Old 12-12-2012, 06:46 AM   #16726
JaySee
Mofo
JaySee's Avatar
Oddometer: 128
You can also find shutoffs in the lawn and garden section at Home Depot and Lowes. Usually comes with about 10" of fuel line.
Jeff
'06 SV650
'08 KTM300xcw
'05 DRZ400s
JaySee is offline   Reply With Quote
Old 12-12-2012, 07:00 AM   #16727
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,689
also Advance Auto Parts....................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 12-12-2012, 07:09 AM   #16728
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 530
I not 100% sure but think I remember reading where someone had their stock petcock leaked through the vacuum line from the stock petcock which filled the cylinder with fuel. The leaking petcock's fuel did go through the carb but through the vacuum line to the cylinder.
So an in-line shut off would not help in this example. I believe that this is rare buts has happen before.
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is offline   Reply With Quote
Old 12-12-2012, 07:18 AM   #16729
Wlfman
Wlfman's Avatar
Oddometer: 1,288
Originally Posted by Bullwinkle58 View Post
I have spent some time on that forum. Those guys are nuts. They have strictly supermoto guys talked into running full coverage skid plates & bark busters.
Everything they & their parrots reccomend is absolutely mandatory for all drz's, otherwise your bike will blow up or fall apart.
I admit though, if you have a problem you can't figure out, there is someone over there who knows, and they'll blame your lack of manual cam chain tensioner, case savers, or radiator guards.
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 12-12-2012, 07:41 AM   #16730
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by 150ron View Post
You see part number #18 in this chart
https://www.thumpertalk.com/shop/oem...007&model=5203
its that little o-ring that sits around the valve seat, i removed the valve seat and the o-ring was completely flat, took it with me to orielly auto parts and found one that looked the same, that fixed up the problem, but just to be safe, i now turn the fuel to the OFF postion when the bike is gonna be sitting for a few days or so.
I will probably pick up a spare over the winter then
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 12-12-2012, 07:45 AM   #16731
Oddometer: 532
Originally Posted by ifixfords View Post
Call me crazy, but I turn my fuel off every night. It can easily fill the cylinder overnight. Keep fuel out of the engine, check your oil and coolant on a regular basis. Your DRZ will last a very long time.
DRZ400E Tagged
KTM200XC-W ""
Well we could call you crazy if you want us too
But although I try to remember to turn mine of after riding, us old farts sometimes forget
So it can be an issue even if you think you are conscientious about that little old gas tap
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager screwed with this post 12-12-2012 at 07:52 AM
Old 12-12-2012, 07:55 AM   #16732
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
But although I try to remember to turn mine of after riding us, old farts sometimes forget
Not remembering to shut the petcock off is just like forgetting your wife's birthday. Think of it that way... They both can cost you a lot of money. Treat this issue just like you did 2 stroke fuel taps in the 60/70s. If you make it a habit just like taking out the key it helps. I do the same thing when I start up the bike....habitturn it back ON. If you have a furnace in your garage you do not want gas on the floor under your bike. Friend of mine lost his garage ,tools, and 5 vintage Bultacos making that mistake one time.
buls4evr is offline   Reply With Quote
Old 12-12-2012, 02:47 PM   #16733
Oddometer: 532
Ah but in the 60/70s I had a memory that worked
So maybe a sticker on the gas tank for us old farts EH!
KLR 650-sold
1977 BMW R100-sold
Old 12-12-2012, 03:04 PM   #16734
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,237
Jeebus! You remember the 70's?
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 12-12-2012, 05:39 PM   #16735
Oddometer: 532
Are you kidding I remember the 50's
KLR 650-sold
1977 BMW R100-sold
Old 12-12-2012, 05:42 PM   #16736
Ryel
Ryel's Avatar
Oddometer: 236
some memories are better then others but it is odd that the '50s seem more real then the '80's.
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is offline   Reply With Quote
Old 12-12-2012, 05:51 PM   #16737
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,731
Guess I should post up and introduce my newest ride here....
Via ADVrider and the wonderful fleamarket thread I found a perfect way to upgrade my Trifecta
I found an inmate looking to get rid of his DRZ 400 and get a KLX250 at the same time I was looking to go from my KLX250 to a DRZ 400....
So we worked out the details to meet up in South Carolina for the swap
Rolled out the driveway and headed south around 5am
Met up with Paul in Greenville, SC just after lunch and swapped out
It was a long day of driving...but worth it
(driveway pictures were from the next day...we made it home just in time to not turn into a pumpkin. 870 miles in about 18 hours )
Now for a bit more fun in the dirt....the KLX was a good bike, but I need something a bit more off-road savvy
EOD3MC is offline   Reply With Quote
Old 12-12-2012, 06:10 PM   #16738
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,617
The '50s were more real then the'80s.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
I got a chill standing outside wiggling wieners.. - LadyDraco
There is no odometer when it comes to pie - VACommuter
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 12-12-2012, 06:26 PM   #16739
150ron
150ron's Avatar
Oddometer: 1,305
congrats on the new bike EOD3MC, looks great, and looks to have some great upgrades on it.
Just some dude...
150ron is online now   Reply With Quote
Old 12-12-2012, 07:12 PM   #16740
DR-Zamboni
DR-Zamboni's Avatar
Oddometer: 99
this may be a stupid question, but EOD3MC.... hows that sport bike style swing arm stand rigged up to the DRZ? I've never seen that on an enduro before. Are there spindles threaded into the swing-arm? I have an old set of stands for my GSXR collecting dust since i sold the bike, it would be nice to rig them up to the DRZ for when i do work.
DR-Zamboni is online now   Reply With Quote
Times are GMT -7.   It's 11:57 AM.
