Old 12-10-2012, 07:28 PM   #13996
Belgian Waffles
Oddometer: 795
Too good to be true, right?
http://www.ebay.com/itm/Honda-XL600-...0b40d4&vxp=mtr
Just making sure... Is it just cheap quality chain in general? Poor quality seals/rings, etc? Or is someone just being really generous.
I'll be needing a chain and sprockets here pretty soon.
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 12-10-2012, 07:47 PM   #13997
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,418
That eBay chain and sprocket set is cheap and maybe too cheap. A good chain alone should cost around $100. Having seen front spline drive sprocket wear I will only get oem front sprockets the rear and chain just good quality but dosnt have to be oem
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 12-10-2012, 08:09 PM   #13998
NorCalTA
Roaming ADV Gnome
NorCalTA's Avatar
Oddometer: 1,395
Last chain I bought was an EK X-Ring from ebay seller moto-heaven for less than $100 shipped. They were great to deal with and have an excellent reputation.
EK 525 SRX GOLD 120 links Motorcycle drive Chain X-RIng
NorCalTA is offline   Reply With Quote
Old 12-11-2012, 07:15 AM   #13999
danyila
danyila's Avatar
Oddometer: 26
http://transalp.danyila.hu/lajos/haspancel/DSCF9810.JPG
http://transalp.danyila.hu/lajos/haspancel/DSCF9811.JPG
http://transalp.danyila.hu/lajos/haspancel/DSCF9776.JPG
6 mm aluminimu plate. Rivet 8mm aluminum
danyila screwed with this post 12-11-2012 at 07:27 AM
danyila is offline   Reply With Quote
Old 12-11-2012, 08:18 AM   #14000
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,250
Couldn't get the links to show so I edited them. My TA plate is cracked and getting fugly. Need something Heavy like this.
Michael
mgorman is offline   Reply With Quote
Old 12-11-2012, 08:27 AM   #14001
Kamala
Kamala's Avatar
Oddometer: 11,543
Send a message via Yahoo to Kamala
Originally Posted by tuffgong View Post
Clutch replacement on an 89 TA 600 looks to be a fairly straight forward proposition without too many complications,open access and no special tools required. Am I kidding myself?
You will need something (Clutch basket Tool, Pennys, Wood) to keep the basket from rotating to get the nut off but other than that its pretty easy. BTW, more often than not all you need for a slipping clutch are new clutch springs. If you are replacing them (as you should) its worth while to see if just those alone solves the slipping problem.
I might be old but I saw all the great bands Live!
I have changed an Audi A6 Water Pump, I can do anything!
Kamala is offline   Reply With Quote
Old 12-11-2012, 02:03 PM   #14002
Transalp1999
Oddometer: 8
Question What the heck am I missing!?
I put a new National Cycle windscreen on this evening and put new windscreen screws in (Since the originals were in rough shape). Problem is the darn things don't tighten down like they should. They just spin. I've tried grabbing the back with a par of needle-nose pliers but no luck. Think it's just cheap rubber that's not compressing to form a seal?? Or what??
Cheers!
Transalp1999 is offline   Reply With Quote
Old 12-11-2012, 02:59 PM   #14003
2bold2getold
Oddometer: 487
Cheers!
I'm guessing these are what are called "well nuts". A flanged rubber tube with a brass threaded insert in one end. I had some that the threaded part turned in the rubber. I carefully used a little super glue on the metal part and quickly reinserted in the rubber. Worked good. Try to keep it straight, and check the threads on the screws. Or get new well nuts at a hardware store or bike shop.
2bold2getold is offline   Reply With Quote
Old 12-11-2012, 07:11 PM   #14004
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,250
Make sure the new screws are threaded all the way up, maybe you are running out of threads before it gets tight or they are too long?
Michael
Old 12-11-2012, 07:46 PM   #14005
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,268
The wellnut rubber end should be a very snug fit in the hole. I have to use a bit of ArmorAll to lube them up a bit before they will pop in.
If they just fall into the hole they are the wrong size
They also have to be long enough to allow the inside bit to deform slightly (like a rivet) to hold the screen tightly against the frame.
Ladder106 is offline   Reply With Quote
Old 12-14-2012, 05:42 AM   #14006
danyila
danyila's Avatar
Oddometer: 26
This is a very robust.
Old 12-14-2012, 05:49 AM   #14007
ChrisUK
ChrisUK's Avatar
Oddometer: 405
Updates of RR involving a TA at http://advrider.com/forums/showthrea...=828973&page=5
Take a look?
Brighty's website: http://www.thebrightstuff.com/
Summer 2012 RR: http://advrider.com/forums/showthread.php?t=828973
ChrisUK is offline   Reply With Quote
Old 12-16-2012, 08:33 AM   #14008
DualDog
Oddometer: 126
Fronk Shocks/Forks
My 1989 Transalp is leaking from front shock and boots are falling apart and has had quite a bit of sag in front end for awhile.
Getting ready to order some Progressive Springs.
Also getting some Honda Fork Seals and Dust Covers.
Question. What is a good fork boot to use? I put Daystar brand ones on my KLR650 and have been happy. Was wondering if anybody is using these and if so, what size. I have seen some sites say the size 58 is what is needed and others say size 69 is what is needed and Daystar website does not list what will fit this cycle. Any suggestions on what size or suggestion on another brand would be helpful (or a brand to avoid).
I am wondering if any special tools and/or equipement will be needed to do this.
Also, any help or suggestions here would be appreciated on how to perform this job.
DualDog is offline   Reply With Quote
Old 12-16-2012, 11:18 AM   #14009
Rob 110
Rob 110's Avatar
Oddometer: 22
noob
hi been lurking for a while and reading up on what to do!
bought this 99 bike with 30,000miles, ex Police bike for £800
got 87 CR500 cartridge forks and RD03 swinger, plus '83 CR250 shocker, so it'll all happen slowly
managed to get a bit done today!
sold loads on ebay, fairing, bars, etc for over £300!!!!
so bought loads too
the transalp exhaust was rotten and i'd always planned for it to go, bit when i removed it actually broke off from the header!
especially pleased with the replacement titanium Gixxer pipe for £11.20 delivered! half the weight too at only 3kg
talking of weightloss i've actually taken 23.5kg off it!
but replacements for some parts only adding 3.8kg, but fairing and a new headlamp will add to this
got the CR forks/XR yokes in today, had to drill and tap some lock stops, but fairly straightforward.
Pleased to find the Transalp progressive springs were longer than the CR ones!
But removing the CR spacer makes em fit with a bit of preload. Trying 5w oil and 120mm air gap.
Oil removed was pretty clean for the age of the forks.
more next week and over chrimbo
http://i589.photobucket.com/albums/s...b110/all-1.png
Dirty R30 CCM
Filty 404 CCM
Tatty Transalp
Rob 110 is offline   Reply With Quote
Old 12-16-2012, 11:38 AM   #14010
Ladder106
Ladder106's Avatar
Oddometer: 4,268
As with any fork swap, you'll want to be certain that the front wheel/tire/fender does not compress so far that it contacts the triple clamp or the frame downtube or crashbars.
Remove the springs and raise the wheel until the fork stops going up...see if anything gets in the way of the tire.
Times are GMT -7.   It's 04:09 AM.
