Thread Tools Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 12-09-2012, 07:48 AM   #1
bmwktmbill OP
Traveler
Oddometer: 5,142
Turning a Blown out RV into a Global Expedition Vehicle(GXV)
CONCEPT AND PHILOSOPHY
We haven't the money, so we've got to think.
— Sir Ernest Rutherford
"Keep it simple stupid."
Kelly Johnson(http://en.wikipedia.org/wiki/KISS_principle)
Occam's Razor(http://en.wikipedia.org/wiki/Occam%27s_razor).
"Pluralitas non est ponenda sine necessitate", i.e., "Plurality is not to be posited without necessity
1974 Minnie Winnie
Engine work is done(360 Dodge engine). Resealed the exhaust manifolds, rebuilt the carb, cleaned and degreased everything, greased the chassis and checked dif and trans(no major leaks). Rebuilt the battery box.
As of yesterday the engine starts(20 deg F.)
Inside is stripped except for table/bed.
Frikkin cold here in northern Wisconsin now. Next step is to rebuild the back wall next and install a wood heater.
The platform in back will remain and morph into a motorcycle hauler and patio.
The door will be reinstalled and a window will be added to the back wall(hopefully), tail lights, propane tank, spare tire on the deck.
Honestly guys I don't know what I am doing so any ideas are appreciated.
All I think about is riding my mc in Arizona this Spring.
I tore out the propane 3 burner range, propane Frig, sink and the shitter. The gray water tank remains and I still have the water tank and a 12V pump. I figured solar for lights and battery/computer/cell etc.
With a deep cycle battery maybe I can pump water to the sink?
Ice cooler in placeof the frig(?) and reinstall the stove for heat and cooking plus a small wood burner for heat. I saved the sink and hope to drain it to the tank so I can legally camp on BLM land out west.
I have contacted a couple of urethane foamers and they will spray the inside when I am ready for little money.
I am into the Winnie for $700 but it has all new tires. I am hoping to keep costs under a thousand bucks. Thinking wood heat, gravity and solar are my friends(and a little propane).
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 12-09-2012 at 08:54 AM
bmwktmbill is online now   Reply With Quote
Old 12-09-2012, 07:52 AM   #2
perterra
perterra's Avatar
Oddometer: 7,400
Subscribed, this ought to be interesting.
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 12-09-2012, 08:24 AM   #3
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,658
And you win!.....a Winnebago!
You are too far, someone just gave me a very nice (and very small) wood stove from a boat all SS, and I am debating installing it in my shop or not. If you have the room, you can DIY pretty nice woodstoves out of an old BBQ tank. Someone even sells them out here for $75.00 or so.
You probably don't need the 3 burner propane stove, a two burners would be enough. I have a couple of them also. Lousy for heating up the space and can even be dangerous. They also create too much moisture inside. There is a little trick to help removing the moisture....a large clay plant pot inverted over the burner. Works well but remember heating with open propane flames.....NOT SAFE, don't fall asleep.
Have tools, will travel!
Old 12-09-2012, 08:44 AM   #4
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
So, you're making a toy hauler, right? You might want to take some time and study plans plans for them to learn how others have worked it out.
The challenge with working in the cold, besides the discomfort, is getting glues and caulk to cure and paint to dry properly, as you're no doubt learning.
Keep us posted.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 12-09-2012, 08:58 AM   #5
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,427
Since you lopped off the back section, make it into a porch that doubles as motorcycle stowage. You can then kick back on your porch when your done riding for the day.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 12-09-2012, 11:49 AM   #6
Speedo66
Transient
Oddometer: 6,777
Here's a link with instructions to make a wood stove from a propane tank:
http://www.freewoodheat.110mb.com/bu...our%20own.html
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 12-09-2012, 12:35 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,658
Looks like that but made with a 20lbs tank. They were selling them as an "emergency" stove so they did have a flattop to warm up foods or keep the kettle warm.
