Old 12-04-2012, 09:17 PM   #2911
Bengt Phorks
Oddometer: 272
Originally Posted by ngads View Post
anyone have experience with the map switch?
I am trying to decide between the 500 and the 350, but i feel like in the long run i would want more power. However, in tight tracks i feel like the 500 may have too much power.
If the map switch on the low setting dials down the power to usable in tight situations then i would def. be set on the 500.
any help would be greatly appreciated!
I have a 2012 500 EXC with the Euro map installed and the map switch. The mild setting makes the throttle more linear. It takes out the snappy response and replaces it with an electric motor feel. The throttle is less responsive. It makes riding in the rocks and mud much easier.
The standard setting seems to have a more rounded power band snappy low end, a strong mid range and good top end. More throttle equals more speed.
The wild setting shifts the power to the mid range and top end. Less low end torque and more top end power is the feeling I get from it.
To change the map setting, flip the switch to the setting you want, kill the motor with the ignition switch,restart and the new setting will be active. The Euro manual says that the setting can also be changed by letting the engine go to idle. I keep meaning to try this but I am having so much fun that I forget I even have the switch. I end up leaving the bike in standard mode since it feels the most versatile.
This bike will pull from idle to 10000 rpm. When I picked it up at the dealer he said "Watch out, it goes faster than you think it does."
Bengt Phorks is offline   Reply With Quote
Old 12-05-2012, 07:40 AM   #2912
garrett
garrett's Avatar
Oddometer: 472
Originally Posted by SteveO View Post
I may have posted this before....can't recall..... but, some folks asked for some more info on this setup, so I took some more pics to post up.....
I went with Powerlet due to their reliability and quality products for motorcycles.
Here is a listing of what I've put on my KTM 500 EXC
Low-Profile Powerlet Socket
PowerLet Fuse Block Assembly
Rigid Powerlet to Cigarette Socket Adapter
Micro USB Short Powerlet Charging Cable
Here is an image of the Fuse Block installed next to the Battery and next to the stock Fuse Block. This Fuse Block interfaces between the battery and the following:
Hard-wired GPS
Trickle Charger - That can double as a heater for a vest
PowerLet Plug - mounted on the HDB bar
AdvMonstor LED lights - To be setup
Here are some more pics of the full setup
Of course, you don't want to be in motion with you ipod charging......
As far as power drain, it's really a non-issue.
Generally any USB device (iPod, cell phone) pulls 5V, which is nothing compared to the 200W the system pumps out.
To get a rough estimate of your available power...
200 Watts divided by available voltage (12), allows for roughly 16.5 amps.
16.5amps is a lot of juice, plenty for any accessories you can slap on a dirt bike.
Anyhow, this is the current setup....soon, I'll be adding the AdvMonster lights....should be awesome.....
Steve
Thanks for the pics and explanation. I've got the HDB setup on my 500, 2 other bikes too (love it). How did you re-route the front brake line so it's not over top the gauge protector?
Does the low profile PowerLet socket come with wire to reach the fuse block assembly or did you splice between the fuse block and socket? I'm not experienced in electrical matter so if it ain't plug and play I'm sitting there staring at it thinking, "now what?".
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 12-05-2012, 10:00 AM   #2913
redtale2000
Oddometer: 2
Originally Posted by snow View Post
Has anyone used the Nomadic Cycle Racks on their 500 EXC they are for sale on eBay.
I installed one on my 350 EXC-F (I'm 99% sure the frame is the same as the 500, at least back there) but it has real problems. Overall, nicely made but the mounting arrangement is WEAK on this model: The rack mount consists of two cylinders that are supposed to slip into the two cylinders at the very rear of the subframe where the fender mounts. A through-bolt is supposed to hold these cylinders together. There is also a very short (less than an inch) tab attached right at one of the cylinders that is bolted to the exhaust mount and is supposed to be the 3rd of what needs to be a 3 point mount.
First problem is that the very sturdy powder coat on the rack makes the rack cylinders too big to fit into the frame cylinders. After much filing and sanding, I got the cylinders to "mate" but not perfectly. I installed Loctited bolts as tight as I dared. First rocky ride with a few tools on the rack and it worked itself loose enough to snap off the tab.
The real problem with this model is the lack of a real 3rd mounting point. If you look at the other Nomadic models they all have some other bracket or tab that is several inches away from the other mounts, providing a sturdy mount. This model is essentially cantilevered from the two cylinders which aren't very secure to begin with.
After the failure, emails to Justin Neimeyer of Nomadic got no response at all. It was after the 90 day warranty period (I had not got around to installing it for awhile after purchase) but you'd think there would at least be some response.
As I mentioned, the rack seems well made, especially for the price, but the design on this particular model is crap.
