Thread Tools Rating: Thread Rating: 154 votes, 4.94 average. Display Modes
Old 12-03-2012, 04:34 AM   #1396
anotherguy
anotherguy's Avatar
Oddometer: 6,344
The article I read referenced a piston wear rate of .03MM per 1000 hours. Don't know what is considered worn out on something like that.
you don't see luggage racks on a hearse..........act accordingly
Old 12-03-2012, 01:59 PM   #1397
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,977
Originally Posted by Maccoul View Post
Wonder what kinda oil they use Seriously I wander what the service interverl is on that monster. At 100 rpm whats an over haul like 20 years?
Maybe its like the Golden Gate Bridge; never done. They just keep pumping oil in one end, and pumping it out on the other...
How about this V-16? 640 bhp @ 11,500 rpm. Crafted from 4 Yamaha 1000's.
High Country Herb is offline   Reply With Quote
Old 12-03-2012, 02:25 PM   #1398
ttpete
Rectum Non Bustibus
Oddometer: 5,938
One of the Navy ships I served on was diesel engined. Two 3000 hp 9 cylinder Nordbergs. We never changed oil, but we ran continuous purification on it through DeLaval centrifugal oil purifiers.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 12-03-2012, 03:31 PM   #1399
ragtoplvr
Oddometer: 6,302
They are designed to be overhauled in place. Some big engines can actually be shut down. one cylinder disconnected. Restarted and then run without that cylinder, They can do liner and cylinder jobs with the equipment on the boat.
Rod
ragtoplvr is offline   Reply With Quote
Old 12-03-2012, 03:43 PM   #1400
Kubla
Oddometer: 1,341
ship will probably be scrapped before the engine needs an overhual
1996 Harley Tour Glide
1998 Honda Helix
1989 Honda Pacific Coast
2000 westward Go-4
1982 Bluebird wanderlodge
Kubla is offline   Reply With Quote
Old 12-03-2012, 04:06 PM   #1401
ttpete
Rectum Non Bustibus
Oddometer: 5,938
Rod
We had a spare cylinder sleeve and piston hanging on the after engine room bulkhead. There were chain fall tracks over each engine.
15 BMW RnineT
09 Kaw Versys
Old 12-04-2012, 09:02 PM   #1402
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
My red brick after a complete rebuild and getting ready to plug it back into my 1800S. Before and after.
GT 40 engine at the Cobra Museum in Boulder.
In Situ
429
SAAB Rally car
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 12-05-2012, 03:52 PM   #1403
schlitz
the slow one
schlitz's Avatar
Oddometer: 107
Let's ride bikes!
schlitz is offline   Reply With Quote
Old 12-05-2012, 05:11 PM   #1404
Gimpinator
This is my Mom's cat
Gimpinator's Avatar
Oddometer: 1,117
Originally Posted by MrBob View Post
429
Actually that's an FE Series engine - most likely a 428 between the fenders of what looks to be a Shelby GT 500 Mustang.
The GT-40 engine up top has a reproduction Shelby block. You can tell because the Shelby blocks have two side bolts per cap, where original Ford 427 blocks only have one.
Yeah I know... Call me the Klay of Ford engines. I'm a detail Nazi - Eeet must be correckt!
"Son, I thought by now you would have run out of stupid."
Gimpinator is offline   Reply With Quote
Old 12-05-2012, 05:41 PM   #1405
broncobowsher
broncobowsher's Avatar
Oddometer: 1,657
The quick way to tell if it is an FE engine is to look at the intake manifold and valve covers. The FE intake goes under the valve covers. If the valve covers are off you can see the pushrod holes going through the intake and not the head. Very distinctive feature of the FE. Same if it is the little 332 or the big 428.
broncobowsher is offline   Reply With Quote
Old 12-05-2012, 08:00 PM   #1406
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
I appreciate the correction. I didn't have information on that engine but the photos were from my visit to the Shelby Cobra Museum in Boulder - a wondrous place for motor heads.
http://102449.smugmug.com/Other/Shel...6640211_wPj3xT
bwanacswan's dad
Old 12-06-2012, 08:17 AM   #1407
ttpete
Rectum Non Bustibus
Oddometer: 5,938
My take on the double crossbolts is that the block is aluminum and needs the extra support because the skirt isn't as strong as cast iron.
At the time that Ford was competing with these engines, I was working for the company in a research area. I saw the 3 valve heads that would have gone to LeMans if the French hadn't changed the rules to prohibit the big engines. The flow lab boss said they were flowing 550 CFM per cylinder.
15 BMW RnineT
09 Kaw Versys
Old 12-06-2012, 08:32 AM   #1408
Keyser Soze
Keyser Soze's Avatar
Oddometer: 294
Keyser Soze is offline   Reply With Quote
Old 12-06-2012, 10:43 AM   #1409
Gimpinator
Gimpinator's Avatar
Oddometer: 1,117
^^^^ Kaase!! ^^^^
http://www.jonkaaseracingengines.com/ Plenty of engine porn on there. That's an easy 750 HP on pump gas, with plenty of vacuum to run power brakes, etc.
Those things are da bomb!
Old 12-06-2012, 02:16 PM   #1410
kobudo28
kobudo28's Avatar
Oddometer: 5,885
Yep, it's a piston out of a Ingersol Rand KVS 26CT Engine. This one was over limits on out of round and was pulled. The bare piston weighs 400lbs so it makes a nice solid vice stand.
Here's a few pics.
The piston has two threaded holes in the dome of the piston that are used for attaching a pulling tool to remove the piston from the engine. I just cut a piece of plate and drilled two holes so I could attach the plate to the piston with bolts....worked great.
This is the KVS 26 engine, it's rated at 1000 HP at 330 RPM and drives two integral double acting compressors. This engine is used to compress natural gas on a pipeline and is the smallest engine/compressor on the pipeline.
Inside the KVS crank case taking crank thrust readings. The power rods are removed in this pic so the power pin is wrapped in cardboard to keep it from getting scratched.
Here's a few pics of one of the larger units, It's a Clark 12 Cyl two cycle engine driving three double acting compressors, it's rated at 4500 HP at 300 RPM.
I have more pictures of the Clark here: http://www.advrider.com/forums/showt...ight=hodakaguy
Hodakaguy
Be yourself, everyone else is already taken.
kobudo28 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:25 AM.
