Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 12-07-2012, 03:58 PM   #211
burmbuster
burmbuster's Avatar
Oddometer: 1,444
Originally Posted by cug View Post
I don't disagree. For me it's just not worth the money. You're shaving what, four pounds or so from a 500+ pound bike (including crashbars, farkles) ... not even worth thinking about it. That's under 1% ...
Yes, but I also went with Wolfman Expedition panniers rather than hard cases (with the exception of my top box but I dont use it while off road) so if you add all of the weight savings up together it can make quite a difference. Especially tackling sandy off road conditions. If you can save weight in some areas it also allows you to splurge in others. Like tools and camping gear.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 12-07-2012, 10:04 PM   #212
devians
Oddometer: 5
Originally Posted by fbj913 View Post
Heya, do you have a link for that gps mount above the instrument cluster? (Not the mount for the gps itself but the mount for that)
devians screwed with this post 12-07-2012 at 10:13 PM
devians is offline   Reply With Quote
Old 12-08-2012, 09:37 AM   #213
Moonsorrow
Jesus
Oddometer: 43
http://www.touratech-usa.com/Store/1...umph-Tiger-800
Moonsorrow is offline   Reply With Quote
Old 12-08-2012, 02:52 PM   #214
MuddySump
MuddySump's Avatar
Oddometer: 97
Think its touratech adjustable mount
Tiger 800XC
Drz 400E
www.youtube.com/muddysump
Tiger 800XC
DRZ 400E
MuddySump is offline   Reply With Quote
Old 12-08-2012, 03:49 PM   #215
freefall109
freefall109's Avatar
Oddometer: 156
Puke
Awesome...who has information on the center light mod in the front fender?
freefall109 screwed with this post 12-09-2012 at 10:43 AM
freefall109 is offline   Reply With Quote
Old 12-09-2012, 06:16 PM   #216
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by Moonsorrow View Post
yep it's all Touratech.
fbj913 is offline   Reply With Quote
Old 12-10-2012, 01:36 AM   #217
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
Originally Posted by Dr. Doofenshmirtz View Post
Heres another option a Carbon fiber hand guard for 96 bucks. Seller has an ebay store. They are also selling carbon fiber versions of all the Tiger 800 plastic parts.
Er, yeah.......read the info carefully and you'll see they're fibreglass with a carbon covering. You'll not get full oven cured carbon fibre for that money.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 12-10-2012, 01:57 AM   #218
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
Sometimes the solution is just so simple that you dont even think about it! Thanks for sharing ;) . Also I will be raising the fender a bit, just a precaution.
Still, I'd prefer the single brakelines instead of all the twists the standard one has. Probably just have to find someone with a 955i and check their banjo bolts.
The set-up you might want to look at is the Tiger1050. That has a single line to a block on the bottom yoke and then two lines to the calipers.
I used the Touratech kit to raise the front guard. Works fine.
But to allay your fears over the front guard shattering. The BMW guard is made from "abs" whereas the Tiger guard is made from Polypropylene. abs will shatter. PP will bend, flex and give. I don't think we'll have that problem.
Old 12-10-2012, 08:11 AM   #219
DropinParts
Ducatista
DropinParts's Avatar
Oddometer: 96
Question Handguards... I need better ones
Just picked up my new Tiger XC and went for my first ride yesterday. It was chilly late in the day and I noticed the hand guards are just to low to keep the cold air off your knuckles.
I see several different ones on this forum. While crash protection is a consideration, I am first looking for wind protection.
Any advice?
There are two roads in life, the twisty one is vastly more fun.
DropinParts is offline   Reply With Quote
Old 12-10-2012, 08:40 AM   #220
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,668
Best wind protection available from a purely handguard solution, is to use Barkbuster guards with the Storm plastic shields.
Next level of protection is a set of Hippo Hands.
Old 12-10-2012, 08:48 AM   #221
cug
Oddometer: 4,878
And they can be used together for the best feeling.
Or the ones from inmate Corrado113:
http://www.advrider.com/forums/showthread.php?t=487221
Scroll down a bit for the wind deflectors.
cug is offline   Reply With Quote
Old 12-11-2012, 01:43 PM   #222
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,537
Who makes the best radiator guard? Is the OEM Triumph one okay or are any of the others any better / cheaper? Some of them look really thin in the pics. anyone had a good ding or rock hit on the radiator?
(Still evaluating what net farkle will be!)
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 12-11-2012, 01:57 PM   #223
bluesman
Oddometer: 3,343
why put another rad guard than stock XC honeycomb plastic? It is more rigid than those thin metal panels and not any less protective...IMO
bluesman is offline   Reply With Quote
Old 12-11-2012, 01:59 PM   #224
advtenn
advtenn's Avatar
Oddometer: 1,364
+1 the factory guard works well. Put your money toward risers.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 12-12-2012, 06:20 AM   #225
DarkRider
Middle-aged Man
DarkRider's Avatar
Oddometer: 608
Tank bag question
I'm about to take delivery on an 800XC and have a question for current owners on tank bags. Aerostich is having a sale today (12/12 sale) and I'd been looking at the Ortlieb Waterproof tank bag. Was comparing it to the Wolfman small expedition and curious if anyone has opinions on either. Specifically, easy of removal for fueling and whether either fits better on an XC.
Thanks in advance for any comments.
_______________________
Life is a participatory sport - say YES and let the adventure begin.
DarkRider is offline   Reply With Quote
Times are GMT -7.   It's 01:45 PM.
