12-06-2012, 08:49 AM
#3901 |
Avoiding the Skid-Demon
Oddometer: 6,734
Two more cents...
As a knifemaker who has used steel from several different suppliers, not all steels are created equal. You can get the same grade steel from two different sources, and there can be significant differences in the chemistry and initial internal structure of the material. In a backyard shop, even though I feel comfortable heat treating 1095, 1095 from one place needs to be handled differently than 1095 from another supplier. In my experience, all steels suffer this inconsistency, even though they have the same grade label. To think that all 440C is exactly the same, all over the world, is foolish - and why I suggest that it's not an ideal material for knives. But people like shiny and no rust, so that's what they get, and if the shop producing blades isn't paying very close attention to what they're doing, they can mess it up with no visual signal that they have.
Chris, Proprietor of The Tidewater Forge Hot iron is my passion. Fire is my mistress. Let's dance. |
12-06-2012, 08:53 AM
#3902 | |
Oddometer: 6,809
Back in Iowa! I like my music like I like my women. Loud, angry and with bagpipes! From Scottie Boy "If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle." |
12-06-2012, 09:16 AM
#3903 | |
Oddometer: 696
12-06-2012, 10:46 AM
#3904 |
Oddometer: 234
I have the same CRKT knife. Use it everyday, no complaints from me.
"Life is hard! It's even harder when you're stupid!" John Wayne Not all who wander are lost! 1982 GL1100 Standard 1980 GS550 |
12-06-2012, 11:26 AM
#3905 |
Oddometer: 6,734
Cost to the end consumer has nothing to do with it - it's all about how the mill did the run, and whether the supplier had anything to do with it as well.
One thing people don't realize is that an awful lot of steel comes from recycled material, so your dad's Buick is in that billet as well, and while most of the really rotten stuff burns off, I've seen streaks of copper in a bar of steel before. If they blend all the ingredients as they're supposed to, according to the recipe, they can call it by the spec's name. I'm sure there are tolerances for chemistry - so it's not "exactly" 0.95% carbon by weight, it's more like 0.86-1.02% as an acceptable range. Chemistry notwithstanding, the cooling rates from liquid to billet, the rate at which carbon was reduced, the manner in which alloying elements were introduced, and the process by which the steel was reduced to the form you get it can all play important roles in the character of the steel you end up with. It's actually a whole lot like baking, really. 2 chefs with the exact same ingredients, following the same recipe, but sourced from different stores and using their own techniques, will make two very different muffins.
12-06-2012, 02:04 PM
#3906 | |
Enjoying my last V8
Oddometer: 5,319
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
12-06-2012, 02:16 PM
#3907 | |
Enjoying my last V8
Oddometer: 5,319
Why don't you use tool steel flats? The quality is very good and chemistry is consistant. For what a custom knife maker charges for a knife the additional cost of tool steel would not be noticed. O-1 or O-2? On thing to know about the variability in the chemistry of steel is a steel manfacturing difficulity know as segragation. As the cast ingot cools the alloy elements group together in different parts of the ingot. When the ingort is rolled into , flats for example and in knife sizes there will be alot of feet of flat, there will be considerable varance in chemistry from the flats at the begianing of the rolling to the middle and at the end of the rolling.
12-06-2012, 04:51 PM
#3908 |
Stroppy.
Oddometer: 24,375
are you here for the ten minute argument or the full half hour?
. . "Discourage self-help, and loyal subjects become the slaves of ruffians." - A. V. Dicey "The ultimate result of shielding men from the effects of folly is to fill the world with fools." - Herbert Spencer "Socialist governments traditionally do make a financial mess. They always run out of other people's money." - Margaret Thatcher |
12-06-2012, 06:11 PM
#3909 |
Enjoying my last V8
Oddometer: 5,319
Are you Presiding High Council?
I'm just here to provide comment and info Your Honor.
12-06-2012, 06:40 PM
#3910 | |
Oddometer: 6,734
My knife steels of choice are primarily 1095, 1084, W1 and W2, occasionally O1, and sometimes some 15n20. I have also used 52100, 5160, I have a hunk of O6 for tool making, and some A2 I have yet to decide what to do with. for my historical work I end up making my own steels, either from carburized wrought iron, or smelted material direct from ore in most cases. I'm experimenting with recycling material into an orishigane-type product using an Aristotle furnace, and also have played around with high-nickel iron meteorite (campo). My personal experience with variable product under a single spec is 1095. The stuff I get from Admiral steel is not annealed, and has massive alloy banding present in almost every purchase. I have changed suppliers to Aldo Bruno (the New Jersey Steel Baron) and his material is clean, well-annealed, and is ready to work, with no additional thermal cycling needed before it's "ready" for knife making. Even then, I know people who got a batch from him, and found inclusions, banding, or other flaws, and the product was replaced immediately - so his customer service carries some weight, but my main decision to use him comes from the nature of the steel as delivered, which is excellent for my purposes and techniques. I don't pretend to know about everything that goes on in a steel mill, but I know the end product can be rather varied depending on the quality controls in place, and the method by which the final bars are made.
12-06-2012, 06:41 PM
#3911 |
Stroppy.
Oddometer: 24,375
No you aren't...
12-06-2012, 06:42 PM
#3912 |
Traveler
Oddometer: 4,014
Oh cool...knife fight.
b
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
12-06-2012, 07:14 PM
#3913 | |
Enjoying my last V8
Oddometer: 5,319
When I read you post it seemed you were having a bad day with your supplier. Bear in mind you are buying a very plain, low end product, 1095. Steel is a very difficult thing to make. Even the best made steel can fail. If you were buying a mills top of the line product, or the majority of its capicity, you may get a better product and more attention when a bad lot is found. Steel mills also hold all Aces. As a manufacturer you have no choice but to buy what they make, good or bad. Although there are mountian high piles of specifications most count on in house QA to keep good raw material in their products and simply get creidt less scrap value from the mills for the rejects. I guess you use 1095 for its vintage authentic quality? It is of interest to me you make your own steels. I have made some knifes and posted photos here but my strong suit is heat treatment. I hope to be of some assistance to you sometime.
12-06-2012, 07:15 PM
#3914 |
Enjoying my last V8
Oddometer: 5,319
12-06-2012, 07:35 PM
#3915 | |
Crowbar of Embrayage
Oddometer: 4,658
You just really are one.
People say friends don't destroy one another . . . what do they know about friends? |
| Thread Tools | |
