Old 12-05-2012, 05:37 AM   #16
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,111
If you are a vest person (I am), a heated vest is better. Particularly if you're planning on adding it to a layered system - that is under your jacket liner instead of replacing your jacket liner.
Hell, I have removable windblock sleeves on mine (unheated) and they're even too much often enough.
I neet to upgrade soon and will probably go full jacket because I don't think the powerlet rapidfire stuff comes in vests, so I might have to leave my sleeve and pit vents open above 30 degrees, depending. If the rapidfire stuff is as comfortable to wear as the ads claim, it might be worth it.
I'd also strongly suggest going with the coax barrel connectors rather than SAE connectors to connect it to the bike, especially if you commute.
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 12-05-2012, 05:54 AM   #17
wee-twin
Oddometer: 198
I was looking at vest as well, but went with a jacket as everyone suggested. Worried about to much electic load I got the 65w jacket from warm&safe. They give us a generous ADV discount as well.
wee-twin is offline   Reply With Quote
Old 12-06-2012, 07:08 AM   #18
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,432
I can't imagine wearing my riding jacket, my heated jacket liner, and a t-shirt and wanting to have the sleeve and pit vents open when riding in 30 degree weather. Unless we're talking 30C....
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Times are GMT -7.   It's 10:24 PM.
