Old 11-25-2012, 02:30 PM   #781
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,195
Changing out the cams on my V strom and found that using a pickup magnet for removing the buckets over the valves works great. Also using a tire marking pen works for marking the cam gears to the cam chain is great for putting them back in place correctly.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-03-2012, 04:15 PM   #782
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 740
Originally Posted by ibafran View Post
Long ago, some boy scouts wanted to have storm-proof, extra large backpacks for staying in the backcountry longer. They took some ordinary pack frames and mounted large, tough, plastic kitchen garbage containers to them. Not the round containers but the squarish ones. These things pre-dated tupperware with the snap on lids. The scouts just threw a piece of oilcloth over the top opening with a turn of rope to keep it there.
Sometime later, I saw bicycle pannier baskets that folded flat against the bicycle when not needed. With that idea, I wondered what it would take to craft such baskets to accept some useful sized plastic containers? If the plastic containers are sized to be common and cheap, it might be easy to crash 'em and buy new ones at a big box store. Farm & Fleet sells nice tough feed bins in various sizes.
No, I am not a KLR rider. But I do like that down&dirty, proven-tough, post-apocaliptical look as it wards off those pretentious GS clowns. Kitty Litter panniers with a cuppla ADV stickers looks like useful pretty good fun to me.
Used a kitty litter lid for the front number plate on an old Yamaha IT175, painted it yellow to match the side plates, worked great. We named that bike "Cat Scratch Fever"
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 12-05-2012, 08:51 PM   #783
jeepsandbikes
loneadventurer
jeepsandbikes's Avatar
Oddometer: 155
to protect a wire that gets bent a lot , use the spring out of a old pen . twist it over the wire and volia .
this can be used for wires that rub , or cables for your phone /gps that get bent near the ends .
i also had a valve cover bolt strip and work its way loose , DPO stripped the threads . It was spitting oil all over me and the side of my bike . i pulled over and had a look at what junk i had with me . I had a rubber bunji that a guy gave me on a trip east . I used a nut and bolt that i had to remove from my dash cut a piece of rubber and using my swiss tool reamer put a hole in the rubber . i stuck the bolt through the rubber and threaded on the nut . it was just tight enough to slide into the hole where the bolt was . i tightened it up , it expanded and plugged the hole . i rode it that way for a week till i could track down the proper size heli coil for the head .
A bad day of riding is better then a good day of work
jeepsandbikes screwed with this post 12-05-2012 at 09:19 PM Reason: forgot something
jeepsandbikes is offline   Reply With Quote
Old 12-06-2012, 09:53 AM   #784
Offthechart
Oddometer: 6
Seated a tubeless rear tyre with a spray can of deodorant, after I lubricated the beads with hand cream.
Offthechart is offline   Reply With Quote
Old 12-06-2012, 11:29 AM   #785
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,674
You know that you can do something similar just sticking a piece of hardwood dowel in the hole, then predrill and use a sheet metal screw. Even a branch of the right size if you are in the bush.Surprisingly strong repairs can be achieved that way.Turned out permanent on the rattly old Tecumseh on my old snowblower. And so are expanding metal or even nylon anchors for concrete/wood/drywall.With all due care and attention not to crack the cases.
Thanks for reminding me.....forgot that I was going to fill a hole with solder or lead and then screw a #12x 3/4 sheet metal screw or so in there with the torque wrench to see how much torque I could achieve before stripping.
Already done something similar to adapt top post batteries on cars to side post. Drilled/tapped and threaded into the posts, removed the center bolt on the side post terminals and bolted them on the top posts. Never failed or stripped at....from my wrist, 25-30 ft/lbs. Even rode the R100GS for a few weeks with a top post car battery mounted that way on the rear rack.
Have tools, will travel!
Old 12-11-2012, 06:57 PM   #786
buickid
Lets ride!
Oddometer: 310
I suppose silver solder could be used, with even stronger results!
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 12-12-2012, 10:00 AM   #787
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,674
Bonding them metals to aluminium can be a problem because of the aluminium oxides. Watch that....
http://www.youtube.com/watch?v=FmjdXKyDEWY
May be better....or not just using them cheap alu repair rods instead of solder. On my list for other purposes now why did I forget to buy them?Too far now.
The things you have to do sometimes when you are in the bush or live very close in my case.
Old 12-12-2012, 10:57 AM   #788
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,258
I'm not sure why, but I find this post slightly creepy, and compelling at the same time . . . . .
But thanks!
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 12-21-2012, 11:52 PM   #789
Tinker1980
Tinker1980's Avatar
Oddometer: 1,396
I must thank you all for a most interesting thread, I read it in it's entirety waiting for the laser to finish cutting at work today.
I will share a couple I have had to try on my own.
