Old 12-04-2012, 10:29 PM   #5416
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,723
Cut Wire
I believe you are correct. It is +5v source for the Idle regulator position sensor. AKA Throttle Position Sensor.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 12-05-2012, 02:42 AM   #5417
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,949
Yup, that's the TPS
Have a look here, the pictures show the various parts all nicely labelled. Plus there's a link wiring diagram on the page too!
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is offline   Reply With Quote
Old 12-05-2012, 04:26 AM   #5418
Lamented
Oddometer: 486
Originally Posted by itsgunnahurt View Post
Yup, that's the TPS
Great link thanks.
A little armageddon is good for you.
Lamented is offline   Reply With Quote
Old 12-05-2012, 04:28 AM   #5419
Lamented
Oddometer: 486
Originally Posted by DESERT SCORPION View Post
Yes, the gas cap wants to cross thread very easily. This was not always the case on my bike. It swells up after continued exposure to gasoline. I partly remedied this situation by baking the cap in the oven at 175 degrees F. for about three hours. Much smoother fit after this, but after a few weeks its as sticky as ever. Next I tried sanding the entire threaded portion of the cap down with 220 wet or dry sandpaper. This barely had any effect because the plastic is extremely abrasion-resistant. I could not remove enough material. The trick I use presently is to wind the cap counterclockwise until I feel the tank and cap threads jump by one pitch. Now firmly push the cap againt the tank opening while slowly turning clockwise. One must be very persistent to keep the cap level with the face of the filler neck. After about half a turn it is engaged enough to finish tightening it. Naturally BMW chose not to use a standard pitch, or I would just replace the damned thing with a $10 O'Reilly non-vented cap. There is a nice alloy cap that Husky lists in their Special Parts Catalog for the TE449; Cod. 8000H4069. I wonder if it will work on the BMW?
THE SCORPION
worth a look!
Old 12-05-2012, 05:49 AM   #5420
jack splash
Two Sheds
jack splash's Avatar
Oddometer: 2,337
Black Plastic!
Hey: I purchased the Black Plastic set for the G450 from speedbrain last year for a project, but didn't get to it. Now I'd like to keep the bike white. So I paid appx $300 for the set, I'd like to get that back. email me at jack-bsm@comcast.net if intrested.
Makes a great xmas gift. for yourself.
jack
Stay dirty my friends!
Bigfoot has a picture of me!
www.pinebarrens500.org
www.pinebarrensadventures.com
jack splash is offline   Reply With Quote
Old 12-05-2012, 09:48 AM   #5421
Lamented
Oddometer: 486
any chance you got the speed brain sticker set too?
Old 12-05-2012, 09:51 AM   #5422
NoVa Rider
Oddometer: 2,870
IIRC, I have a sticker set for the rear and number plates. I can send pics if interested.
NoVa Rider is offline   Reply With Quote
Old 12-05-2012, 09:55 AM   #5423
Lamented
Oddometer: 486
send em!
Old 12-05-2012, 02:51 PM   #5424
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
I would be interested at
for the speed brain black plastiX
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 12-05-2012, 07:16 PM   #5425
SRFade
FeHorse Rider
SRFade's Avatar
Oddometer: 53
Clutch Drag?
Fairly new to this bike having purchased a 2010 a few months ago with 1800 miles and 50 hours on the clock. After 20 hours of riding, put the bike in for some minor warranty repairs and its second oil change. The bike was returned to me with what I felt was excessive clutch drag with a pretty strong bang from neutral into first. Long story short, after a complete teardown of the clutch pack and replacement of the thrust bearing (under warranty), the clutch still doesn't feel like it completely disengages and the dealer is now telling me that it is "normal" after additional fiddling and adjusting at both the lever and the cable end. I know there are a lot of variables in this issue, including what I think is normal. Just wondering if this is common or normal and, if not, any suggestions?
“You can ignore reality, but you can’t ignore the consequences of ignoring reality.” Ayn Rand
2008 1200GS "Babe" (Sold)
2010 G450X (Sold)
2013 690 Enduro R
SRFade is offline   Reply With Quote
Old 12-06-2012, 06:04 AM   #5426
Lamented
Oddometer: 486
Mine is the same
Old 12-06-2012, 06:08 AM   #5427
Gearhead001
Nut
Gearhead001's Avatar
Oddometer: 75
Gas Cap
THE SCORPION
I use a dab of Vaseline (petroleum Jelly) on the threads. I no longer have a problem..
Gearhead001 is offline   Reply With Quote
Old 12-06-2012, 06:58 AM   #5428
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,760
101 uses
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 12-06-2012, 07:24 AM   #5429
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Brings a new meaning to screwing the cap.
Old 12-06-2012, 07:28 AM   #5430
Gearhead001
Nut
Oddometer: 75
Wicked Gas Cap
Originally Posted by Stagehand View Post
101 uses
One of the few things you can use anywhere on anything!!
Times are GMT -7.   It's 03:42 PM.
