Old 12-04-2012, 02:35 AM   #106
markie_wales
Oddometer: 878
1) strength is really good. Been down on rocks a few times, and although not cosmetically pretty still 100% on protection.
2) using RTV sealant was not such a good idea. These tanks "breathe" fumes and one of mine simply fell off while riding. Spent ages looking for it but it's gone for good :( There was no sealant stil on the tank, the vapours had lifted it off & I guess it was all still on the cover. I have now taken my other off, re-RTV'd it, but also put some gaffer tape around the edges (and under the tank, orange cover) to stop the last one going walkies when the vapours release the sealant again.
I'd buy another set (or just the one) if they were cheap, but what with import duties it's just too spendy for my right now.
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
- Only bikers understand why dogs like to stick their heads out of car windows.
markie_wales is offline   Reply With Quote
Old 12-04-2012, 07:38 AM   #107
Cyclops Motorsports
Cyclops Motorsports's Avatar
Oddometer: 945
cheers
Markie
Great feedback Mark..Ill send you another at no charge for the part. Please PM me for details.
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 12-05-2012, 05:32 AM   #108
markie_wales
Oddometer: 878
Well thank you - that is a very generous offer - PM sent!!
As I said above - can thoroughly recommend the guard for strength, we just need to be a bit more careful on fitting, or check the RTV sealant I think.
see there are people who "get" Customer Service
cheers
Markie
Old 12-05-2012, 07:57 AM   #109
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 99
I have had the same luck RTV Adhesive brand new tank I sanded the tank to rough up the surface so it would stick better. They stayed on for about 2000 miles 1 feel off in my garage and the other on the road. I was riding with a friend and lucky he saw it fall off. Try #2 I wire wheeled all the RTV off the covers and then tried to refit with 3m molding adhesive looks like it may work better but the covers don't fit the tank very well I don't know at this point how to get them to stay on.
before the RTV adhesive I also tried 3m double sided molding tape. Same thing i used on my swing arm covers and stock tank guards It wouldn't stick to the Safari tank.
Let me know if anyone comes up with a solution.
SE Steve is offline   Reply With Quote
Old 12-05-2012, 08:17 AM   #110
LukasM
Oddometer: 4,942
Was that standard 3M stuff or their VHB tape? The latter really does have a very high bond, but with gas fumes nothing will be easy.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 12-05-2012, 08:26 AM   #111
Cyclops Motorsports
Oddometer: 945
We pulled the molds staright from a safari tank. is it possible that a tank can distort a bit?. All the ones we fit up seamed to fit very well.
Ill look into other adhesives.
Old 12-05-2012, 05:59 PM   #112
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 99
They fit well when I first put them on. I think the tank must have expanded or something. Maybe I was to aggressive when I was cleaning the RTV off. I cleaned the clear coat off and they look really cool just need to figure out how keep them on.
Old 12-05-2012, 08:21 PM   #113
Cyclops Motorsports
Oddometer: 945
I didn't see this coming. sorry guys, I made a bad recommendation and will replace missing guards at this point.for a limited time, now is your chance to check them and replace the adhesive with something more suitable, If you lost a guard Pm me..
. My ADV tank that my guards are on is painted so no issue.
I just got this off the net.
Permatex® offers the solvent based Form-A-Gasket® products or MotoSeal® #29132 [hyperlink to 29132 product page] that are designed for applications in a gasoline environment.
Old 12-05-2012, 09:23 PM   #114
Riddler990
I Suck, You Rule.
Riddler990's Avatar
Oddometer: 494
Another product to try is Permatex "the right stuff" found at any auto supply house. Has solved many sealing issues on my cars, valve covers, valley pans etc. It is not as slick as rtv, stays in place really well. Seems to be a better "glue" than silicone. I used it on my set from CMS, although I can't attest to how well it's holding up as the tank has been sold off. I did however use the same "right stuff" on a set of Carbon Works CF guards for a stock SE tank and they are holding up with no issues.
Riddler990 is offline   Reply With Quote
Old 12-10-2012, 05:45 PM   #115
mattc
mattc's Avatar
Oddometer: 404
Riddler, I think I bought your tank with guards. They are still in place, and the goo holding them on looks solid. No signs of them coming off.
2008 950 SE-R
2000 XR650R
2001 CR250R
1983 ATC200E
mattc is offline   Reply With Quote
Old 12-11-2012, 08:12 AM   #116
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 99
I think the guards are great quality. Just need to figure how to stick them on. I don't know what the tanks are made of but nothing sticks to mine every sticker I have put on has pealed off.
Old 12-12-2012, 03:18 PM   #117
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,152
I pulled pretty hard on mine the other day (once I saw this thread again).... they are still stuck on nicely.
traveltoad is offline   Reply With Quote
Old 12-12-2012, 07:48 PM   #118
Cyclops Motorsports
Oddometer: 945
Good to hear Traveltoad. I also checked a local riders tank out and no issues. It looked as though it would be tough to pull them off.
We used an empty tank, and acetone to clean the spot where the guards where to go..Tough stuff was our adhesive. We used enough that it oozed out the sides a bit and had to be cleaned off.
Old 03-20-2013, 03:40 AM   #119
markie_wales
Oddometer: 878
Just got to say a big "bloody well done" & thank you to all those at Cyclops Motorsports and Daryl in particular. He's been in constant contact and also managed to source me some petrol resistant sealant I was struggling to get in the UK and it came through recently.
This is a man/company who stands by it's products and clients when things go a bit astray. I wouldn't hesitate to recommend the guards or doing with the business with them - they get customer service!
cheers
Markie
Old 03-20-2013, 11:14 AM   #120
Cyclops Motorsports
Oddometer: 945
cheers
Markie
Thanks for the kind words, Sir
Times are GMT -7.   It's 11:09 PM.
