Old 12-10-2012, 03:20 PM   #3931
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by kindofblue View Post
Looks to me like the spark plug cover.
Yeap, I think so.
EJ_92606 is offline   Reply With Quote
Old 12-10-2012, 03:38 PM   #3932
CrustyAPO
CrustyAPO's Avatar
Oddometer: 439
The oil filter position looks like it is going to make for messy oil changes.
Yeah, and maybe I'm a Chinese jet pilot.
CrustyAPO is offline   Reply With Quote
Old 12-10-2012, 04:00 PM   #3933
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Ya, i know where the spark plug is, but you see where the spark plug wire goes once it exists the valve cover? under the plastic piece and around the cover....
Old 12-10-2012, 04:11 PM   #3934
Marki_GSA
Oddometer: 705
there is nothing special about where the injector is. It is in a better place than it used to be but it is now where virtually every other engine has its injector. Even the first Kawasaki 750 turbo engines had the injectors there. Its certainly no where close to being DI
Marki_GSA is offline   Reply With Quote
Old 12-10-2012, 04:12 PM   #3935
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I think we could both be right...clearly the spark plug wire runs up in that area as can be seen in this pic, but there is also clearly a port to the intake for either a sensor of some sort or injector.
Old 12-10-2012, 04:28 PM   #3936
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Found a better picture of the intake....yes, definitely an injector as can be seen by the light blue color signifying gasoline.
Old 12-10-2012, 05:29 PM   #3937
Montauk
Oddometer: 280
Originally Posted by Montauk View Post
I couldn't figure out the purpose of this plastic thing sticking out on the left side above the cylinder
From image posted by EJ_92606 (just realized that you are in my backyard, I am north of Hwy 5), this means, that the thick cable is carrying fuel and not fuel vapor. Leaving it exposed to outside prankster to cut the cable. Further, it seems that they fastened it with 1 screw.
But the good thing is that they placed it where it would not easily break through accident of some kind. I hope extreme heat from the cylinder do not cause problems with the cable while it sits on top. It looks like it is touching the cylinder.
Montauk is offline   Reply With Quote
Old 12-10-2012, 05:51 PM   #3938
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,615
If you include the carburated R bikes bikes the fuel line has been in the open for the past 90 years. How is this any different (other than unlike the carburated bikes you can't drain the tank by cutting this line).
marchyman is offline   Reply With Quote
Old 12-10-2012, 07:31 PM   #3939
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Montauk: Great pictures!!!
tallguy-09 is offline   Reply With Quote
Old 12-10-2012, 07:55 PM   #3940
RetrogradE
RetrogradE's Avatar
Oddometer: 1,226
Originally Posted by oalvarez View Post
the nice thing is that if you tire of the color you could always swap or buy oem painted plastics for not very much money.
1. We don't even know what the bike will cost yet, so to extrapolate the cost of plastics is a strange past-time.
2. "Not very much money" is a relative concept, but I've found anything "OEM" isn't cheap at all.
RetrogradE is offline   Reply With Quote
Old 12-10-2012, 07:58 PM   #3941
Kevin Dixon
Motorrad Abenteurer
Kevin Dixon's Avatar
Oddometer: 818
Anyone worried about tire selection for the new size tires?
Kevin Dixon is offline   Reply With Quote
Old 12-10-2012, 08:04 PM   #3942
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
You must have missed the 'swap' part. In addition, I thought his point was a good one. There are only a few panels, unlike a car...take em off and have em sprayed if you don't want to buy new. If a few hundred bucks is an issue, I think you shouldn't be looking at a $20k bike.
Old 12-10-2012, 08:24 PM   #3943
Montauk
Oddometer: 280
You don't have choice, water cooled can come in one of three diff tires all same size just diff manufacturer
Old 12-10-2012, 08:25 PM   #3944
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,677
I was using the cost of the parts off of a current model year as the basis for my statement. I would be amazed if they were dramatically different in price, I suppose we'll know the real answer soon. If one wants to change the color of their bike without sacrificing their panels and the resale value of their bike, swapping panels or buying oem painted ones is a cost effective way of doing so. Well, at least I think it is.
Thanks EJ.
2016 Aprilia Tuono Factory | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 12-10-2012, 08:33 PM   #3945
Kevin Dixon
Motorrad Abenteurer
Oddometer: 818
Coming from a K16 with a crappy selection of available tires this is the only thing that worries me. Oh well hopefully the manufacturers come out with something by March.
Times are GMT -7.   It's 01:27 AM.
