Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 11-14-2012, 06:01 PM   #196
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,370
Originally Posted by SafetyThird View Post
Yeah, if you're willing to come out past La Honda.
Dang and I'm working out there off Stage Rd. too. Thanks for the offer though.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 12-08-2012, 09:52 AM   #197
vtwin OP
vtwin's Avatar
Oddometer: 7,370
I splurged on the Willys.
To replace this piece of crap.
I'll be getting rid of those brackets and the new one is supposed to fit in the stock location. I would have preferred a stock brass radiator, but those were double the price of the one I got. I may paint it black as I'm not really into bling, too lazy to clean. Hey, this is a work truck.
I do have to tap into the vast experience of this forum. I need to adapt the lower hose with a 1 1/2" diameter to the 1 3/4" id. Looking on ebay, they do have a few awkward looking items. Anyone have any ideas?
Monroe.
unknown
Old 12-08-2012, 09:57 AM   #198
zilla
zilla's Avatar
Oddometer: 1,617
My Dad had a 60 Willys Pickup with a GMC 305 V6 swapped in it, and he could never keep that thing cool in the summer.
" The lesser of two evils is still evil"
zilla is offline   Reply With Quote
Old 12-08-2012, 10:08 AM   #199
vtwin OP
vtwin's Avatar
Oddometer: 7,370
I'm adding a 3 row and the Willys is only spec'd for a 2 row, so hoping I don't have problem overheating. I've had british cars in the past and they seemed like they were made to overheat in our summer weather.
Monroe.
unknown
Old 12-08-2012, 10:21 AM   #200
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,535
Are you going up from 1 1/2" to 1 3/4"? If so just getting the hose nice and warm and a little Vaseline.
Had to do that when I ghettoed a cheapo rad on my old GMC van.
Have tools, will travel!
Old 12-08-2012, 10:25 AM   #201
vtwin OP
vtwin's Avatar
Oddometer: 7,370
That might work. Yes, the hose is a 1 1/2" and the lower outlet is 1 3/4". Going to be changing hoses anyway, but since they have part numbers and molded, i thought I'd stick with them. Always hated flexible hoses.
Monroe.
unknown
Old 12-08-2012, 11:02 AM   #202
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,163
http://sandiego.craigslist.org/nsd/cto/3456032222.html
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 12-08-2012, 11:43 AM   #203
AKjeff
AKjeff's Avatar
Oddometer: 5,137
A 1 1/2" to 1 3/4" exhaust pipe reducer, with suitable radiator hose clamped on either end would work.
Cut the end off the stock radiator hose and find a 1 3/4" hose with the right bend in it for the end.
Or see if a radiator shop cad weld an aluminum reducer on it.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 12-08-2012, 12:07 PM   #204
vtwin OP
vtwin's Avatar
Oddometer: 7,370
Yep, been looking into getting a reducer of some sort and a short piece of hose. I asked the radiator people about changing the outlet and they told me it's cheaper to find a hose that works instead. I'll install the radiator first and try to mock up some hoses and go down to the local parts guys and try to match them up.
Monroe.
unknown
Old 01-01-2013, 01:16 PM   #205
vtwin OP
vtwin's Avatar
Oddometer: 7,370
Well, seeing as how I had a long weekend, I should get something done.
Pulling that radiator today since I'm not planning on using the truck in the near future.
P.O. never even installed lower bolts for the radiator.
Nasty rusty water.
It's out, cleaning up the paint over spray from the brown.
Used a little water and sponge sanding block I had handy.
It's temped in to check out the hoses. Upper hose fits really well, but the lower hose is 1/4" too small in diameter and the wrong angle.
Someday, the truck will get repainted in the proper Glenwood Green, even if I have to roll the paint on. The county is pretty strict about spray painting in a residential area.
Anybody need a radiator that is needing repair?
Monroe.
unknown
Old 01-09-2013, 09:22 PM   #206
vtwin OP
vtwin's Avatar
Oddometer: 7,370
Someone passed this on to a mailing list I'm on. Very cool.
http://papercruiser.com/?page_id=4
Monroe.
unknown
Old 01-09-2013, 09:27 PM   #207
vtwin OP
vtwin's Avatar
Oddometer: 7,370
Boy, was I wrong about the size of the outlet, it's a 1-13/16" I got a flex hose (I hate those, but what are you going to do?) 1-3/4" and it was still too small. So I took the shipping cap from that outlet and brought it down to the O'Reilly's and matched it up to the 1-13/16" one. Had to special order that size reduced to 1-1/2". Now to just find a joining hose piece that large.
I did call a radiator shop and they told me it would cost around $150 to put on a reducer. I'll try the exhaust piece first.
Monroe.
unknown
Old 01-10-2013, 09:23 AM   #208
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,554
I had a similar problem. I used a stock rad hose with the fancy bend. It reduces by itself to go to the engine. I just put a straight coupling onto it with some hose clamps.
That was in order to run 2 radiators in series. I had room for the extra hose. Not sure you will?
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 01-10-2013, 11:16 AM   #209
SafetyThird
SafetyThird's Avatar
Oddometer: 318
I should've bought this back when they didn't know better and had it listed for $9,999.
http://www.autotraderclassics.com/cl...tionId=1008552
It's going up faster than my 401k
SafetyThird is offline   Reply With Quote
Old 01-10-2013, 09:22 PM   #210
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,554
I'd love to have one as well.
I'm playing with a big Toyota right now. No resources for another truck.
When I do move to another project I imagine it'll be a Mercedes. Sadly, I may never have a Willys. :(
Thread Tools
Times are GMT -7.   It's 06:15 AM.
