Old 12-03-2012, 10:58 AM   #6451
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,888
I have finals this week but after they are done I'll get a site up on my webserver. I'm thinking of a wiki style. If it becomes super popular we can move it to a dedicated host.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 12-03-2012, 04:13 PM   #6452
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Good deal! Shoot me a PM when you're ready and I can send you the domain details.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-03-2012, 06:44 PM   #6453
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
I'm not that popular but I do own a 690R.
I'll be up to contribute some funds and grab some swag.
Can I join the cool club?
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 12-03-2012, 07:44 PM   #6454
TheMuffinMan
Oddometer: 5,888
Sure.
Lets get the website up before worrying about funds though!
Old 12-03-2012, 07:47 PM   #6455
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,603
Sure.
So glad that you bought a 690!
Thanks for stepping up. This will really be a big help to all of us!
Gordy is online now   Reply With Quote
Old 12-04-2012, 10:00 AM   #6456
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,465
On the front of the shirt should be a rider with an ear to ear grin, on the back of the shirt should be a rider swinging a sledge hammer at the same machine.
Seth S
Seth S is offline   Reply With Quote
Old 12-04-2012, 10:37 AM   #6457
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,667
I'm glad you guys got the lemons. Both mine have been great.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
RoninMoto is online now   Reply With Quote
Old 12-04-2012, 12:18 PM   #6458
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Well, we ride them off road more
Just say'IN
Old 12-04-2012, 12:47 PM   #6459
Seth S
Seth S's Avatar
Oddometer: 4,465
mine was good for the first 10,000 miles of racing and woods riding abuse. Then it popped the water pump seal and headgasket. I am not complaining.
Seth S
Old 12-04-2012, 01:16 PM   #6460
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,667
You are probably right. My tires never leave the pavement. I should have got a SM
Old 12-05-2012, 04:46 AM   #6461
NumNum
NumNum's Avatar
Oddometer: 11
Sweet pic Noah,
NumNum is offline   Reply With Quote
Old 12-06-2012, 07:51 PM   #6462
numbutt
john
numbutt's Avatar
Oddometer: 100
More on sidestand switch disable....
Ho-hum it must be winter in USA/north..threads are becoming mundane..!!.... thought id follow some others in disabling the sidestand switch...( in a slow quest to reduce ? the ocasional flame-out when racing to a stop )
Another inmate suggested a 1K to 3K resistor to repace the hall switch putting this resisror between the pink and black wires [ there are 3 wires going to the switch pink, black and blue ].
I did a few tests to ceate some understanding and what we have is a blue wire that supplies a regulated 5 Volts from the ECU to power the switch [ the switch is a Hall device [ linear response to a magnet ] coupled internally to a Schimdt trigger level detector that provide a snap action . [ hope im not boring anyone ]. Anyway, at ignition switch on, 5V is sent to blue and without the Hall connected the pink wire also reads 5 Volts. With the Hall switch in place and activated [ stand up ] the pink wire is locked down to 2.50Volts. Black is the earth wire or at earth potential [ 0 ].. I did a few tests to establish the ( voltage ) effect of adding the first mentioned resistor ''cheat '' to ''pull down '' the pink wire to about 2.5 Volts .
3.3K gives 3.02 volts
2.7K gives 2.78 Volts
2.2K gives 2.52 Volts [ test resistors between black and pink ]
1.8K gives 2.27 volts
1.5K gives 2.06 Volts
1.0K gives 1.6 Volts
After all this bull we must conclude that probably the best resistor to use is 2.2k { 2200 ohms } ...a standard value and i used a 1 watt metal oxide type [ most stable ] [ fortunately i carry many of every resistor 1 ohm ...1 Meg ohm at home so its an easy test !! ]
So after all that #&*@# , simply cut wires to stand above connector near shock, solder in 2.2 K ohms between Pink and Black, heat shrink it, then isolate and heat shrink off the blue so it cant short....and Bobs your uncle ....
numbutt is offline   Reply With Quote
Old 12-06-2012, 09:38 PM   #6463
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,990
great report but you lost me after "it must be winter in the USA/North"
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is online now   Reply With Quote
Old 12-06-2012, 10:41 PM   #6464
Seth S
Seth S's Avatar
Oddometer: 4,465
Call me lazy but I just bought a pre-made side stand switch and plugged it in.
Seth S
Old 12-07-2012, 01:04 AM   #6465
motoged
motoged's Avatar
Oddometer: 908
Yeah....I was gonna say that.
But some of these guys know how to make a simple job so effin complicated
Ged the Luddite
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
