Old 11-28-2012, 02:48 PM   #3091
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,418
Originally Posted by Cruz View Post
Did you just use your old cover and their foam on your seat base?
Yes, it is the stock cover but on top of their foam and shape. There was some material added underneath I believe to make it work.
Top quality job and it transformed the ride for me over 500 miles of desert
I sent in the seat and they did the whole thing
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 11-28-2012, 03:26 PM   #3092
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,243
The stickers and colouring of the 2012 models are still wayyyyyy better than the older ones. (IMHO)
FE450.
XT660R
Blakduk is online now   Reply With Quote
Old 12-01-2012, 04:32 PM   #3093
Blakduk
Blakduk's Avatar
Oddometer: 1,243
Yep, sorry you didn't get the 2012 in the US.
Anyway a serious question. I was told to put anti-seize on the subframe bolts under the seat that connect into the fuel tank. (or maybe it was the screws that hold the radiator shrouds on?)
Anyway last time I looked about 3 were loose. I tightened them up of course. What's the thinking here, it is better to occasionally lose a bolt than have them seize in the tank and then spin out the plastic uselessly.
(......I think I know the answer to this question D'oh, just wondering what the forum thinks)
FE450.
XT660R
Old 12-01-2012, 04:45 PM   #3094
rensho
Oddometer: 178
Your reasoning is correct. I haven't touched mine, nor have had the tank off, but will soon. Will put anti-seize on all those bolts.
rensho is offline   Reply With Quote
Old 12-02-2012, 08:27 AM   #3095
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Just for fun (and to know for certain) I weighed my bike just now.
2010 FX450.
Stock gas tank - full of fuel.
Sicass dualsport lighting kit w/ horn.
Tail bag on bike w/ tools.
Seat Concepts seat.
Ohlins steering damper.
Garmin 60CS GPS on Ram mount.
Weights:
Front - 130 lbs. (59 kg.)
Rear - 154 lbs. (70 kg.)
TOTAL -- 284 lbs. (129 kg.)
Lazy Traveler
SRG is offline   Reply With Quote
Old 12-02-2012, 09:32 AM   #3096
frostyuk
frostyuk's Avatar
Oddometer: 274
srm2 driving light
Wired up my srm2 driving light, i've mounted on a bracket connected to the side of the hdb top clamp, only problem is i cant bend it far enough forward to get it to a point where it wouldnt blind oncoming vehicles,, i've asked paul at hdb to make me up a headlight relocation kit so i can move the mask forward and drop the computer to the lower mounting point on the top clamp and then rotate the light farther down, short term i'll have to raise the light higher with a taller bracket or a spacer, alternatively i might have to get fork clamp to mount it on just below the top triple clamp
sorry about the pic quality again
IMG00186-20121201-1446
here's with the comp mounted lower
IMG00190-20121201-1502
cam is too poor to take pics of the light it gives out
frostyuk is offline   Reply With Quote
Old 12-02-2012, 11:14 AM   #3097
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,222
2010 FX450.
Seat Concepts seat.
Weights:
Sounds about right. One of the moto mags did a comparo on KTM vs FE Bergs and their measured true weight for stock Berg FE offroad bike, full oil & fuel was 271lbs. The 390 thru the 570 only vary by a pound or two. The 50-state 570S is no doubt heavier with the extra smog stuff. Add a full 70degree tank and it will be close to 300lbs.
cyborg is offline   Reply With Quote
Old 12-02-2012, 09:07 PM   #3098
Blakduk
Blakduk's Avatar
Oddometer: 1,243
70 Degree Racing (Dale Covington) advised today that the subframe tanks have arrived.
FE450.
XT660R
Old 12-02-2012, 09:28 PM   #3099
cyborg
cyborg's Avatar
Oddometer: 5,222
Yep, right on his front page
http://www.70degreeracing.com/
"UPDATE: 12-03-12
I picked up the first small batch of tanks from the molder last Friday.
We made a design change on the tank for quality control. This change will require us to include two small spacers for the rear fender mounting screws on the back end of the tank. Once we have the spacers made we will be able to start shipping tanks!
http://www.husaberg.org/forum/viewto...135507#p135507
Dale E Covington"
Old 12-02-2012, 10:09 PM   #3100
BogeyMan
BogeyMan's Avatar
Oddometer: 449
Talking
"UPDATE: 12-03-12
Dale E Covington"
And, in that thread there's this tantalizing picture:
Looks like they're a lot lighter in color than the originals. Personally, I like that.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 12-03-2012, 12:24 AM   #3101
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,084
Originally Posted by scorpion View Post
Hey Scorpion, any chance to can post a photo of the underneath side of your seat? Would like to get an idea how much extra material they needed to add.
Anyone have a Seat Concepts cover, and which would be the closest to the feel of the original cover?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-03-2012, 09:05 AM   #3102
Baja Dad
Baja Dad's Avatar
Oddometer: 2,012
I do !!!
I will post a pic later today !!!!
I love it !!!!!!!!!!!!!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 12-03-2012, 10:36 AM   #3103
BogeyMan
BogeyMan's Avatar
Oddometer: 449
Question Intake fart?
Here's a [hopefully] quick question for the collected wisdom that is this thread...
My FE570 has been running a little odd lately. Starts fine (rarely, if ever, needs the choke - even on colder mornings), but then it'll idle for a bit, and I'll get a loud fart into the intake (with a nice puff too, when the seat's off) and it'll cut-out. It'll do this several times until it's really heated up. Sometimes subsequent starts take a few seconds on the magic button.
Other than that, everything runs fine.
I suspect it's time for a valve check/adjust... but don't know what slightly out-of-spec valves might cause this behavior (and I really don't know if they are out of spec, as I haven't checked yet).
Any other suggestions?
Old 12-03-2012, 01:01 PM   #3104
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,207
I have the Seat Concepts low seat on my 570 and the OEM cover stretched easily to cover it with no additional material needed. Looks great, but the low SC seat is pretty thin as far as padding goes, I definitely feel the seat pan on hard hits. I just sent another OEM seat off to Renazco to have true long distance seat made, I will report on the difference after Christmas when I get the Renazco back.
On the fuel tank post seeing that made my day after a frustrating day of Efing up my R1200GSA trying to do a simple oil change.. I really shouldnt be allowed to handle tools
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 12-08-2012, 02:19 PM   #3105
Sproat Sport
Oddometer: 64
Continuing on with my display lights problem (high beam, low fuel and signal)....I checked the little bulbs and they are fine. so...don't know what to do now.
Sproat Sport is offline   Reply With Quote
Times are GMT -7.   It's 04:45 PM.
