Old 11-18-2012, 10:19 PM   #16
ragtoplvr
Oddometer: 6,150
Originally Posted by mendoje View Post
I also have the Harbor Freight balancer. Take the bearings out, peel out the bearing shields and toss 'em. Then flush out the grease and lube with very light oil. You'll be able to balance to a 1/4 ounce or less no problem.
then when your bearings get dirt in then they will work much worse.
You can pop a shield, wash out the grease, oil and put the shield back in. But really, it is plenty close with them in. I never feel a shake
Rod
ragtoplvr is online now   Reply With Quote
Old 11-18-2012, 10:57 PM   #17
ParaMud
ParaMud's Avatar
Oddometer: 626
psh make your own. I made this out of wood lying around.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 11-28-2012, 08:00 AM   #18
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Originally Posted by ohgood View Post
I don't get it... what's wrong with the stock axle and two lawnchairs ?
no, really.
Or picnic table, chunk of 4X4 just right and stock axle.... Really cheap.
buls4evr is offline   Reply With Quote
Old 11-28-2012, 12:22 PM   #19
triplenickel
triplenickel's Avatar
Oddometer: 2,428
I use 1/2" round stock with a magnetic torpedo level hung from it, pretty simple. No point in over thinking this shit eh? I have my favorite tires like everyone and when chainging like for like it pretty much never changes.
07 SE
PG007
Old 11-28-2012, 02:11 PM   #20
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Seriously does not matter a hell of a lot. First time you hit a BFR it changes anyway! Only the Starbucks crowd agonizes over wheel balancing. They don't ride over BFRs.....
Old 11-28-2012, 05:26 PM   #21
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 2,093
Did something similar for my DL1000. Made some quick & dirty uprights, far cruder than the pic above, with 90 degree "V" notches rather than round holes. Then I bought an 18" piece of 20mm shaft stock and a pair of open 20mm ID bearings from McMaster-Carr. The bearings rest in the notches.
Wheels are balanced with MotionPro stick-on weights to higher speeds than I care to push the Strom - all is good.
"That's MISTER Crash to you, sonny...."
LexLeroy is offline   Reply With Quote
Old 12-02-2012, 10:31 AM   #22
Navin
Navin's Avatar
Oddometer: 7,823
I just bought the HF one, nice enough piece.
I had just tried Dyna Beads and after swapping tires on/off and testing the beads, the weights and nothing I'm convinced that nothing is just fine. I can't find a difference between any of them.
My front wheel took 3/4 oz and I can remove it with no effect at all up to 100 MPH.
Navin is offline   Reply With Quote
Old 12-04-2012, 06:54 PM   #23
espacef1fan OP
Oddometer: 667
I dont balance my dirtbike tires, USUALLY. unless its a dualsport. My sportbike tires are a different story, hence the thread;)
2006 Bonneville GS100
2006 Ninja 650R
Want a dual sport again...accepting donations..lol
espacef1fan is offline   Reply With Quote
Old 12-04-2012, 07:27 PM   #24
gallinastrips
gallinastrips's Avatar
Oddometer: 701
Got the Marc Parnes too and am very happy with it, nice workmanship
RIDE ON
gallinastrips is offline   Reply With Quote
Old 12-06-2012, 12:25 PM   #25
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,540
Another +1 for Marc Parnes. Have had it for 4+ years. Very nicely made.
There are crap tools that just get thrown around. Then there are others that I depend on for good accuracy and look/feel right for the job. MP balancer is one that I like to take out of the box and use.
'92 K100RS
'12 DRZ400
sugarhillctd on the world-wide K11OG forum
I got my MotoMatters calendar, did you?
DC2wheels is offline   Reply With Quote
Old 12-07-2012, 08:37 AM   #26
ohgood
ohgood's Avatar
Oddometer: 2,726
Originally Posted by DC2wheels View Post
There are crap tools that just get thrown around.... Then there are others that I depend on for good accuracy.... is one that I like to take out of the box and use....
this is going to be one fantastic day.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 12-07-2012, 11:02 AM   #27
Smoke Eater 3
Oddometer: 685
Originally Posted by bhorocks View Post
save your money if you dont care for the truing stand.. I use the harbor frieght one and it works just fine..
http://www.harborfreight.com/motorcy...and-98488.html
Yep! Got that one. Dealers in my area hate me because everyone changes their tires in my garage. I welded up a receiver mount for the Harbor Freight wheel changer too. We change tires on the side of the road, at track days, etc.
Smoke Eater 3 is offline   Reply With Quote
Old 12-09-2012, 11:43 AM   #28
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46 31.714' E 010 27.212'
Oddometer: 3,803
Originally Posted by espacef1fan View Post
I'm kind of done dealing with dealers and shops.
I can understand that. Why pay for substandard work?
I built one similar to the one in your link for under $30. It acts as a wheel balancing and truing stand.
I used precision Swiss bearings without seals (you ought to see this thing resolve), some sheet metal that I sheared and bent for the base and 1"x 3" tubing for the uprights. It was nicely TIG welded.
There was no way I was going to let anybody change my tires and nick a rim, so why stop there.
BTW, balance your wheel rim by itself just to find the heavy spot. Then install your tire accordingly.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Times are GMT -7.   It's 08:26 PM.
