Old 12-12-2012, 10:58 AM   #1
motoretro OP
Oddometer: 495
Vintage Motor Scooter Battery Charging and options
Please Delete
motoretro screwed with this post 02-18-2015 at 08:10 AM
motoretro is offline   Reply With Quote
Old 12-12-2012, 12:34 PM   #2
dmn0507
dmn0507's Avatar
Oddometer: 352
I wouldnt mind charging a standard 'flooded' battery with caps off, unless you want to weld or grind stuff while charging it.
Except for the first charge, the vent hose it's enough for a slow charge to top-up the battery, so no need to open caps.
I charge my car batt. with an electronic charger, max output 3.8A and they never bubble.
dmn0507 is offline   Reply With Quote
Old 12-12-2012, 12:44 PM   #3
RVDan
RVDan's Avatar
Oddometer: 2,635
I'm constantly charging Rv batteries in my shop at high charge rates, multiple at a time. Not a big deal. They don't constantly offgas as you suggest, and such a small battery will charge fairly quickly, it really won't vent a significant amount.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 12-12-2012, 01:17 PM   #4
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,269
How much battery do you need? Could you use a "stick" of NiCad's instead of a regular battery? Less weight, space and no out-gassing.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 12-12-2012, 02:18 PM   #5
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,269
What kind of scooter is this? Does the scooter have electric start? If it does, scratch the ni-cads. Does your headlight only run when the engine is running? What is on/working when the key is on/engine off vs. key on/engine on?
1991 Honda XR628R
1978 Yamaha XT500
Old 12-12-2012, 03:28 PM   #6
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,669
Check the specs on your OEM battery cable. Big doesn't mean it has much wire in it. Recently cut into an old one....lots of rubber sheating, not much copper, about 10Ga to my eye.
BTW that type of battery you are contemplating with the wires built in, often used in old 6V BMW motorcycles.
Like this:
http://bmwdean.com/6_Volt_Battery.htm
Fuse it to be on the safe side, altough if you think you may blow the fuse troubleshooting, I'd use something like that:
http://www.grainger.com/Grainger/COO...-Breaker-6AYJ4
Thread worthless without pics....I want to see the old scooter.
Have tools, will travel!
Old 12-12-2012, 06:42 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,669
Left ooops edit, long day...RIGHT click on any pics if they are online somewhere, open "properties" then copy/paste the URL in the window that opens when you click on the yellow mountain/sun icon above. May have to click delete first to get rid of the Http:// thing in the window.
I know what you mean with translating German, often comes out weird with online translations . Then I go to my German neighbor, old retired mechanic, good for them technical terms.
Nice scooter...! Got to wonder now if they looked at some Buicks for the portholes.
H96669 screwed with this post 12-12-2012 at 07:27 PM
Old 12-12-2012, 08:56 PM   #8
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,269
That's cool! I'm guessing this is the grandfather of Maico motorcycles.
1991 Honda XR628R
1978 Yamaha XT500
Old 01-06-2013, 11:56 AM   #9
redprimo
Oddometer: 461
The 6v batteries I get are shipped to me dry and then I add the acid and charge them up. I pull the caps off for the initial charge and after that for maintianance charging I leave the caps on and let it vent through the vent tube. Ive not had any problems doing this, but I also don't have my batteries charging below my welding bench.
redprimo is offline   Reply With Quote
Old 01-06-2013, 06:55 PM   #10
S/W
S/W's Avatar
Oddometer: 390
6v wire size
When I was just out of High School in the late sixties, my first job was in an auto electric shop. There were still a lot of cars running around with 6 volt systems left over from the 50's. The boss made sure I understood that I had to use heavier gauge battery cable for the six volt systems,as the lower voltage needs more conductor because the amperage is higher for the same power.
S/W is offline   Reply With Quote
Old 01-06-2013, 07:47 PM   #11
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,010
http://www.amazon.com/Panasonic-LC-R...ges/B009DKCX62
will one of these unit do? I had 12 volt one and there was no issues beyond making up a leads to the battery . seal units.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 01-07-2013, 01:24 PM   #12
JerryH
Oddometer: 5,069
That is a beautiful old scooter. I don't think I have ever seen one of those before. If it has no electric starter, it should be easy to convert it to 12V and keep the 6V electrics with a step down transformer. It most likely will need to be a motorcycle/scooter battery, the headlight can still draw quite a bit of current.
But, you can charge an old style flooded battery without removing the caps, as long as you don't try to charge it to fast, which can damage the battery anyway, they do have a vent. My Genuine Stella is 12V, but it came with an old fashioned flooded battery. It is still holding up, so I have not replaced it. I keep it in my living room with a Deltran battery tender hooked to it, with the battery in the scooter, and all the covers on. I have a pigtail wired to the battery, and just unplug it and plug it back in when I ride it. I have 2 other scooters in the same room hooked up the same way, but with sealed batteries. I would only charge it outside or in the garage, but a battery tender does not have enough power to hurt anything, even if the battery shorts out. They automatically shut off if that happens.
JerryH is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
