12-11-2012, 11:19 AM
#16 | |
BAN - Born Again Noob
Oddometer: 5,962
brake...weight shifts forward..forks compress...front tyre profile changes to provide more contact with road so front brakes are more effective.. this simply doesn't happen with the rear brakes.. IMO a heavy cruiser has just as much reason to front wheel brake (in conjuction with the rear) than any other bike.....when the conditions allow it. As for the newbie choice presented by Wraith...I'm going to go with "none of the above". Instead I'd teach a newbie to brake properly...front and back, with no locking..and keep teaching until they can manage that before they get let loose on the road. Braking is a fundamental skill.
Planning NA 2010 NA 2010 Adriatic Loop August 09 Mandello Guzzi Protest Sept 09 "I've got the key to the gates of paradise...but I've got too many legs!!" Jeff "Civilized men are more discourteous than savages because they know they can be impolite without having their skulls split, as a general thing." -- Robert E. Howard |
12-11-2012, 11:26 AM
#17 |
Riding an' Wrenching
Oddometer: 112
Seems silly to me to deny your ANY percentage of your brakes the chance to stop you in an emergency. I use both brakes often, and have found that good use of the rear has led to being quicker on the twisty roads. By splitting the braking between the front and rear, you minimize chassis de-stabalizing, and the bike is better settled and set up for the turn. Only using the front brakes has my bike feeling squirrelly and not at all confidence inspiring. Also I find I often over brake for a corner when only using the front. Using both it is easier to modulate my corner entry speed.
In an emergency braking I also use both brakes and if the rear locks up, it is still controllable. I would tell the new rider to practice using both brakes so he or she understands and knows how they react. Telling someone to ignore any of their braking potential seems like a bad idea to me. Just my thoughts. |
12-11-2012, 11:35 AM
#18 | |
Latte riders FTW!
Oddometer: 1,142
Without writing a full graduate paper on the subject (I'm sure you will have that before too long), both brakes have their uses so ultimately you want to learn to use all the features of the bike, not just some of them. I can understand telling a new rider to just use the front brake until they become competent with it, there is a lot to learn / co-ordinate when you are starting out but after a week I would expect the new rider to be using all the brakes. In the same way you would introduce more advanced steering inputs as the riders competency grows, the end result you are aiming for is a rider fully capable of getting the best they can from the motorcycle. In answer to your brake question, I use the rear all the time on every bike, dirt, road and track, it's a great tool, learn to get the best out of it.
Orange...cause it makes me look like I know what I'm doing! |
12-11-2012, 11:37 AM
#19 |
Oddometer: 18,063
Practice Practice PRACTICE.
Use both and make a habit of doing a few threshold braking maneuvers each and EVERY ride.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
12-11-2012, 12:13 PM
#20 |
Frostback
Oddometer: 176
Hell, I don't even like to use my rear brakes on my car. I use them occasionally though and for deliberate skids they are pretty handy.
12-11-2012, 12:22 PM
#21 | |
Oddometer: 5,962
what car have you got?
12-11-2012, 12:30 PM
#22 | |
Oddometer: 7,796
But to avoid using the rear brake for fear of locking the rear wheel is just as dumb a reason as avoiding using the front brake for fear of going over the handlebars... As we slow down it doesn't make a s#*t what you do. Remember, the OP was talking about freeway speeds, not residential road speeds. Thanks for giving me credit for that "one" thing I got right.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
12-11-2012, 12:41 PM
#23 | |
Adventure Poser
Oddometer: 1,067
Until your girlfriend becomes an expert at stoppies though, she should be advised to practice emergency stops using both brakes.
2000 Shadow 750 (the "trainer") - Sold 2005 DL650 - The "real" bike Money gives back small echo to the cries of calumny. - Samuel Hopkins Adams Heaven and Hell are one and the same when desperation's all you can afford. - Warren Haynes |
12-11-2012, 12:43 PM
#24 | |
MADMark
Oddometer: 128
MAD (yes, those are my real initials) |
12-11-2012, 01:09 PM
#25 |
Наглый ублюдок
Oddometer: 617
OP,
I'm really not following your logic that she shouldn't be learning how to use that rear brake in "NEED TO STOP NOW" situations because she may be panicking and over do it. How do you think she's going to develop the conditioned response (uh oh, I just used a psychological term) required to not lock up that brake in an emergency situation? She has to practice using the rear brake in a firm, progressive manner. I know other people have said this, but I figured it needed to be repeated one more time for good measure. In emergency situations you want to stack the cards as heavily in your favor as you can.
I ride 652ccs of slug. |
12-11-2012, 01:15 PM
#26 | |
QuestionableBanterer
Oddometer: 10,894
Because when you really need it, it needs to be automatic. It's very pleasing to execute a quick stop for a deer or somesuch, and look back on the event a few minutes later and realize you didn't even think about the brakes, you just did it. |
12-11-2012, 01:25 PM
#27 | |
Isn't that dangerous?
Oddometer: 1,243
EastSideSM: '06 950SM Black, '01 Honda RC51 |
#28 |
not dead yet
Oddometer: 26,994
There is no such thing as a fixed front/rear ratio so in that sense 70/30 is bullshit. But they also put a rear disc on performance bikes for a reason. Until you are actually doing a stoppie, there is still rear braking power left. In normal street riding, people are not doing stoppies.
Personally I believe in approprite use of both brakes. My wife has a tendency to not use the rear brake and I have encouraged her to routinely use it. We ride a lot of dirt roads and contaminated hard surfaces and I don't want her to needlessly wash out the front trying to squeeze it harder to get the bike to stop in time, when she still has back brake capacity left unused. The way to learn to not lock up the rear is to use the rear enough to get familiar with its characterisitcs, not to not touch it out of fear it will lock up. That's just as bad as the Hardly Dimwitson riders who supposedly are afraid to touch the front brake for fear they'll go over the bars.
Advanced pancreatic cancer diagnosed 04/2010. 95% mortality within 2 years but NOT DEAD YET. Been thru & still doing all sorts of treatments. Gonna keep doing what I'm doing until I can't any more. |
12-11-2012, 01:37 PM
#29 |
Red Sox Nation
Oddometer: 8,922
I'm with the OP. The only time I use the rear brake is in dirt, and even then I try to use the front more. The front brake is your friend even off-road.
On the street I'll sometimes use the rear brake on slippery surfaces, but not much. In fact, If I used my rear brake on my old KTM 950 with any pressure, it would boil the brake fluid and be pretty much useless until it was serviced. Take Daytona coming down from a buck seventy off the tri-oval and into the slow speed T1. You think anybody uses the rear brake? ![]() How about Loudon in the rain into turn 3? Think anybody uses the rear brake? I think the front brake is the one everybody needs practice with. The rear brake is a crutch.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
12-11-2012, 01:38 PM
#30 |
Isn't this that guy?
Oddometer: 676
Hmm, why's that there...
![]() they must not use it. Those guys don't know how to ride anyway.
