Old 12-05-2012, 07:03 AM   #16
Crazy_Dave
Back'in it in
Crazy_Dave's Avatar
Oddometer: 582
Be forewarned. The PBR handles are made out of powdered metal or some kinda cheap cast.
I broke mine so I made a longer one out of SS , much happier now.
It’s easier to apologize then it is to ask permission.
01 R1-01 CBR929-08 WR250R-92 DR650 (24-7 365)-07 F650GS-05 200 EXC-03 450EXC
Crazy_Dave is offline   Reply With Quote
Old 12-05-2012, 03:02 PM   #17
Myfuture_yourdebt
Oddometer: 372
Tools required: safety wire and safety wire pliers (can be bought as a kit from major retailers). It's the best middle ground I've found between clip style and rivet style master links; it's by far the easiest set-up and if done right is very safe and secure. You get the convenience of the clip style with the security of the rivet style...no chain tools needed for install or removal. This sort of master link securing is done in the aviation industry.
Myfuture_yourdebt is offline   Reply With Quote
Old 12-06-2012, 06:56 AM   #18
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,228
Interesting.
I'll stick with the rivets for now, because I have the tool, but I wouldn't be opposed to that method.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 12-06-2012, 09:27 AM   #19
ttpete
Rectum Non Bustibus
Oddometer: 5,844
If one has to use a clip link, after putting the clip on, use the chain tool to pull the side plate back hard against the clip. It will help secure it from being knocked off because it can't flop around with tension on it.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 12-06-2012, 08:33 PM   #20
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,647
this is the pro tool
http://www.motionpro.com/motorcycle/partno/08-0135/
i have the bottom one on your list of 3 and works great for home use.
the key is to always grind the pin head to ease disassy.
the higher end tools are stronger so you can just push the pin out w/o grinding (ie quick shop work) but they are much heavier in your hands to work with.
since it's occasional home use i go with the bottom of the 3 and grind
http://www.motionpro.com/motorcycle/partno/08-0058/
i find the quality of the metal & tool very high.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-06-2012, 08:36 PM   #21
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,647
that's slick. replace the clip w/ safety wire.
question? why wouldn't aviation go with the most solid option and always rivet?
Alaska
Old 12-07-2012, 11:57 AM   #22
Myfuture_yourdebt
Oddometer: 372
Good question. I have no idea. Maybe safety wire is the most solid, secure option. I'm not part of the aviation industry, but when I recommended the safety wire master clip idea on a different forum someone responded that doing that is inline with aviation safety codes or something like that. "NAVAIR 01-1A-8" he said.
Old 12-07-2012, 12:10 PM   #23
LuciferMutt
Oddometer: 11,228
I'd wager a guess that they choose safety wire because it offers an easier item for quick visual inspection -- if the were is there and not cracked/broken/it's fine. Same idea as those torque paints that crack if the fastener turns.
Old 12-07-2012, 04:04 PM   #24
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,193
Yep.
Most people have never heard of this, especially those people who are sitting next to the road wondering where their chain might be.
I once saw a roadracer casually snap a much-used master link clip into place with his fingers after changing a sprocket and then head back out onto the track. Gave me the willies.
Anyway, yeah, the PBR is a very nice tool.
I've done the safety wire thing before as a temporary measure to deal with a missing clip. Not that inhumanly neat, but it worked. I didn't know it was an "officially" acceptable thing, though.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is online now   Reply With Quote
Old 12-08-2012, 12:12 AM   #25
Beezer
Oddometer: 5,748
the things that get safety wire on aircraft almost always have a hole drilled in it to accommodate the wire, and the wire is captive. a wired bolt or turn buckle will not move. the wired master link... mebby, mebby not
I have also seen guys wire the clip to the side plate
Beezer is online now   Reply With Quote
Times are GMT -7.   It's 03:54 PM.
