Old 12-03-2012, 11:35 AM   #8056
preppypyro
preppypyro's Avatar
Oddometer: 453
Thanks guys, thats sort of what I thought as well. Does pretty much the same thing as it would on a car rim. Wasnt sure how wide our rims were VS a smaller duke or whatever, so i also wasnt sure if they just threw a tad wider of a tire on our rims, and the rims on our bikes were the same as the smaller dukes and whatnot.
preppypyro screwed with this post 12-03-2012 at 11:46 AM
preppypyro is offline   Reply With Quote
Old 12-03-2012, 11:42 AM   #8057
Idle
Oddometer: 411
Cool2
I've worn out 2 distanzias in the 160/60-17 flavor. It is a softer supermoto compound in that size. I got about 2k miles out of this one.
IMO one of the reasons a supermoto wears out tires quickly is because of the engine braking a thumper has.
A little bit of pavement use on my 18" D606 showed typical wear on the leading edge of the knobs as you'd expect. But the back of the knobs was rounded off equally as much as the front. I hardly even use the rear brake so I know it's the engine braking that caused that specific wear. On a street tire I'd have never seen hard evidence of wear from engine braking.
Sorry, got sidetracked.
I'd think a distanzia 160 on a 5.5" rim would be fine. It is a heavy tire and it's wider than most 160's by a fair margin. It measured (iirc), 167mm mounted on a 5" Behr rim. That's pretty close to 170, a tire that surely fits a 5.5" rim. Lemme look on my photobucket for sidewall pic.
I took almost an 1/8" off the edges of this tire with a block plane and using dish soap for lube. I had serious clearance issues with the chain and swingarm. The pilot power 160 fit great with no modifications whatsoever. I didn't need a chain block with the pp's, had no chain rub at all, but it was mandatory with the distanzia. Did I mention it's a wide tire?
160/60-17 distanzia on a 5" rim. (with trimmed sidewall)
Hope that helps..
Idle is offline   Reply With Quote
Old 12-03-2012, 12:15 PM   #8058
angustoyou
Oddometer: 19
The standard tyres sizes are not numbers plucked out of the air.
Worst mistake I made was fitting some sticky rubber to a bike before my annual biking holiday at the Isle of Man TT races. My tyre size wasn't made in the proper sticky ones, so I went up a size. Slowed the steering at all speeds, and damn near spat me off (and I guy I was riding that section with) when it started into a nasty weave on Quarry bends. It was absolutely hopeless at anything over a ton, and pretty useless at anything under. Ruined the riding bit of the holiday for me.
Taught me a lesson, that's for sure. Hope it helps someone else.
angustoyou is offline   Reply With Quote
Old 12-04-2012, 05:16 AM   #8059
doctor_big
It hurts when I fall down
Oddometer: 587
Just squeaked 260km / 156mi out of a tank. 36km of that was with the fuel light on. The bike then took 16l of gas, and the capacity is 17.5l so that's pretty damn good range. The most I've got out of a tank. Need I say that I'm running stock gearing?
Jason
Better to die on your feet than live on your knees.
doctor_big is online now   Reply With Quote
Old 12-04-2012, 05:19 PM   #8060
nattyMo
Oddometer: 562
Not to many that offer bars in Carbon Fiber. Two mfg's that I know of. If you want an alloy bar you sure do have several more choices.
Originally Posted by corndog67 View Post
You guys are kinda trapping yourselves into a couple different brands of hanebars, when in reality there are many, many more brands. ProTaper, Answer, Rental, just get a dirt bike magazine and check them out, probably at least 50 different bends for your viewing pleasure.
Just saying, don't limit your choices.
nattyMo is offline   Reply With Quote
Old 12-05-2012, 08:11 AM   #8061
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 239
Clutch Pull
Quick question: Is increased clutch pull stiffness after riding a while a sign that the Magura blood needs replacing or would it be something else?
-Buck
BuckMoto is offline   Reply With Quote
Old 12-05-2012, 12:21 PM   #8062
gallinastrips
gallinastrips's Avatar
Oddometer: 575
Loe Vince pipe question. Just put new to me Leo Vince cans and Y pipe on, voltage regulator and shock spring are getting really hot to the touch! Anyone have problems with parts getting fried from to hot of aftermarket Y pipe? Stock has heat shield but Leo does not
RIDE ON
gallinastrips is offline   Reply With Quote
Old 12-05-2012, 01:56 PM   #8063
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
Know of two guys running Leo stuff on SM's and others with unshielded pipes at that point, but haven't heard of RegRec getting smoked. Weld a nut onto the pipe, at a point where you could bolt up the stock shield again. Keeps ya from thinking about the problem, even if it turns out not to be one...
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good!
justin@giantloopmoto.com
www.giantloopmoto.com
snowhawk jockey screwed with this post 12-05-2012 at 02:28 PM
snowhawk jockey is offline   Reply With Quote
Old 12-05-2012, 02:27 PM   #8064
snowhawk jockey
Slack Jaw Gaper
Oddometer: 744
Curious to see what the word is on this question! My understanding is that it is the opposite feeling, clutch going soft, but am here to learn! I was thinking I had some basket wear, but maybe it is just time for fresh blood?
Old 12-05-2012, 03:05 PM   #8065
wpbarlow OP
Oddometer: 7,885
Originally Posted by snowhawk jockey View Post
Curious to see what the word is on this question! My understanding is that it is the opposite feeling, clutch going soft, ...
That's what happened to me when mine failed. Logical when you think about it; fluid escaping past the oring.
Walter Barlow
wpbarlow is online now   Reply With Quote
Old 12-05-2012, 06:01 PM   #8066
Thumper996
Thumper996's Avatar
Oddometer: 503
I found an acceptable o-ring replacement at Ace Hardware and ran it for several hundred miles with no issue until i upgraded the slave cylinder. O-ring was just a few dollars and quick fix.
Thumper996 is offline   Reply With Quote
Old 12-06-2012, 11:33 AM   #8067
nattyMo
Oddometer: 562
I've been through 2 VR's. Upgraded to a Rick's Mosfet VR and moved it to the LH side of the airbox.
http://ricksmotorsportelectrics.com/...dLVE05NTBTTVI=
Old 12-06-2012, 11:37 AM   #8068
nattyMo
Oddometer: 562
May be time for a look at the clutch slave. You can simply unbolt it from the side of the engine without draining it to check for leaks. When's the last time you changed the fluid? The slave may be gummed up causing the increase in effort.
Old 12-06-2012, 12:24 PM   #8069
900rider
Oddometer: 508
God damn your bike is clean
900rider is offline   Reply With Quote
Old 12-06-2012, 01:41 PM   #8070
angustoyou
Oddometer: 19
Takes about 10 minutes to flush new oil through the clutch. Try it and see. I change mine every oil change, while the oils draining out.
Times are GMT -7.   It's 02:28 AM.
