Old 12-11-2012, 10:10 PM   #16
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 675
Harley dealer had every size I needed - 36 bucks for 8. Harley parts in my KTM - oh the humanity
folknride is offline   Reply With Quote
Old 12-11-2012, 10:20 PM   #17
rotarygirder
Oddometer: 21
I'm in the middle of my valve job right now. I tried to call a Harley dealer the other day to get individual shims and their parts department convinced me that valve shims did not exist, and I had to be thinking of valve guides.
After that conversation I went ahead and bought the Hot Cams shim set. All of the ones I will need measured within .015mm of their spec'd size, most were less than .005mm off. Not bad for $60, especially considering their size divisions are .05mm and now I have enough of these things to take care of both of my KTMs.
rotarygirder is offline   Reply With Quote
Old 12-12-2012, 06:40 AM   #18
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,307
The Harley guy last time I went in the there said, "you working on a KTM aren't you?"
"Yep, how'd you know?"
"No V-Rod guys here do their own valves, you KTM chaps are the only ones who ever buy them over the counter."
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 12-12-2012, 08:09 AM   #19
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Set the valves on the loose side. Get the shims spot-on with the aid of emery cloth:
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 12-12-2012, 09:01 AM   #20
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 675
The Harley shims measure pretty true - just one of the eight is about .01mm thin - so should be good - still within spec.
On another note, how much carbon deposit are folks seeing on the back of the valves? I've got some uneven (lumpy?) carbon on mine - not a ton but it's there. Everything else is clean after 30,000 km - plugs have normal deposit
Old 12-12-2012, 02:21 PM   #21
ElRod
4<2
ElRod's Avatar
Oddometer: 282
That's too funny......nearly word for word here at an H-D shop in Texas when I did my clearances last summer.
ElRod is offline   Reply With Quote
Old 12-12-2012, 02:44 PM   #22
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 691
Originally Posted by gozirra View Post
68 vs 41 degree fahrenheit, i think he listed celsius.
Indeed. 15 degrees.
uraberg is offline   Reply With Quote
Old 12-12-2012, 04:18 PM   #23
EatinDirt
WannaB Thumpin
Oddometer: 19
Roll that baby into the cabin where its nice n toasty your wife won't mind.
EatinDirt is offline   Reply With Quote
Old 12-14-2012, 12:43 AM   #24
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
Yeah, do some extra work to get them all on the loose end of the range. It'll run better. 30k is a good time to do this because they don't change much from here on out.
Honing them with sandpaper is only good for 0.001" (0.025 mm). You must start with 100 grit, then 200, 320, 500 and you may get only a small change.
For temp changes aluminum head will change more than the steel valve stem. At cold temps the clearance will be smaller, the alum shrinks more and pulls the cams closer to the valve seat. But, when the bike is running, the parts don't have the same temp. The alum head will only get to 200 deg F, but the valves may go to 300 F for the intake and sometimes 1200 F for the exhaust. This will close the clearances, much more for the exhaust. That's why it has more clearance to start with.
Humm, Kali. Doesn't suck much right now.
"Son, you can't do both"
Old 12-14-2012, 01:02 AM   #25
markjenn
Oddometer: 10,424
"Better" depends on what you're after. Wider valve clearances result in an engine with less valve lift and softer cam timing. This will tend to move the torque curve slightly lower in the rev range, but reduce high-end horsepower.
- Mark
Old 12-14-2012, 10:00 AM   #26
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 675
All done
Thanks for the advice guys. My fourth valve check/adjustment - you'd think I'd get faster .
With Harley shims I was able to set all the valves - intake at 0.13 - 0.14 and exhaust 0.27 - 0.28 - just below the loose end of spec.
I go slow so I don't do anything so the job, with oil change and coolant flush (replace with Engine Ice) and a few little tweaks like some new Doubletake mirrors spanned three days. When I read that folks do this in 4 hours, I think they must have different plastics than me - and don't get me started on throttle body removal and replacement. Don't get me wrong - I love my bike and enjoy my efforts at wrenching - but couldn't they have made some of this stuff easier to get at!
Bike started right up and runs great - California here we come.
Old 12-14-2012, 01:20 PM   #27
Douf
Limey Bitch
Douf's Avatar
Oddometer: 771
Depending on the actual materials and the geometry of the valve train, if you do the math it looks as though the temperature difference could have made a few tenths of a thou difference, which - based on the actual clearance tolerance range - is possibly more than insignificant.
http://www.engineeringtoolbox.com/li...ents-d_95.html
It's a pity you didn't ask about the Engine Ice too
Douf
Douf is offline   Reply With Quote
Old 12-17-2012, 08:57 PM   #28
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
Markjenn is right. For most people, starting easier, idling easier, better throttle response, more mid-range is better running. Most won't notice a 'little off the top' to get this.
Old 12-19-2012, 08:18 AM   #29
Black Hills
Oddometer: 1,183
when looking for shims talk to the guys in the shop, not the parts counter. Locally the Honda/KTM dealer just trades me what I have for what I need (if he has them). the local independant shop charges me $5/ea. and I keep the old ones..
Black Hills is online now   Reply With Quote
Old 12-19-2012, 02:59 PM   #30
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Record the clearances and changes you made.
Dont change the clearances significantly, you might get some surprises.
04 ADV 950
keener is offline   Reply With Quote
Times are GMT -7.   It's 08:42 AM.
