12-03-2012, 09:25 PM
#1051 |
Oddometer: 284
Kevin '12 K1600GTL, '13 TR650 Strada |
12-03-2012, 10:09 PM
#1052 | |
DualsportBC Rider
Oddometer: 41
John
A motorcycle will go anywhere the rider has the ability to take it ----------------------------------------------------- Husqvarna Terra TR650 Beta 400RR |
12-03-2012, 11:10 PM
#1053 | |
Oddometer: 284
Here's my quick comparo, for MY needs/wants, ymmv: The Strada beats the WR250R in: 1) Raw Performance - the Huskyificated Rotax is very strong 2) Braking - ABS on the Strada 3) Speeds >60mph - No problems running 75 on the freeway with plenty of passing power 4) Range, about 175 miles for the Strada, 100 for the WR250R - 3.5gals vs. 2, easily fixed aftermarket for the WR250R The WR250R beats the Strada in: 1) Transmission - shifts better than anything I've ever owned 2) Weight (Strada is 410, WR250R is 298) - It's very nimble, while at the same time surprising planted 3) Power delivery / Fuel Injection - No surprises, consistent, very usable and predictable on the WR, the Strada is a mess below 4000 RPM, needs a lot of warmup, stalls off idle without any load 4) Handling - Again, very nimble, suspension is great for my needs 5) Speeds <60 - No issues on secondary roads, would not want to ride freeway with 65mph limit for very long, but that's not why I bought this bike. (I'm 6'4" 280lbs, it carts my bulk surprisingly well) 6) Ergonomics - The WR250R fits me well out of the box. Strada was good, but I would need risers to do any standing. 7) Fuel Economy - I'm seeing high 40s on the Strada, high 50s on the WR250R, both require premium 8) Maintenance - oil changes at 3k, valves at 24k, strada needs valves checked every 6k, oil @ 6k. WR250R spits out FI faults on the display, Strada needs dealer computer for diagnostics 9) Cost of ownership - $800 less for the WR at MSRP, but lots of competition and supply widen the gap with actual purchase price. If you are up for checking the valves on the Husky every 6k, probably similar maintenance cost, but if the dealer is involved, that's going to be a several hundred dollar bill every 6k, vs 24k on the WR250R 10) Dealer network - There are Yamaha dealers all over the place, including about 2mi from my house. My Husky dealer is 50mi, there's only four in the entire state. If I had to make do with one bike for all purposes, something like the Terra/Strada or one of the larger GSes would likely be my choice. Because I have a road bike, and I don't intend to ride for days to get to where I'll leave payment, I can optimize for the off pavement part with the WR. If I had a big enough garage, I'd keep them both, but I suspect I'd grab the WR much more than the Strada.
12-04-2012, 12:57 AM
#1054 | |
Oddometer: 385
12-04-2012, 01:54 AM
#1055 |
free range
Oddometer: 415
Is it correct as posted above that the valves have to be checked every 6000? Any more info on service intervals would be appreciated.
12-04-2012, 06:00 AM
#1056 |
Oddometer: 448
Had a chance 2 weeks ago to try out the Terra in a little rougher terrain over in W. Va..and I was really pleased with the way it handled the off camber rutted two track up the side of several mountains.In this terrain I think its a little easier to ride than my little WR.It feels more planted than the WR while still maintaining the light feel and the smooth power is awesome for pulling thru the rougher stuff.
Please bear in mind if they issued plates for riders,I would have to run the antique plate... and I was just putting along enjoying life,obviously if I was hammering it the WR would have been a better choice.Just saying...I think this bike will be great most anywhere up to jumping stumps and single track,assuming your riding at a reasonable pace. This was the only pic I took.I was by myself and not willing to stop in the rougher stuff for a pic.Nobody had been across this track in a long time
12-04-2012, 07:51 AM
#1057 |
Adventure Rider
Oddometer: 61
Krussell - does that mean that the Strada is being replaced by the Wr250r??
Jim
Mine 05.5 Ktm 950 Adventure 06 Ktm 950 SuperMoto 06 DR650 13 Husky Tr650 Terra Her's 07 DL650 08 WR250r |
12-04-2012, 07:56 AM
#1058 | |
Oddometer: 284
Clean/lube change every 600mi Oil / Filter every 600 mi, then every 6k Check valves, adjust if necessary every 6k Replace plugs every 12k Replace return pipe oil filter, every 12k Air filter, every 12k, 6k if used in dusty conditions Fork oil, every 12k Brake fluid every year Coolant every 2 yrs Fuel hoses, every 4 yrs Then there's the usual check/adjust/tighten stuff. And finally at every service do "Control Unit Diagnosis" Check/Reset
Kevin '12 K1600GTL, '13 TR650 Strada krussell screwed with this post 12-04-2012 at 08:04 AM Reason: It's plugs, not lugs! |
12-04-2012, 07:58 AM
#1059 |
Oddometer: 284
Yes.
12-04-2012, 09:35 AM
#1060 |
Bronze Age Fall Guy
Oddometer: 5,129
It looks like the perfect match for the 660 Tenere.
Hate gets you nowhere. |
12-04-2012, 10:30 AM
#1061 | |
Red Sox Nation
Oddometer: 8,902
More recently I tackled some serious sand washes and rock gardens. I was amazed at what I could actually roll with that little thing. So I left the Yam out west and promptly sold my KTM 950 in Boston. I replaced it with a more powerful version of the Yamaha...a Ktm690R. Had the Husky been out I would have probably bought the Terra instead. I could have saved a few thousand dollars and I don't really use all the KTM offers anyways.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
12-04-2012, 10:31 AM
#1062 | |
Oddometer: 83
That is good info. I appreciate the feedback. It is very helpful to hear from someone who owns both. Helps me narrow it down.
1994 XR650L aka Captain America |
12-04-2012, 11:50 AM
#1063 |
Oddometer: 284
Hopefully BigDog will way in, he's got a lot more mileage on both bikes, especially the WR. Keep in mind my priorities are MINE, and others will be different. Depending on what you are looking for the TR650 may be a better option, they are fantastic bikes.
12-04-2012, 08:06 PM
#1064 | |
Oddometer: 844
Mud is evil |
12-05-2012, 07:26 AM
#1065 |
Oddometer: 2,460
I'd send that skidplate back. Pretty pathetic piece, especially, for Husky.
And, the Booster Plug has a loyal following amongst Tiger 1050 owners, too. It's a simple fix.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
