Old 12-09-2012, 07:52 PM   #1
indr OP
Oddometer: 1,197
Disassembled oil pressure relief valve
and read an hour later in the manual that I'm not supposed to.
It was functioning fine. I just disassembled it to clean without thinking.
I'm guessing the ball could be damaged, which is why the manual advises against taking it apart. I'm thinking of running a little brake cleaner from the top to make sure it doesn't come out the other end. Would this be enough to ensure I didn't damage any tolerances?
indr is offline   Reply With Quote
Old 12-09-2012, 07:57 PM   #2
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
Just put it back together conscientiously and you'll be fine. I wouldn't worry about it.
The manual advises against it because if you do not put the snap ring back in its seat correctly and it pops out, you'll lose all your oil pressure right then and there. Better for you to buy a new valve from them instead of the occasional idiot trying to sue them for a new engine.
GreaseMonkey is offline   Reply With Quote
Old 12-09-2012, 08:01 PM   #3
RickS
RickS's Avatar
Oddometer: 578
Gotta ask, for what?
RickS is offline   Reply With Quote
Old 12-09-2012, 09:14 PM   #4
buickid
Lets ride!
Oddometer: 310
I want to say I saw that exact same note in either my Kawasaki or Honda service manual. It was one of those.
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 12-09-2012, 09:49 PM   #5
Tosh Togo
Oddometer: 1,594
Annndddd... did the snap-ring get reinstalled the right way; ie: so its' chamfered side is facing the spring?.
Tosh Togo is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