I used to drive a 1988 Mitsubishi Mighty Max. Those who are not familiar with those little trucks, they are more commonly labeled as a Dodge D50. They are not common trucks by a long shot. Mine had a 2.0 liter 8 valve 4G63 engine, which has the infuriating issue of bad fuel pump location. The mechanical fuel pump (Carbureted engine) is bolted to the side of the cylinder head. The intake manifold is also bolted to that cylinder head, same side as the fuel pump, leaving approximately no room to get the damned fuel pump out. Another bigger problem, was the fact that nobody had said fuel pump in stock, at least no auto parts stores had parts in stock - more on that later. One instance when the pump died, my roommate and I were far, far away from anything, having only the toolbox on the back of the truck, and it was either a 50 mile walk to civilization, or get creative and make the truck run. I had several feet of spare fuel line for reasons I cannot recall, and a few bungee cords, and a gallon gas can. I set the roommate to getting gas into the gas can (Older Japanese trucks have a drain plug in the gas tank) while I used the flashlight on my fancy Keyocera Rave cell phone to get the fuel line off the carb, and plug the ones from the fuel tank. (Why most cellphones have cameras, and not flashlights, is baffling to me. A flashlight is much more useful.) We fed a fuel line down into the gas can, attached the other end to the carb, and strapped the gas can to the roof of the truck - bent the back corner of the hood up a bit to get the hose in with the hood closed. We had to stop to fill the gas can a few times. After that, I put an electric fuel pump on the truck, and never had that problem again. I learned a bit later that to get engine parts for the truck, one didn't need to go to an auto parts store - you were better off going to a forklift shop. The Mitsu 4g63 engine is used in a few forklifts, such as the Clark GC25, a few Mitsubishi lifts, and smaller Caterpillar lifts.
With the KLR I had an issue related to the fuel petcock - the vacuum operated one. Local motorcycle shop didn't have one that would fit. Took the factory petcock apart, just to see what was inside to see what I could do with it. Ended up going to the local Industrial Supply Shop and getting some fuel-proof rubber from them. Cut a piece and replaced the vacuum diaphragm with the rubber, and it's not been an issue since.
Another favorite - the ignition coil started to give up the ghost on my Chevy truck. We would go about six miles, and the truck would shut down. 30 minutes later, it would run again like nothing was wrong. For a week I kept the coil in the freezer at home, put it in the truck to drive to work, and put it in the freezer at work.
Reading the stories posted here has made me think - most people cannot do these things. The wherewithal to see a problem, and think of a solution that involves only the things in arm's reach, is not a normal ability. I grew up in a family where if something broke, we would fix it - no matter if it was a toilet, doorknob, car, computer, radio, VCR, etc etc. If it could not be fixed, we tried anyway - what is there to lose?
Tinker1980 is offline   Reply With Quote
Old 12-22-2012, 06:07 AM   #790
luxlogs
luxlogs's Avatar
Oddometer: 299
What you are reffering too is the difference between a Mechanic and a Glorified Parts Changer.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline   Reply With Quote
Old 12-24-2012, 07:34 PM   #791
Tinker1980
Tinker1980's Avatar
Oddometer: 1,396
A trick I almost forgot about, that is really handy for repairing small plastic things temporarily. (I've used it for the wife's eyeglasses)
A tube of super glue, and a strip of an old T-shirt - cut a strip big enough to wrap it around the broken plastic part, and soak it though with super glue. The wrap it around said part. You end up with something similar to fiberglass when it dries.
Old 12-25-2012, 05:15 AM   #792
dmftoy1
dmftoy1's Avatar
Oddometer: 243
Used my girlfriends pantyhose to improvise a fan belt for my 62 Nash rambler American. On the plus side in not only got us home but got her partially undressed. (And the rambler was a station wagon where you could fold front seats back and rear seat back forward to have a perfectly flat surface front to back)
dmftoy1 is online now   Reply With Quote
Old 12-25-2012, 10:46 PM   #793
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Very interesting! I wonder if ripstop nylon would also work for that?
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 12-25-2012, 10:49 PM   #794
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
   That's an improvement to the old running-out-of-gas trick.
Old 12-28-2012, 10:09 AM   #795
JTT
JTT's Avatar
Oddometer: 1,530
Saw a neat trick the other day by a plumber. I had a leak in a 4" ABS drain pipe inside a wall (as a result of a "misdirected" recip ). Instead of cutting out the pipe, he took another piece of ABS and started sawing small strips off and collecting the shavings. Mixed the shavings with ABS glue on a board making a slurry (as the glue dissolves the ABS), then applied it like putty. Made me think of other applications using this technique.
JTT is offline   Reply With Quote
Times are GMT -7.   It's 04:17 PM.
