Old 12-10-2012, 07:52 AM   #1
Michelangelo OP
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,736
Anyone make a small driving light with high/low beam?
I'm making a custom mx style number plate for my Bandit 1200 streetfighter and going to fit a single projector or driving light of some kind. (No, not a fog light. I need something I can actually see with in the dark on the highway.)
Ideally I need something that is self-contained, meaning has the high/low bulb or a high/low/ground hookup on it so I can still use my handlebar switch to go from high to low and back. Needs to be under $100.
Any recommendations?
Dirt and offroad motorcycle tours...
ALL MOTO ADVENTURE,LLC.
www.AllMotoAdventure.com
Michelangelo is online now   Reply With Quote
Old 12-10-2012, 08:07 AM   #2
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,715
sanjoh, aka advmonster led lights. happy with mine. you'd need the rotary dimmer switch, but with the adv discount you could probably come in right around 100. no affiliation, just a happy customer.
http://advrider.com/forums/showthread.php?t=607184
http://stores.intuitwebsites.com/hst...StoreFront.bok
none of us is as dumb as all of us
clapped_r6 is online now   Reply With Quote
Old 12-10-2012, 12:03 PM   #3
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 1,009
Do you really want a small headlight? At least in most states, driving lights are only allowed to be on with a high beam headlight. Fog lights are only allowed to be on with a low beam headlight.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is online now   Reply With Quote
Old 12-10-2012, 12:25 PM   #4
Michelangelo OP
Oddometer: 1,736
Yes.
Old 12-11-2012, 06:40 AM   #5
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
We have a small (a bit larger than 2" in diameter) led light that has an adjustable low beam, with a high beam. Plenty of light to navigate or get a light tan
Tree at 100yds
Send me an email if you need more info. sandjoh@gmail.com
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 12-11-2012, 12:36 PM   #6
Michelangelo OP
Oddometer: 1,736
Ended up going with this one
Says it has a High and Low beam. Will have to make an L alum bracket to mount it cleanly.
Old 12-11-2012, 05:43 PM   #7
Myfuture_yourdebt
Oddometer: 372
If that doesn't work something like this might:
http://www.amazon.com/HELLA-Oval-Dou...rds=Hella+dual
With that you'd have a lot of options but none of them would include switchable/hi-lo bulbs (a la H4). That being said you could replace one bulb with a higher wattage or HID bulb and connect that to high beam and/or wire the bulbs so high beam also keeps the low beam bulb lit.
Myfuture_yourdebt is offline   Reply With Quote
Old 12-11-2012, 06:41 PM   #8
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Kinda reminds me of this
Hope it works for you.
Times are GMT -7.   It's 09:29 AM.
