12-09-2012, 05:43 PM
#541 |
Slow Ride to Nowhere
Oddometer: 126
Alpi , That's one of the eBay contact's I'm waiting to hear back from. Go figure. Either they don't know how to measure it, or business is so good they don't need us.
It appears the TT ABS kit is no longer available. I would like a close look at some WP axle clamps. I would guess it could be drilled and tapped for a couple short 4mm bolts. This should allow a plate to be mounted to carry the ABS sensor. Maybe even use the fork guard lower mounting location. I need to see one in person.
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson 06 FJR1300 09 XR1200 H-D Yea I thought I never would either 75 Norton 850 E-Start Project 69 Z-50A Mini Trail with Lights & 2007 X-Challenge Heavy dirt bike sweet sweet motor |
12-09-2012, 06:11 PM
#542 | ||
Oddometer: 73
'07 G650 XCh (and '04 recumbent bike) |
12-09-2012, 06:47 PM
#543 |
Oddometer: 836
From memory the magnet and reed sensor are for the TT road book/computer
12-11-2012, 10:31 PM
#544 | ||
"Moto Porn"ographer
Oddometer: 3,831
If you are doing enduro work on it then what Lukas suggested are about right. If you are doing adventure travel with it, or general purpose riding, then you want lighter. (KTM 950-990 Adventure use 0.48 and thats a much heavier bike - AND with less travel on their forks) I would recommend about 0.44 if linear springs. I used progressive springs from Hyperpro that started at about 0.42 and go up to about 0.56 later in the stroke
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE World Motorcycle Altitude Record video HERE www.sibirskyextreme.com Colebatch screwed with this post 12-11-2012 at 10:40 PM |
12-13-2012, 01:26 PM
#545 |
Oddometer: 73
4860 front assembly transplant on the 650X Ch
Walter, you mentioned your front forks "4860s were from a 640 Adventure". I was wondering, how complicated was the adaptation in the frame head... I contemplating a front assembly (fork, triple, wheel, calliper) and I found out the triple neck length is 185mm with a 52mm inside diameter of neck tube. Does that sound similar to what you have ?
12-22-2012, 01:51 AM
#546 | |
"Moto Porn"ographer
Oddometer: 3,831
You need the stem slightly longer for the XC than a standard KTM one (cant remember exact details ... maybe 5-10 mm) and it needed to be 28mm inside bearing diameter. The XC uses 28x52x16 bearings (which are quite common and easy to get at any bearing supplier) ... and a KTM stem is 29mm at the bearing points. You can get away with just machining down the KTM stem to 28mm but it really should have about an extra 5mm or so of length. Ideally get a machinist to make you a new stem.
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE World Motorcycle Altitude Record video HERE www.sibirskyextreme.com |
12-22-2012, 03:19 AM
#547 |
Oddometer: 836
The X steering head is the same length (185 mm) as the 650GS and the bearings on both are STD BMW
The comments earlier in the thread that the 4357's slide into the X yokes suggest that the X yokes would be a bolt on to the GS for any GS owner looking to fit 4357's. Dependent on the stock X forks they may also be able to be used. I always wondered about the steering head and yokes on the X This would potentially make GS owners a market for those here who have swapped out to other forks. The sticking points would be yoke width and yoke offset, I have not seen any info on those or the axle diameter for the X Anyone have yokes lying around and willing to take some measurements, I have an accurate yoke offset calc on line http://www.f650gs.crossroadz.com.au/CalcYoke.html |
12-24-2012, 11:13 PM
#548 | |
"Moto Porn"ographer
Oddometer: 3,831
Either way its not a show stopper. Quite a few folks have put KTM yokes and front wheel (at 190mm ) onto the XC. I remember mesuring with Adv forks and EXC triple clamps, the offset was about 2mm less than the XC stock ... meaning the bike was (slightly) even more stable than stock.
12-24-2012, 11:29 PM
#549 |
Oddometer: 836
Thanks for adding to the info
The GS forks are 185mm c-c spacing and accurate offset is 21 mm, there are other less accurate offset figures floating round The c-c width of the XC forks at 210mm would seem to be a bit wide to fit the GS unfortunately, I dug around and also noticed the offset ignition lock mount, that could also add to the difficulties. It was worth checking the figures though |
03-16-2013, 07:31 PM
#550 |
Oddometer: 73
final decision: WP 4860
After much deliberation, feedback from Jim @ Cycle Improvements and taking advantage of a visit south, I had my last change of mind in favour of WP 4860. This time is pretty final, as I just got them in for rebuild. They look a bit worn out, but I hope cleaning the sticker residue and changing the orange covers (with proper black ones) will fix some of that
![]() ![]() They were described as being "06 KTM 525 Exc forks, .48 springs installed and valved with race tech internals". Until the rebuild is done, I can only hope those mighty race internals (whatever that means) are in good shape. I also got the axle and calliper with bracket (as backup, as I knew the BMW calliper would have fitted). Next I need the complete triple clamp (got the lower one which is obviously not matching the upper stock one)... and an Excel A60 21" wheel ![]() Question is: can someone confirm the stock triple clamp offset (25 mm ?) vs acceptable KTM equivalent for 4860? Lukas was saying in #122: "KTM triple clamps have 20mm offset vs. the stock 25mm", but is that 5 mm variation in offset not without some instability consequences ?
03-16-2013, 08:10 PM
#551 |
Oddometer: 836
Offest is a pain to accurately measure, I created an online system of accurately measuring it as I kept hearing different figures for both the GS and WP forks, An ancient greek's triangle calcs makes it all easy, you can use it here http://www.f650gs.crossroadz.com.au/CalcYoke.html
03-16-2013, 08:31 PM
#552 | |
Oddometer: 73
Thanks Wayne!
I was hoping, though, someone would have the official factory offset spec, as it seems the precision in measuring "Distance to Post" (51) and "Post Hole Diameter" (32) is very important in that algorithm (a slight 1mm variation can throw the offset value by some 30%)... I may not have the right tools to measure precisely ![]() Quote:
03-16-2013, 08:44 PM
#553 |
Oddometer: 836
Yes, need a good vernier, WP stamp the offset on their yokes (18 & 20mm mostly) but other mfr's dont and the numbers quoted for the STD BMW yokes varied too widely between those measuring it, as did the the YZ figures quoted. The system I put online was the most accurate I could come up with and using a vernier I was able to get consistent figures cross checking the WP yokes I had access to and knew the offset for.
05-10-2013, 12:13 PM
#554 |
Oddometer: 850
Left damper unit
Need some advise from the wise...had my x-c in for fork seals and some other work and the tech called to tell me my left damper unit was pooched. The part from Max's is $350, plus shipping to me. Is there another solution? I'm not opposed to upgrading the forks with others, but I'm not sure of availability to locate replacement upgrades. Any suggestions?
5 weeks in Baja |
05-10-2013, 09:34 PM
#555 | |
Can I change this?
Oddometer: 278
There is no such thing as bad weather, only inadequate clothing. |
