12-10-2012, 07:28 AM
#4096 | |
Still pretty much a n00b.
Oddometer: 138
12-10-2012, 08:05 AM
#4097 |
Oddometer: 20
12-10-2012, 01:52 PM
#4098 |
Oddometer: 20
I think there are some american Pikes Peak owners here on this forum? You guys have them numbered over there, but nr.1 Pikes Peak you can`t find on your continent
12-11-2012, 10:52 AM
#4099 |
Oddometer: 286
A 2010 MTS owner checking in here, with nearly 21k miles.
A few days ago the bike has developed an unusual problem with multiple symptons. First, the black key no longer worked - bike didn't recognize the presence. So I changed the battery in the key. Still no go. I've tried more than one new battery. Second, the steering lock is no longer working. When I try to use the lock, very quickly an error code flashes - something about a red key not releasing. Third, the handlebar switch for turning the bike on and off no longer works. The gas tank on / off button still works, but it is intermitant. Or in other words it doesn't work in the same manner as before Lastly, the red ring no longer flashes like normal when the bike is off. Usually the red ring flashes every 15 - 20 seconds. Now it stays off completely or flashes at a much much longer interval. I'm thinking there is something wrong with the key receiver and or immobilizer. But what do I know? I'm just the rider. The inbuilt Battery voltage menu shows 12.6 volts. All this is coming exactly 1 month out of the standard Ducati warranty. I bought the "Ever Red" warranty just for this type of situation. I'll probably drop the bike off at the shop in the next few days depending on my schedule. I'll keep you posted on the outcome, especially on how the claim goes with Ducati's extended warranty program. "Ever Red". This will be my first experience with an aftermarket warranty. I don't think this hiccup will change my opinion of the bike. Still love it! |
12-11-2012, 11:01 AM
#4100 | |
regret minimizer
Oddometer: 621
2010 Ducati Multistrada Sport |
12-11-2012, 04:38 PM
#4101 |
Tarmac Adventurer
Oddometer: 2,000
Yeah, but did your ophthalmologist tell you that your distance vision and reading vision would be somewhat compromised with this arrangement? Definitely not as sharp as if you corrected both eyes for distance and used a pair of glasses just for reading!!!!
'13 Ducati Diavel AMG #163 '09 KTM 65XC (son's ride) Gone: '10 Ducati Multistrada 1200S, '11 BMW R1200GS, '10 BMW S1000RR, '08 BMW HP2 Megamoto, '07 KTM 950SMR, '05 BMW R1200GS, '94 BMW R1100R |
12-11-2012, 04:42 PM
#4102 |
270 deg crank
Oddometer: 103
Penny to a pound the bikes battery is cactus.
270 deg crank |
12-12-2012, 05:43 AM
#4103 |
Oddometer: 152
12-12-2012, 11:07 AM
#4104 |
Oddometer: 286
12-13-2012, 06:23 PM
#4105 | |
Choosing to be here.
Oddometer: 283
What you can do is a basic load test. Start the bike, and make note of what the voltage drops to when the starter is cranking the engine (you may need to use a multimeter for this). If it dips below 10.2 volts or so, then your battery may have an issue. But, if stays above, and then quickly shoots back up when the engine is running, then I think the battery is fine. But again, your symptoms sound nothing like low battery symptoms, but rather some kind of electrical gremlin elsewhere.
The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it. ― Terry Pratchett |
12-14-2012, 09:30 AM
#4106 |
I'm the Decider
Oddometer: 3,310
Does anyone know the status of the Ducati extended warranty programs today? I know the EverRed program has been dropped, but I was wondering if there was something in the works to replace it. My '11 goes out of warranty in a couple of weeks and since there's still nothing out there that I'd replace this bike with I'd like to get some sort of coverage, through Ducati if possible.
'11 Ducati Multistrada 1200S Sport "Stormtrooper II" '09 BMW HP2 Sport '98 Ducati 900SS Final Edition "The old whore" '93 Ducati 900SS "Slightly older whore" "Gentlemen. You can't fight in here. This is the War Room!" |
12-14-2012, 11:03 AM
#4107 | |
regret minimizer
Oddometer: 621
http://aftercareservicecontracts.com/
12-14-2012, 11:53 AM
#4108 |
Radical centrist
Oddometer: 21,234
In the thread for the new BMW's there was a discussion that the DOT wouldn't approve the LED turn signals in the USA so the bikes are being delivered with conventional lights but the parts counters will have replacement LED signals.
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
12-14-2012, 02:32 PM
#4109 |
...leave a trail
Oddometer: 49
[rabble rabble rabble] So the theory being that for some reason front LED turn signals are fine, but rear LED is just a bridge too far? I don't buy it. They're everywhere in cars. Why brake lights, but not turn indicators? You aren't even required to have indicators in most states! [/rabble]
12-17-2012, 05:40 AM
#4110 |
Oddometer: 286
Heard a cool rumor, as least it's cool for those of us with standard / base MTS. Ohlins will now make available manually adjustable shocks for the MTS. I also heard that Ohlins will also possibly make available an electronic shock and fork kit for the MTS which includes an ECU.
All this is due to fallout / chaning of S / Touring suspension from Ohlins to Skyhook. At least there's a benefit for us early adopters. Pesonally I'm interested in the manually adjustable shock and even better a manually adjustable fron fork set. I'd be in heaven with both. Come on Ohlins! There's only a few of us, but we're here and some of us are willing.
