Go Back   ADVrider > Fluff > Ask Baldy, blame AceRph
Thread Tools Rating: Thread Rating: 21 votes, 4.81 average. Display Modes
Old 11-30-2012, 12:39 PM   #5386
klrzorn
klrzorn's Avatar
Oddometer: 819
klrzorn is offline   Reply With Quote
Old 11-30-2012, 09:16 PM   #5387
Pinzon89
Pinzon89's Avatar
Oddometer: 17
Test
Pinzon89 screwed with this post 11-30-2012 at 10:27 PM
Pinzon89 is offline   Reply With Quote
Old 12-03-2012, 02:22 AM   #5388
ozboy
ozboy's Avatar
Oddometer: 16
Originally Posted by Guzz View Post
Winbloze tidbits...
Print Scrn = the entire screen into clipboard
Alt+Print Scrn = the active window into clipboard
Does this work on a Mac?
One does what one is; one becomes what one does - live it!
ozboy is offline   Reply With Quote
Old 12-03-2012, 09:51 AM   #5389
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
1. The simple “print screen button” capture:
Press the Apple key ⌘ + Shift + 3 all at the same time
You will find a capture of the screen on your desktop named ‘Picture _’
2. Capturing a selected portion of your screen:
Press the Apple key ⌘ + Shift + 4 all at the same time
You will see the cursor change to +
Drag a box around the section you want to copy and release the mouse
You will find a capture of the screen on your desktop again entitled ‘Picture _’
3 . Capturing from a selected application window:
Press the spacebar
The cursor will change to a camera. Simply click on the window you want to be captured.
Again the capture of the screen will be on your desktop labelled ‘Picture _’
rotten is offline   Reply With Quote
Old 12-03-2012, 05:45 PM   #5390
Bob in Indy
Bob-O
Bob in Indy's Avatar
Oddometer: 13
Test
Bob Smith
2011 Yamaha WR250R
Bob in Indy is offline   Reply With Quote
Old 12-03-2012, 06:38 PM   #5391
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,303
el examen
Falcon86 is offline   Reply With Quote
Old 12-03-2012, 08:40 PM   #5392
daveel
"Who me?"
daveel's Avatar
Oddometer: 214
test
test
daveel is offline   Reply With Quote
Old 12-03-2012, 09:12 PM   #5393
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by daveel View Post
http://www.shutterfly.com/lightbox/view.sfly?fid=20570ea9d03daf766d9889752d9a603c
seems your shutter fly image is not public accessible which it needs to be in order to be viewed.
Old 12-03-2012, 11:28 PM   #5394
SpeedySapper
SpeedySapper's Avatar
Oddometer: 19
SpeedySapper is offline   Reply With Quote
Old 12-04-2012, 05:50 AM   #5395
yaktackler
Oddometer: 14
test
yaktackler is offline   Reply With Quote
Old 12-04-2012, 08:12 AM   #5396
JPDenny
Oddometer: 24
Trouble with Pics
I finally learned how to post, the thing I was doing wrong was using the "Insert Image" button, don't bother with that, just right click in the message, paste the code, and you are done. Preview post & you should see the pic.
JPDenny is offline   Reply With Quote
Old 12-04-2012, 08:13 AM   #5397
JPDenny
Oddometer: 24
pic test
Old 12-04-2012, 06:59 PM   #5398
red clay
Oddometer: 12
test test
red clay is offline   Reply With Quote
Old 12-04-2012, 07:07 PM   #5399
red clay
Oddometer: 12
http://s205.beta.photobucket.com/use...34875697544283
Old 12-05-2012, 11:34 AM   #5400
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by red clay View Post
Close... try this..
and you should get this...
if you select the highlighted IMG code it will auto copy then just paste it directly into your post without using the insert image button (its already included in the IMG code). CTRL+V or right click in post and select paste and BAM your good to go....
Let me know if you have any questions!
Thread Tools
Times are GMT -7.   It's 03:24 AM.
