Old 12-08-2012, 03:45 PM   #1
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,865
Crimping wire
I am trying to practice crimping two wires. I have purchased uninsulated 16 gauge butt splice and i just happen to have this tool lying around.
Is there anything wrong with using this tool to crimp? There are some nice crimp tools on ebay, but I need this for a project, so ordering something additional may set me back a bit. I may be getting these tomorrow, because they may work better...
Learn to ride. Ride to learn.
a1fa screwed with this post 12-08-2012 at 03:55 PM
a1fa is online now   Reply With Quote
Old 12-08-2012, 03:54 PM   #2
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 559
That's pretty much what you want for occasional use.
Yamarocket630 is offline   Reply With Quote
Old 12-08-2012, 04:29 PM   #3
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,448
Yea, I have a similar tool. That's what you use. Although, much like yourself, I think something 'beefier' is in order. Plus, I just don't like the crimp - prefer to solder. But, most bike/auto electrical connectors are made for crimping and not so easy to solder (which, btw, only aggravates me when I solder them). Good luck!
Stan_R80/7 screwed with this post 12-08-2012 at 04:37 PM
Stan_R80/7 is offline   Reply With Quote
Old 12-08-2012, 05:56 PM   #4
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,741
The first crimper is *adequate*, crimpers of that type tend to deflect before they make a good crimp. They're good in a pinch, but I wouldn't use one if I didn't have to.
The second type is a far better version of the first, the frame is stout enough that it isn't going to bend and twist before the connection is made. If you're on a budget and need a crimper for the shop, get that type.
If you have the $$ to spend, a ratcheting type crimper is the way to go. Expect to spend ~$60 on the tool and another $40 for each set of dies. In return, it will create a connection that is stronger than the wire itself.
As far as soldering crimped connections goes, it is an allowed practice in ANSI J-STD 001, the guideline most industries use for controlling soldered connections. If you feel you must back up a crimped connection with solder, the correct sequence is to crimp first and then solder. Going the other way around can damage the crimping dies.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 12-08-2012, 05:59 PM   #5
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,865
Practice makes perfect...
The first 3 where made with the first tool. The first one was a disaster, and then I got much better at using it... but then I went to Lowes and picked up the second tool... and its amazing!
Old 12-08-2012, 06:34 PM   #6
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
Amazing what the right tool for the job will do!!
That first tool is a wire stripper and that's about it.
Old 12-08-2012, 06:39 PM   #7
buickid
Lets ride!
Oddometer: 310
Poor wire stripper at that... Harbor Freight's ratcheting crimper (SKU 97420) is pretty good, as is their wire stripper (SKU 98410).
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 12-08-2012, 06:45 PM   #8
GordonH
Oddometer: 82
I agree. No one should crimp anything with the first one. They're probably the reason dry crimps got a bad name. When they're done with the second one, and then heat shrink is applied,(remember to put the tubing over the wire before you crimp) It's almost as good as a soldered connection.
Gordon
GordonH is offline   Reply With Quote
Old 12-08-2012, 06:49 PM   #9
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,865
I was just about the say -- it sucks at stripping as much as it sucks at cutting and crimping. I'll be doing a lot of crimping over at the "Great Damn Van" thread. Click Here!
Old 12-08-2012, 06:57 PM   #10
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
Don't forget that you can buy the quality stuff online these days.
http://www.matcotools.com/catalog/pr...CRIMPING-TOOL/
Old 12-08-2012, 09:46 PM   #11
Beezer
Oddometer: 5,836
the crimper has to match the connector
the first tool looks like an Amp Superchamp knock off. the real Amp tool used on Amp PIDG terminals works fine. other combinations... mebby not.
the second tool is a Stakon type. maybe more forgiving. it wil also work better with the parts it was designed to be used with
PS with the wrong tool you can be loose, or over crimp the wire and make the connection brittle
Beezer is offline   Reply With Quote
Old 12-08-2012, 09:55 PM   #12
Bad Daddy
Oddometer: 103
I have some tools from Ancor Wire, and FTZ. They have excellent connectors as well as tinned AWG wire.
Double crimp connectors, Cool-Seal anaerobic crimps, etc. some are even s/s, and made for marine environment.
Been using them for years. I use fine stranded pre-tinned wire, and tinned connectors. Combined with shrink tubing, it is a very durable connection.
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 12-09-2012, 04:38 AM   #13
machinebuilder
Oddometer: 1,127
the difference is the part of the first tool you are using.
if you had used the part for NON insulated (below the hinge) it would worked better.
I crimp a lot of uninsulated fork lugs and I use the second type,
But match the lug to the wire size,
IF you have to make do with a larger lug, fold the wire in 2 before puting the lug on and crimping. (I also work with 24-26awg at times)
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is online now   Reply With Quote
Old 12-09-2012, 07:51 AM   #14
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,315
A1FA,
I hate to sound like a buzzkill, but both these guys are pretty much spot on and it would benefit you to understand what they are saying.
If someone were to post that they have a full set of SAE wrenches so they did not need buy a metric set because they could find something to fit most of the time, it would be obvious to most that there is a bit of improperness in that.
It is the same with electrical connectors and wiring. You have both insulated and uninsulated and they are two different animals, about the only thing common with them is they need to be sized properly to the wire.
As you have found out, if you use an uninsulated butt splice connector that is too large for the wire, and then try to crimp it about the only thing that happens is the connector smashes flat and then the wire slips out. Had the connector been sized properly, or even if the wire had been made bigger by folding it back on itself once or twice, you could have then crimped it with the tool and it would have held. The main issue in doing it like you did IMHO is that you have to squeeze it pretty firmly and as Beezer points out, it smashes the wires and they get work hardened and brittle and will often break right there at some inconvenient point in the future).
Additionally, if you use the "non insulated" crimp position with insulated terminals, it will cut the plastic with a firm squeeze, and if it is a heat shrink sealable connector it will cut the insulation as soon as it looks at it, then when you apply heat to seal it the little cut opens up wide and you have to re-do the entire connector.
Anyway, it sounds like you now have both styles so good on you and that should keep you going for many years. Ratcheting ones are great but if you use them improperly they won't give you a good crimp either.
I suspect if you went to a website for tools such as Klein or Greenlee, they would probably have instructions on how to use their version of the tools you have and it would be helpful for you to read those.
Apologies if this sounds like criticism, because it is not intended as such but it is attention to details such as these that enables one to eventually become a master of his craft, otherwise one never really moves past just being a hack.
Best wishes,
GM
GreaseMonkey is offline   Reply With Quote
Old 12-09-2012, 09:02 AM   #15
t6pilot
Oddometer: 557
When ever possible solder connection, then double heat shrink tubing. If you going to crimp fitting get a high quality crimper
t6pilot is offline   Reply With Quote
Times are GMT -7.   It's 05:39 AM.
