Old 11-22-2012, 01:17 AM   #1081
rmhrc628
rmhrc628's Avatar
Oddometer: 2,645
Originally Posted by tehdutchie View Post
On the rubber side of things.. What do you call these in English?
I cannot find the right one here locally (holland) so want to google them abroad.
Looking for this size;
D=12mm
H2=2mm but not too critical
FH=22mm
OD=29mm
H=15mm
Anyone got an English name and ŵebshop where i might find these? I need a few for some fairings im having made for my RXV.
http://www.cmsnl.com/honda-cr500r-19...r_18334ml3680/ maybe?
rmhrc628 is offline   Reply With Quote
Old 11-22-2012, 01:43 AM   #1082
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,844
The fairing will be made once the tower is in place but it will be very close to the 690 rallye part!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 11-22-2012, 01:53 AM   #1083
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,828
Niiiiiiiice
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 11-22-2012, 10:09 AM   #1084
wrk2surf OP
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,901
Originally Posted by Carlos M View Post
On my 640 I have a short choke cable I bought from Sommer KTM. The knob (it's a knob you pull out and twist to hold in the on position) attaches to the frame, close to the kick start. It's very convenient to use and you get rid of another control at the handlebars. I'm on the road right now but can send you a pic next week.
If you are using the Mikuni BST a 03 Ktm 625 sxc uses such a thing..
numbers 93-94-95
Part Number: 0912060303
Description: AH SCREW DIN0912-M 6X30
Part Number: 58302095251
Description: SLEEVE FOR CHOKE CABLE
Part Number: 58302095400
Description: CKOKE CABLE BST 40 L=242MM '00
wrk2surf is offline   Reply With Quote
Old 11-22-2012, 10:52 AM   #1085
Carlos M
www.motoxplorers.com
Carlos M's Avatar
Oddometer: 3,400
numbers 93-94-95
That's exactly what I have on the 640.
Carlos M.
MotoXplorers.com
Carlos M is offline   Reply With Quote
Old 11-22-2012, 12:23 PM   #1086
schattat
schattat's Avatar
Oddometer: 1,445
@Antal: English word is grommet, in German: Gummidurchführungstülle
Can get them here at Conrad. I have various types to mount tripmasters on to 3mm plates with here, let me know if you need any!
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is offline   Reply With Quote
Old 11-22-2012, 12:50 PM   #1087
tehdutchie
tehdutchie's Avatar
Oddometer: 1,877
Thanks for all the responses! Will check!
tehdutchie is offline   Reply With Quote
Old 11-29-2012, 01:56 AM   #1088
juancartm
Oddometer: 4
Alberto Dottori bracket
Hi to all:
My name is Juan Carlos, from Spain. In 60 days I will be racing the IRC2013.
http://www.intercontinentalrally.com/
I want to share with you my little esperience....
My bike is in rally progress now.
I show it to you:
This a cheap way to race.
Well, I add more pictures soon.
Gaasssss.
juancartm is offline   Reply With Quote
Old 12-06-2012, 11:22 PM   #1089
michael1968
michael1968's Avatar
Oddometer: 865
Fairing
So I'm finally getting around to making a proper fairing for my nav tower, at this stage it's just a plug made of MDF. It will be vacuum bagged carbon/kevlar eventually.
michael1968 is offline   Reply With Quote
Old 12-10-2012, 04:42 AM   #1090
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,741
Darth Vader has arrived
you might consider giving that top edge a small amount of curl so that if you do an ender over the bars it has less knifing potential.
Seth S
Seth S screwed with this post 12-10-2012 at 05:29 AM
Seth S is offline   Reply With Quote
Old 12-10-2012, 04:48 AM   #1091
640 Armageddon
-oo-
Oddometer: 2,828
Old 12-10-2012, 05:47 PM   #1092
michael1968
Oddometer: 865
I did finally get around to watching star wars episode 3 a few weeks ago, maybe it rubbed off on me.
Thanks for the tip, I think I'll add a bit of a lip the whole way round.
Old 12-14-2012, 11:47 AM   #1093
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Used some HDPE cutting boards to mock up my brackets. Glad I did. I have interference on both sides, brake line on right side and a mounting bolt on the left side.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 12-14-2012, 12:03 PM   #1094
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
On the rally bikes we build, we re-route the brake lines so that all the moving portion is between the caliper and the lower triple clamp. Everything above the lower triple is fixed to the triple and bars to avoid interference. We attach the line to the triple using rubber-lined loop clamps.
Here's Kevin doing that on his 2013 Dakar bike (pic courtesy RMK).
Dave
DaveRMS is offline   Reply With Quote
Old 12-14-2012, 12:55 PM   #1095
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,899
on the KTM's there are 2 - 6mm holes that position it perfect.
This is a pic from my installation instructions.
c.vestal is offline   Reply With Quote
Times are GMT -7.   It's 08:12 AM.
