Old 12-11-2012, 04:46 PM   #4516
Stinky151
Oddometer: 128
The biggest thing is that if you decide to do a 685 kit (or alone those lines) I think you need a different cylinder. Beyond that, check the doohickey and broken/missing bolts, and ride the wheels off it. As far as parts, very little has changed on these bikes in 25 years. Finding parts really isn't an issue.
Lincoln
"Motorcycles are no more dangerous than cars, they are just less forgiving of mistakes"
Stinky151 is offline   Reply With Quote
Old 12-11-2012, 05:26 PM   #4517
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 672
KLR FAQs
Originally Posted by KJD19892 View Post
So sorry to interupt the gas mileage conversation but I'm needing some advice. I've been looking for a new dual sport bike because my 95 dr bit the dust a couple months ago. Today a guy came into our store and mentioned that he's wanting to sell a 95 KLR 650. 11,000 miles, its supposed to be in pretty good cosmetic shape and has new tires. I know it has a dead battery but thats not a big deal, I bet the battery off my DR would fit it actually. So my question, Buy it or no?? He's wanting 1000 but I'm sure I can get it for 800 which sounds like a good price to me. I don't like having a bike thats gonna need a lot of work though so what do I really need to watch out for on this bike? The DR had a big overhaul in 96 so used parts were nearly impossible in this area. Did KLR's have anything like this? So pretty much any advice would be great!
This is well worth reading: http://www.bigcee.com/klr650faq.html#knownissues
I would pull the valve cover, check the valve clearances and pull the cam bearing journal caps one at a time to ensure they're still in good shape. There's some pics in this thread showing what it looks like when the journals start galling: http://www.advrider.com/forums/showthread.php?t=671941 If the cam bearing journals are showing signs of galling, repair is very expensive (requires a new head). I guess what I'm trying to say is that what initially might appear to be a good deal may not be if you need to throw a lot of money at it later.
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned:
- '91 Honda GL1500 Goldwing with CSC Friendship sidecar (highway pig),
- '92 Kawasaki KLR650 with DMC Enduro sidecar (country cruiser).
GreatWhiteNorth is offline   Reply With Quote
Old 12-11-2012, 06:21 PM   #4518
GAS GUY
GAS GUY's Avatar
Oddometer: 2,043
Actually,1996 got the newer cylinder and other updates.
Its 1996-2007.
2008 KLR 705
2001 GAS GAS 321
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 12-11-2012, 06:38 PM   #4519
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,422
Provided it doesn't need anything, $800-1000 for a runner ain't bad.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 12-11-2012, 07:29 PM   #4520
MC-Shifter
aka Shifter
MC-Shifter's Avatar
Oddometer: 218
The conclusion: There was still air in the system. We took the lever off. Used a 1/4" ratchet extender to push the piston farther than the lever was capable of. There was basically about an 1/8" of travel. Once that pushed the rest of the air out, we continued a couple more pumps and pressure built right up.
The really good news is that it was all worth it because this new CZR system is much more powerful than my stock system was.
Thanks to all for the help.
Originally Posted by MC-Shifter View Post
Thanks flea market.
MC-Shifter is offline   Reply With Quote
Old 12-11-2012, 08:50 PM   #4521
Aprilia
Oddometer: 340
Its 1996-2007.
You are correct...too much traveling lately and brain is not working correctly. I nuked my post as a result
Aprilia is offline   Reply With Quote
Old 12-12-2012, 07:27 PM   #4522
GAS GUY
GAS GUY's Avatar
Oddometer: 2,043
http://www.advrider.com/forums/showp...postcount=3936
Check out this guy.
2008 KLR 705
2001 GAS GAS 321
Old 12-13-2012, 05:10 AM   #4523
Danger4u2
KX & CR 500 Rider
Danger4u2's Avatar
Oddometer: 312
"She's seen 122mph on flat ground many times (verified off other bikes)"
A land speed record on a KLR yea right.
http://www.youtube.com/watch?v=evOOEnOYuOk
Go faster than everyone.
Only worry about what's in front of you.
'08KX500AFC(my favorite) '07KLR650
'04KX500(street legal) '97CR500R
'06KLX250(351cc kit) '08KFX450R quad
Danger4u2 screwed with this post 12-13-2012 at 08:09 AM
Danger4u2 is offline   Reply With Quote
Old 12-13-2012, 08:02 AM   #4524
fleshpiston
fleshpiston's Avatar
Oddometer: 507
Ok, a question for the KLR electrical gurus......
According to the factory and Clymer manuals there is a yellow/black wire running from the CDI to the starter relay. This is only present on 1990 and later models.
What purpose does it serve, and will there be any issues running a 96 harness (with the wire) on an 89 motor????
Thanks for any input.
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 12-13-2012, 08:24 AM   #4525
XDragRacer
Oddometer: 2,024
Can't be definitive, but . . . on this wiring diagram http://www.wiringdiagrams21.com/wp-c...ng-diagram.gif , BLACK/YELLOW is a common connector to the battery negative terminal, or GROUND. Don't know if, prior to 1990, other ground connections were used for the CDI and for the starter relay; the wiring diagram linked shows YELLOW/BLACK as a shared battery negative connection, throughout the wiring scheme.
Before you swap out wiring harnesses, I'd suggest you take your ohm-meter and run a continuity check between the CDI and the starter relay connections and ground, with and without the BLACK/YELLOW wire connected to each terminal. If the terminals show continuity with ground without the wire, looks like machts nichts to me, suggesting the '90-and-later connection might be for redundancy and insuring a low-resistance path to ground. Postulation and inference, only!
XDragRacer screwed with this post 12-13-2012 at 08:31 AM
XDragRacer is offline   Reply With Quote
Old 12-13-2012, 08:43 AM   #4526
fleshpiston
Oddometer: 507
But very much appreciated
That diagram looks very different from the one shown in the Clymer... they show it as being a direct connection, not tied into the normal ground circuit
SRX600
SRX250
SR500
KLR650
Old 12-13-2012, 08:56 AM   #4527
CA Stu
CA Stu's Avatar
Oddometer: 42,650
Here is a great wiring diagram link
It's a ground.
CA Stu is offline   Reply With Quote
Old 12-13-2012, 09:24 AM   #4528
mcpenner
mcpenner
Oddometer: 122
Speaking of wiring, I was looking behind my fairing (05 klr) and noticed two open wires with connector plugs. Are these open and available to connect things to? If no, what is missing on mine. If yes, can I use them for lights of usb charging port or ??
mcpenner is offline   Reply With Quote
Old 12-13-2012, 09:32 AM   #4529
Grinnin
Forever N00b
Oddometer: 1,605
They're for the "city light" on the European versions. They ARE available. One is positive and one is ground. The positive is switched with the ignition.
I use mine to turn on a relay in my extra dashboard The relay controls a larger-gauge circuit and provides power to GPS, jacket, etc. that I don't want powered when I turn off the ignition. If it was only USB (5V, .5A or 1A) I'd connect the two city-light terminals directly to the USB converter.
Motorcycles are magical.
Grinnin is offline   Reply With Quote
Old 12-13-2012, 09:41 AM   #4530
mcpenner
mcpenner
Oddometer: 122
[QUOTE=Grinnin;20240898] They ARE available. One is positive and one is ground. The positive is switched with the ignition.
Thanks Grinnin, that makes me happy I was about to start wiring up from the battery to install a charger and a plug for my vest. So much easier. How much can those little wires take? I think my max would be electric vest, GPS or phone, and heated grips??
Times are GMT -7.   It's 11:05 PM.