Bit the $billet$ and went w/Pro-Moto. Now that"s bullet-proof.
redtale2000 is offline   Reply With Quote
Old 12-05-2012, 10:17 AM   #2914
ngads
Oddometer: 40
Great thanks for the info !
ngads is offline   Reply With Quote
Old 12-05-2012, 12:40 PM   #2915
avconnect
Oddometer: 120
Originally Posted by garrett View Post
Steve
Garrett
I have been unable to find a solution for the routing of my clutch cable. A different HDB top clam that is shorter on the above the bars side might do it but then you are giving up some real estate that is what makes HDB so desirable. What we really need to find is a clutch cable that dives or angles downward sooner. I tried the Moose cable and it did nothing to help the problem. For now, I am keeping an eye on the cable.
avconnect is offline   Reply With Quote
Old 12-05-2012, 06:24 PM   #2916
bill1960
Oddometer: 369
powerlet for gps ?
In the past I've used the gps hardwire cable to power my gps direct from the battery via inline fuse.
I'll be installing the HDB setup soon which will include a low profile powerlet socket in the top clamp.
Rather than running the gps hardwire cable to the battery, I'm thinking of hardwiring the powerlet socket direct to the battery with inline fuse, then attach the low profile right angle powerlet plug to the end of the gps hardwire cable.
That way I dont have a cable dangling around when the gps is not on the bike. The only other use for the powerlet will be stationary use such as tyre pump or usb phone charger.
Question
Will the right angle powerlet plug to powerlet socket be a secure enough connection to provide uninterrupted power to the gps when riding over rough terrain ?
bill1960 is online now   Reply With Quote
Old 12-05-2012, 07:01 PM   #2917
hoss314
hoss314's Avatar
Oddometer: 135
Just installed the BD dimmer switch for my Squadron. Works awesome! A plug and play set up...low beam is adjustable and uses the stock switch. Mounts on back side of headlight shroud.
Sent from my ADR6350 using Tapatalk 2
08' KTM 690 Enduro (Black Rally)
06' CRF450X Plated
hoss314 is offline   Reply With Quote
Old 12-05-2012, 07:23 PM   #2918
garrett
garrett's Avatar
Oddometer: 472
Hi Av
Have you seen the cable hooking on the protector at all? Mine seems like it should be OK but it is at the end of it's travel. I've got a tall riser from HDB so I may have to order a shorter unit if it's problematic. Don't have my studs on yet so I haven't ridden the thing since I brought it home. :(
Garrett
I like bikes...
Old 12-05-2012, 07:30 PM   #2919
toeneal
Oddometer: 3
I installed the BD light with dimmer last night and went for a short ride. At full power it is absolutely incredible. Is it normal to have a 2-3 second delay when switching from full power to "low beam"?
toeneal is offline   Reply With Quote
Old 12-05-2012, 07:34 PM   #2920
avconnect
Oddometer: 120
Hi Av
Garrett
I have not seen it hang up in riding conditions. I have very tall risers as I am 6'5". That may also be part of the problem.
Old 12-05-2012, 07:35 PM   #2921
avconnect
Oddometer: 120
Can you post a picture or two? Has anyone used the SAR switch with the dimmer?
Old 12-05-2012, 09:33 PM   #2922
the_babaji
the_babaji's Avatar
Oddometer: 321
Mine switches instantly. I would not want any delay. Contact support.
Sent from my GT-I9000 using Tapatalk 2
the_babaji is offline   Reply With Quote
Old 12-06-2012, 09:59 AM   #2923
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
anybody out there using the BD ignition switch? if so which way do you turn the key for power on? mine powers on when it turns to the left which is opposite the factory switch. did I do something wrong?
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 12-06-2012, 10:39 AM   #2924
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,713
Curious what this light and dimmer look like? Ya got any pix?
Guns keep society safe.
Colemanfu is online now   Reply With Quote
Old 12-06-2012, 06:19 PM   #2925
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,975
Wonder what happened during your install?....just measured mine and it is at 8 1/2".
Hands down the best seat right out of the box. I have them on three of my bikes...a must have upgrade same as a stabalizer in my opinion.
Here is my brand new out of the box Seat Concepts "complete seat".
This is the factory made one they ship to you that they build. It is standard height. Carbon sides. Gripper top:
Informal "squeeze test" - I squeezed with my thumb until I could feel the seat pan:
vs. the stock seat:
Fit is perfect... just like the stock pan
Profile:
Top shape:
Right side:
Left side:
Pretty much the same thickness as stock - it is wider at the back than stock but not by a lot.
The big difference is the foam density.. only a ride will tell whether it works for my arse or not.
Hopefully I can sneak out for a few hours tomorrow before the snowstorm arrives this weekend.
Times are GMT -7.   It's 10:23 AM.
