11-28-2012, 11:15 AM
#16 |
Oddometer: 2,069
I don't think that discards the battery. It might, if the bike was getting a full 12+ volts while being jumped. Earlier you said the injector had 10 volts. I know an X Bike will not run at that voltage. That low voltage could be due to being discharged, or it could be due to a bad cell. Also, 10V on the voltmeter isn't the same as 10V under load.
I don't know how the system is wired, but unlike most cars, the X Bike needs a healthy battery. If your battery has a bad cell, no charging will revive it and the bike will not run. So even if the stator is putting out 12+ volts, having the bad battery still messes with the efi system for some reason. to eliminate this possibility, I would totally remove the battery and either replace it, throw in a known good battery, or wire it up to your car battery (without your battery in the system).
Marc 07 XChallenge 99 VFR |
11-29-2012, 01:38 PM
#17 | |
Oddometer: 354
I measured the wire that gets to the pump again and it gets 10.6 volts, its clearly possible that a cable is damaged somewhere, as I measured voltage on other cables and got 13.2. Also cleaned the injector which wasn't actually bad, followed this as I had the plug of the canister was able to make a nice tidy connector. Today I took the bike to the dealer as I haven't been able to find the root of the problem and its a real pain to commute on the car. I'll post their findings. Thanks everybody for the help
--- My G650X Challenge, Bike build thread on http://www.advrider.com/forums/showt...7#post15320987 |
12-03-2012, 10:21 PM
#18 |
Oddometer: 354
So the problem was according to the dealer a couple broken wires in the middle of the wiring loom, causing low or inexistent voltage ... I guess I should have stripped all the wiring myself ... next time maybe
