Old 12-03-2012, 03:01 PM   #16
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,230
Originally Posted by Pablo83 View Post
Full plans to be announced Christmas day. I'll give you a hint: the bike's a pre-1975 Sportster.
Luke is offline   Reply With Quote
Old 12-07-2012, 02:17 PM   #17
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
At some point in the bike's history a bolt rubbed on the rear drum cover and put a giant gouge in it. I thought I should go ahead and take care of this.
Cleaned and welded:
And sanded back down (not perfect, but this bike's not going to be perfect)
Pablo83 is offline   Reply With Quote
Old 12-07-2012, 02:27 PM   #18
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
I've also started to tear into the primary to try and stop an oil leak (pointless endeavor on an old Harley, I know) and see if anything else needs to be fixed.
I called the dealership to get new clutch seals. The guy took about 20 minutes to tell me most of the seals for this bike are discontinued. He can get one of them, but he would have to charge me for 10 of them because that's the minimum quantity he can order them in and he won't be able to sell the rest. I'm guessing I won't be relying on the dealership much for this project.
Old 12-07-2012, 02:56 PM   #19
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 1,300
XR750 replica?
dbarale is offline   Reply With Quote
Old 12-11-2012, 10:55 AM   #20
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
The bike's been starting well, but I haven't been taking it out on long rides, so I thought I wouldn't hurt to put it on a trickle charger. After two days the battery still wasn't at full charge and it sounded like the acid in the battery was boiling so I took the charger off. It was just a little battery tender like this:
Can anyone tell me what's going on with my battery?
Old 12-12-2012, 04:56 PM   #21
lilsmokey
lilsmokey's Avatar
Oddometer: 335
well thats...... Classy
I ride a bullet. A 2 wheeled, multiple-explosion powered machine with enough moving parts to remove entire fingers. Surfaces hot enough to cook flesh. It propels me at neck-breaking, bone-snapping flesh-tearing speeds, over and trough obstacle's I can only see as blurs. Its a sport that kills the careless, maims the best, and spits at the concept of mercy.
lilsmokey is offline   Reply With Quote
Old 12-14-2012, 02:43 PM   #22
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
-- i cant wait to see what this will turn into!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 12-15-2012, 12:10 PM   #23
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
In current form...
Can't wait to see where it goes without that paint and springer nonesense.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-24-2012, 02:08 PM   #24
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,825
Originally Posted by Hughlysses View Post
Another dual-sport Sportster project?
Sort of.
Originally Posted by Luke View Post
Yes
Originally Posted by dbarale View Post
XR750 replica?
And yes.
I guess I made that one too easy. The pre-75 Sportsters had a right side shifter which is perfect for flat track. I've already got conventional forks and a 19" front rim on the way.
Old 12-25-2012, 12:22 PM   #25
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,230
Ohhhhh yeaaaah!!!!
Old 02-22-2013, 09:07 PM   #26
villageidiot
Oddometer: 1,985
For parts, check out sporty parts in Fullerton California. All they do is sportster parts. From all eras.
villageidiot is offline   Reply With Quote
Old 02-22-2013, 09:19 PM   #27
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,219
Back in the good old days, on Brit bikes, we would use silk thread on the primary with no gasket. I would stop the most stubborn oil leaks.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Times are GMT -7.   It's 03:12 AM.