Something like this....? Smaller than a propane tank. Was cheap to me and my friends have a similar one in their camper van. Cozy...!
Install stove first and use Winnie as the shop. Keep warm and burn the scraps at the same time.
Outside air supply for any wood stove in confined spaces!
Old 12-09-2012, 01:27 PM   #8
Zman1
Zman1's Avatar
Oddometer: 169
Looks like a cool project! I applaud your ingenuity. I would not mind having something like that old Minnie to go camping in.
I do have a question though. Why not leave it the way it was and pull a trailer with it? Was there leaking roof issues? Just wondering.
Have fun with the build!!
Ride safe and God Bless!!!!
Zman1 is offline   Reply With Quote
Old 12-09-2012, 04:29 PM   #9
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,076
RustySpokes is online now   Reply With Quote
Old 12-09-2012, 04:36 PM   #10
bmwktmbill OP
Traveler
Oddometer: 5,142
Hi everyone,
Thanks for all the encouragement. My plan is to leave the back deck on the rig for a mc hauling platform but I will build a bumper/trailer hitch/spare tire carrier as well. I need to fire up the torch and welder for some quick mods to what was.
I plan to leave the rig out west somewhere and return home by motorcycle at the beginning of next summer. The fuel costs of going back and forth in the RV would be hard on my fun money. I have vehicles(Honda CRV) that will get better mpg pulling my trailer.
All plans are easily changed.
For propane heat and cooking the 3 burner stove is a range and has an oven. I was hoping I could use that as a heat source and make a pizza at the same time.
The wood stove is a must for me and it would keep the coffee warm too. I heat my house with wood so I get that mostly.
I'd like something with a 16-18" firebox so I could handle standard lengths.
http://www.vogelzang.com/browse.cfm/...ted)/4,44.html
It's a budget buster.
The propane tank conversion is neat looking and would be very compact!!
The roof has been coated and does not leak, one skylight is cracked and needs duct tape or a more sophisticated patch. I'll be doing some asking about construction adhesives/glues and hope for a couple more days above freezing.
Any wood stoves for sale?
Anyone a solar panel guru?
I will need electricity for LED lights, computer charger/ cell phone and AA battery charging...the usual suspects.
I have been camping off my motorcycle for 50 years so this is real luxury for me but my needs are not great in terms of lighting. I am used to reading and writing with a headlamp.
Thanks again,
bill
Bill Shockley
bmwktmbill screwed with this post 12-09-2012 at 05:04 PM
Old 12-09-2012, 04:53 PM   #11
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,680
I was wondering what was to be with your project. I'm thinking of doing something similar. I'm starting the other way though. I think I've found a decent Hino Cube van with a 3.8 diesel in it. I plan on using it as a toy hauler and adding some creature comforts. I should be able to salvage RV appliances from older units.
I like the wood heat idea. That could be toasty, even in the winter. One more thing for "The List".
I also though about picking up a 51' van body trailer. They sell for around 2500 at auction and would provide a lot of space. Can't really park them in too many places though. I would just rent a single axle day cab when I needed to move it.
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 12-09-2012, 05:09 PM   #12
bmwktmbill OP
Traveler
Oddometer: 5,142
Deeds,
A nice vehicle I'd kill for, unfortunately I'm on a budget...mission...quest.
good luck.
bill
Bill Shockley
Old 12-09-2012, 05:20 PM   #13
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,438
Something like this for a stove?
http://www.armytents.com/heaters.html
Pick one. The Provo Army surplus store has 3 different sizes all under $200.
Solar power for how much?
An LED reading light, charge your computer and phones.
How about some of these http://www.goalzero.com/prep/
WVhillbilly is offline   Reply With Quote
Old 12-09-2012, 05:27 PM   #14
AKjeff
AKjeff's Avatar
Oddometer: 5,226
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 12-10-2012, 12:49 PM   #15
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:17 PM.
