12-04-2012, 03:23 PM
#1 |
Oddometer: 3,315
I was just thinking of doing an update on my 550 since I haven't done one in a very long time.
Has anyone run into any unexpected surprises after doing an update ? I don't want to do the update if its going to cause problems. Thanks
If I wasn't here, I'd be somewhere else |
12-04-2012, 03:39 PM
#2 |
Oddometer: 185
i recently updated maps and software,, no issues unless you count (mind you this was first time ever updatitng maps) not all of the united states will fit on the tiny hard drive.. If you want all of the United States you need to save them to your sd card.. and then point the zumo to read maps from sd card..
take a little longer for the zumo to boot up but once it going no problems.. just remeber it tkae at least three minutes for the zumo to boot up and start giving directions..
Unclebudintx http://unclebudsadventures.blogspot.com/ 2004 BMW R1150GS 2004 BMW R1150RT1979 Kawasaki KZ1000st (sold) 1991 Harley XLHsporty 883 (sold) |
12-04-2012, 03:43 PM
#3 |
Oddometer: 3,315
Thanks what size card are you using ?
12-04-2012, 03:53 PM
#4 |
Truffle Rustler
Oddometer: 1,947
I would recommend a 4GB card, as some of the City Navigator products are now over 2 GB. You can use the extra space for music files if needed.
Normal is just a setting on the dryer. Armageddon was yesterday - Today we have a serious problem. 2009 R1200GS Adventure 2008 K1200GT |
12-04-2012, 03:58 PM
#5 |
Oddometer: 185
8gb but i was told you can go as high as 32gb,, but i have not tested that... i have about 9 hours of music and maps on the 8gb card...
do a seach on this site about updating maps... there is an old thread by some guy nemed zumoman or something like that...it is very helpful.. i thought i had the thread book marked but cant find it right now
12-04-2012, 05:23 PM
#6 |
Oddometer: 1,093
I run firmware 5.0 on the unit.
I put the CN North America maps on the 8 gig SD card along with 1000 mp3s. I use the "free" space on the unit itself for 24K Topo. |
12-04-2012, 05:50 PM
#7 | |
Oddometer: 55
I will be happy to help you with this. Garmin releases 4 map updates a year, and with every map update more information is added. Because of this you will have to select for a smaller region to be downloaded to your device, and the rest of your update can be loaded to an SD card using the MapInstall program. In order to download the rest of your update to an SD card you will have to select for your maps to download to your "device and computer". Below I have provided you with instrucitons on how to use MapInstall. Using MapInstall- The map update installation will install the maps on your Garmin device but will also install them to your computer. This is beneficial in cases where there is not enough free space to install the map data to the internal memory. After you have updated the Nuvi with a region (i.e. West Region) you will need to insert a blank SD card. The SD card must be at least 512 MB but no larger than 16 GB. Once you are connected to the computer, open the MapInstall program. You can open MapInstall from your Start Menu > All Programs > Garmin folder. When MapInstall opens it will ask you to select a device. Just verify that the Nuvi is listed and select the 'removable disk' from the drop down menu. After you have selected the 'removable disk', select Next. Once the map page has loaded, simply select the states you want to install onto the card. Be sure to remember that all of the states you originally loaded do not need to be selected. You only need to select the states that were not included in the region you installed. If you need further assistance please reply to this email or contact us at 1-800-800-1020 Monday-Thursday 8am-6pm and Friday 8am-5pm Central. With Best Regards, Tamara J" No 32gb support according to the reply I got. |
12-04-2012, 07:42 PM
#8 |
Procrastinators
Oddometer: 5,798
Generally when you update a map it takes longer for the initial boot as the gps indexes and caches the new map, but subsequent bootup should not be slower than normal.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
12-05-2012, 11:35 AM
#9 |
Oddometer: 3,315
FOLLOW UP
Thanks for the responses ! I did have a problem with some sort of glitch that Garmin resolved at their end. Once that was done the update proceeded. I was only on hold for ten minutes and the tech was polite and knowledgeable.
12-06-2012, 10:24 AM
#10 |
Oddometer: 1,093
I used to split the CN maps updates between the SD and unit but now just dump the whole thing on the SD card.....don't think it really makes a diff on performance.
Make sure you update the firmware too. Twohondas screwed with this post 12-25-2012 at 12:20 PM |
12-25-2012, 08:51 AM
#11 |
High Desert Rat
Oddometer: 420
I hooked my 550 up to the computer and started to do the Garmin update for grins. It first installed the map installer or did something that updated the 550 so it now says 2012 when it boots up when started. So far that didn't cost a thing so I stopped right there. Hopefully it updated the firmware or software or whatever makes it work and seems to work good but I haven't had in on the road yet.
My thinking is that they haven't changed the road system much since the 2009 maps mine has on it. Maybe to find a new street address or someplace new but I'll try it this way for a while. I am cheap and considering a 660 anyway. The biggest hassle I had was riding down a state or back road highway and the GPS not showing the road. What's up with that?? I always have a paper backup in the tank bag. Maybe the free 2012 issue/update will fix that. |
12-25-2012, 01:51 PM
#12 | |
Oddometer: 185
12-25-2012, 06:21 PM
#13 |
Oddometer: 67
OK, I just copied the entire latest version NA.2013.30 file download (yikes - 6.83GB total) to an 8GB SD card with objective of being able to select that latest map version with SD inserted into my original Zumo 550. As clarification, I own 2/ea Zumo 550, SP2730 and SP2720 units. The other Z550 and both SP2730 feature LM subscriptions, so my hope is to piggyback off those for my original Zumo unit. I figured Zumo would prompt me if I'd like to import newly found data, but no dice. I even detached the files from the NA.2013.30 folder in case that was an issue but no dice.
Some of you mentioned much smaller file sizes, so I'm thinking only a subset of files within 6.83GB total are required? Some clarification would be helpful. What file names/extensions/sizes are you using successfully? I'm not a Garmin novice and I'm actually proficient in creating custom MapSource routing, but this has me stumped. TIA...
Oday ouyay eakspay igpay atinlay? 2004 R1150RT - Biarritz Blue 2004 R1100SA - Pacific Blue |
12-25-2012, 08:13 PM
#14 | |
Old F@rt
Oddometer: 347
You must use mapinstall or one of Garmins map updaters to install maps on your GPS. If you simply copied the downloaded file from your computer to the SD card that just will not work. The install programs compile the maps into a different format than the file that you downloaded from Garmin. |
12-27-2012, 07:59 AM
#15 | |
High Desert Rat
Oddometer: 420
Beware those with no sense of humor as they will cause you misery. Disclaimer: I am only responsible for what I said, not what you understood or how you interpreted my words!! '11 GSA supertanker/mothership, '07 Tiger 1050, Suzuki Burgman 400, wanting a D/S |
