Old 06-03-2012, 06:02 PM   #61
Sadlsor
Oddometer: 691
As mentioned on p2 by ADVMax, this happened to me and is well documented with photos and all, must be back in '08? '07 maybe? Beats me.
Mine is a 2005.5, and I'm pretty sure the TSB for the rotor - loctite check included my year. Mine looked pretty much exactly like this thread.
Had prolly ~10K miles (bought used in '07 with 1300 - not K miles on it) at the time.
I changed the oil, after replacing the first stator ...and used the wrong Loctite. So I got to do it twice. Second time, I cried to Max and he suggested the... the... whatever the hell he said. (See p. 2 this thread.)
After replacing the second replacement stator, I changed the oil and worried some more. Nothing happened except putting on more miles. And more tires. (Not sure the tires are related to the stator issue. But I could be wrong.)
Anyways, my symptoms each time were very clear. (At least they were, if I had a clue.) The battery stopped holding a charge. Because it wasn't being charged by the alternator / charging system. D-uh!
And because the copper windings on my stator were being shredded, minced and pulverized by the bolts that were not thread-locked properly and backed out of the rotor which was spinning round and ...I think I'm repeating myself.
So, yeah, on a late-model 2005 / pre-release 2006. AKA 2005.5.
And I used the same gasket.
And it still doesn't leak.
And I ain't goin' back in there unless I have to.
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 06-03-2012, 09:02 PM   #62
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,713
Just so I'm clear, the TSB relates to 03-04 bikes but the failures have been documented to 05.5 or 06. Presumably this would also be an issue on the SE (07-09)?
v8toilet is offline   Reply With Quote
Old 09-17-2012, 06:32 PM   #63
Xskydiver
Xskydiver's Avatar
Oddometer: 223
I just had the same thing on my 04. My dealer said my VIN wasn't in the range so the TB was never done. They are calling KTM to ask for a fix anyway. Mine has 15k miles. I also did the torque limiter and didn't check the bolts.
dsadvtours.com
"Adversity doesn't build character. It reveals it."
Xskydiver is online now   Reply With Quote
Old 12-04-2012, 04:03 PM   #64
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Sorry to hear of your troubles. I just hand checked that mine are tight last week (06).
I figured me removing, cleaning and re-648ing the bolts came with a chance of screwing up (not removing all the oil etc) so I left them alone
Yeah, I kind of felt the same way, someone said just re-torquing might actually beak the loctite that was there.. anybody else buy that?
erappaport is offline   Reply With Quote
Old 12-04-2012, 05:03 PM   #65
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 541
The little I know about loctite when you brake it louse the bolt/nut is stell bound all the way out I Would think that it is not the end of it but what is there in to puling it all apart and re applying
slidewayes is offline   Reply With Quote
Times are GMT -7.   It's 12:19 PM.
