Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 12-09-2012, 06:20 PM   #6241
TravellingStrom
TravellingStrom's Avatar
Oddometer: 392
Hmm
I have been following this section with interest, especially as I just learned how to add a shortcut The Fuel search function would be nice for me too, and as my version is 4.60 I tried a few things.
It seems the FUEL 'where to' is available in a few places. I went to my single tap "Favourites' page and using the 'change favourites' button, then 'add favourite' the 'FUEL Services' was available, cool :)
I then went into Setup/Main Menu/Add and I could also select Fuel Services and out it in my drawer as well :)
And to answer the question raised above, yes I could select lodging, or hospitals or whatever I wanted in EITHER location, even though one of them has been selected before
Cheers
TS
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 12-09-2012, 09:05 PM   #6242
Rocky TFS
Rocky TFS's Avatar
Oddometer: 228
Resistance is futile......you will be assimilated.
Rocky, aka t.h.e.b.o.r.g.
Rocky TFS is offline   Reply With Quote
Old 12-09-2012, 11:32 PM   #6243
advNZer?
advNZer?'s Avatar
Oddometer: 2,242
no problem
aka BMWST?
advNZer? screwed with this post 12-10-2012 at 12:28 AM
advNZer? is offline   Reply With Quote
Old 12-10-2012, 04:41 AM   #6244
Cataract2
Where to?
Oddometer: 498
Send a message via AIM to Cataract2
Originally Posted by advNZer? View Post
no problem
She could assimilate me any day.
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 12-10-2012, 08:06 AM   #6245
Bonerov
Oddometer: 167
Gotta love Seven of Nine, or as I called her: Seven and Eight of Nine.
Bonerov is offline   Reply With Quote
Old 12-10-2012, 08:13 AM   #6246
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 3,259
Originally Posted by TravellingStrom View Post
Hmm
Cheers
TS
Yes, anyplace you can put an App/Shortcut Icon you can add the WhereTo? Searches. But, you can't (via the menu's) add it twice to the same Menu Page or the Favorites Dashboard. Not that you would want to I suppose.
UPDATE: The Montana Dev Team are probably getting a kick out of watching me s-l-o-o-o-w-l-y figure out that there isn't a problem.
Cheers,
Cheers,
Dan
DRTBYK screwed with this post 12-10-2012 at 02:23 PM
DRTBYK is offline   Reply With Quote
Old 12-10-2012, 12:33 PM   #6247
Bonerov
Oddometer: 167
I finally received an email response about my security screw issue. The person agreed with me that it sounds like the screw is too short, but suggested that I just put in a longer one. I had to reply to him that I liked the Torx screw, as it provides a small amount of security. Replacement would be a pain in the butt, as it requires disassembly of the mount, and would eliminate the security aspect of the "security screw." I asked him if there was any way that they could simply replace the mount. We'll see what he replies. Here is the email he sent me:
Dear Aaron,
Thank you for contacting Garmin International. I would be glad to help
you with this.
I believe I have an understanding regarding the situation you currently
have, but to be sure a video may help (if you do not mind).
Additionally, it may be a case where the screw could unfortunately be
too short. At a local hardware store you should be able to find a longer
screw (M3 x 6mm long screw) which will fit the mount. Please let me know
if this remedies the trouble.
With Best Regards,
Matt S
Product Support Specialist
Outdoor/Fitness Team
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Matt S, Associate #6042
www.garmin.com
Old 12-10-2012, 12:43 PM   #6248
Offcamber
Offcamber's Avatar
Oddometer: 1,177
Dear Aaron,
you with this.
With Best Regards,
Matt S
913-397-8200
800-800-1020
www.garmin.com
I had the same issue on one of my two mounts....I ended up taking it part and removing the washer. That gives it just enough length to engage the threads....
"I don't ride to be seen....I ride because I want to disappear...."
Halfthrottle
"The difference between genius and stupidity is -- genius has its limits."
~Albert Einstein
Offcamber is offline   Reply With Quote
Old 12-10-2012, 03:42 PM   #6249
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 486
That's it. I can't stand any more.
If Garmin is gonna make it so easy, I am going to make a page with links and quotes to all of their Customer Support Failures.
They are epic at failing.
Garmin Montana Wiki Oregon 6xx Wiki BaseCamp Wiki
atlas cached is offline   Reply With Quote
Old 12-10-2012, 03:57 PM   #6250
DRTBYK
DRTBYK's Avatar
Oddometer: 3,259
With Best Regards,
Matt S
[/B][/I]913-397-8200
800-800-1020
www.garmin.com
It's too easy to hand a Garmin problem back to the Customer via email. I would not accept this response. I know it takes time away from your personal life but make a phone call and don't hang up until you have the issue resolved. Escalate to a Supervisor if need be. If that doesn't work for you maybe sending this Prod.Support response email to Mr. Cliff Pemble would be a good idea.
If I were a Garmin Exec I'd be embarrassed by the Product Support suggestion that the Customer should "fix" a engineering/manufacturing defect in my product.
Cheers,
Cheers,
Dan
Old 12-10-2012, 04:07 PM   #6251
mass-klr
mass-klr's Avatar
Oddometer: 78
Dear Aaron,
you with this.
With Best Regards,
Matt S
913-397-8200
800-800-1020
www.garmin.com
I guess I was very, very lucky. This is what my reply looked like:
I am sorry to hear that your mount is not holding the device in correctly. If you could please provide me with a copy of the receipt I would be more then happy to see if we can cover it under warranty for you.
Please let me know if you have further questions.
With Best Regards,
Tim Fe.
Outdoor Team 2nd Shift
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Tim Fe., Associate #6982
www.garmin.com
If I could please get your shipping address, phone number, and email address I would be more then happy to send you a replacement mount.
And got it a week later...
mass-klr is online now   Reply With Quote
Old 12-10-2012, 04:46 PM   #6252
DRTBYK
DRTBYK's Avatar
Oddometer: 3,259
With Best Regards,
Tim Fe.
913-397-8200
800-800-1020
www.garmin.com
Tim Fe was the Support Specialist that worked with me to replace my Tempe. Sometimes you get a good one, eh?
Cheers,
Cheers,
Dan
Old 12-10-2012, 04:52 PM   #6253
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,054
With the info posted by mass KLR, we can direct our email to Tim Fe:
Not that I would ever resort to doing that...
P.S. New Post in the Wisdom and FAQ Thread. Bli55 gave me permission to add his post about replacing the Security Screw from the Rugged Mount.
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee is online now   Reply With Quote
Old 12-11-2012, 10:24 AM   #6254
Bonerov
Oddometer: 167
That would be very helpful, I think. What a PITA.
Cheers,
Right? That was my first thought, as well. You guys want me to go to a hardware store, buy parts, take apart my mount, and fix it myself, instead of just replacing it? Seriously?
Tim Fe.
Modified the message to shorten it, but that was the response for which I was hoping. Maybe I need to contact Mr. Fe directly. How annoying.
Old 12-11-2012, 10:58 AM   #6255
Offcamber
Offcamber's Avatar
Oddometer: 1,177
I found it easier to just fix it than deal with CS trying to get a replacement that may very well have the same issue.
How many of you stuffed earplugs in the battery compartment to fix that issue rather then send it back for a replacement that will do the same thing. I pick my battles, this one wasn't worth it....YMMV
I'm not agree with the CS rep that told you to replace the screw....if a replacement is really what you want call back and talk to someone else....
Halfthrottle
~Albert Einstein
Times are GMT -7.   It's 09:05 AM.
