod and try and catch dinner, could just pull up on the beach and camp maybe, sit back, chuck a line in, have a few beers, have been plotting a course around the island and seen all those lines through the parks and that but I guess you don't really know whats what until you get there and have a look.
Old 12-04-2012, 02:09 AM   #8351
Sol Erzenberg
Lost somewhere
Oddometer: 1,537
Yes off the beach at Vivonne Bay, some great gutters in very close to shore & easy casting distance, the jetty is good too (however the River is full of under size bream).
Did very well at Western River Cove, bream, salmon trout & big yellow fin mullet, the Cove is set up very well for camping with toilets, big shade shelter/pergola & rain water tanks.
2009 KTM 690 R
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1978 Suzuki RM 100.
ARIEL MCC
Old 12-04-2012, 02:33 AM   #8352
bull600
bull600's Avatar
Oddometer: 369
Have fun on KI, it's a top spot
A Ride Report I did on a trip there a few summers ago is here: http://www.advrider.com/forums/showthread.php?t=649131
If you're after a gps log of the trip, just flick me a PM
Cheers
bull600 is online now   Reply With Quote
Old 12-04-2012, 02:56 PM   #8353
slapper
Oddometer: 99
re: frame welding
thanks all for the advice - have dropped in to see Snowy and am dropping the DR off on Thursday.
Now to work out how to get this pig of a thing in and out of the trailer without dropping it :)
cheers,
Slapper
slapper is offline   Reply With Quote
Old 12-05-2012, 04:33 AM   #8354
Bubba Bauer
Bubba Bauer's Avatar
Oddometer: 156
KI feb
Do you have a bit more accurate date within february?
I really want to go, but I have to organize it at work ASAP because they only let 1 person at a time to be on holidays .
It will be my third time on KI, but you just can`t get enough of the place.
Bubba Bauer is offline   Reply With Quote
Old 12-05-2012, 03:35 PM   #8355
Gasman_ADV
Oddometer: 387
again for those interested
I have been thinking about why the front was so firm, the forks were serviced by a larger motorcycle dealer here in Adelaide back in Jan 2011 and I think they may not have relocated one or both of the internal compression damper rods hence the extremely firm front end combined with the high fork oil level. The compression damper rods need to be seated properly otherwise you lose adjustment and I think greatly increased compression dampening as well, this is on the WP forks.
it now feels like a dirtbike !
A.
Times are GMT -7.   It's 06:11 AM.
