12-12-2012, 08:13 PM
#91 |
BAN - Born Again Noob
Oddometer: 5,425
The maximum braking
The maximum braking allows to achieve the maximum deceleration, that is: ![]() The deceleration is a function of the wheelbase p, of the vertical h and horizontal position of the center of gravity and of the coefficients of friction, not of the vehicle mass. The ratio between the front wheel braking force and the total available braking force depends only from the geometrical properties and the coefficients of friction: Figure 6. Deceleration lines and braking ratio wheelbase p=1.4 m; height of the center of gravity h=0.7 m; horizontal position of the c.o.g. b=0.7 m The above figure shows that the deceleration increases with the coefficients of friction. Due to the load transfer the front wheel braking force is bigger than the rear wheel braking force. The braking ratio between the front and the rear wheel are expressed by the red lines. The horizontal axis represents a rear wheel only braking condition; the vertical axis a front wheel only braking condition. If the coefficients of friction are low, the importance of the rear braking force is not negligible, as in high friction condition. The maximum deceleration before the forward tilting is 1 g. As an example consider braking a vehicle with a deceleration equal to 0.5g; it is possible to reach the desiderate decelerationusing different ratio braking. Braking using the front wheel only, requires a front coefficient of friction equal to 0.68 (point A). If the used braking ratio is 80% on the front wheel, 20% on the rear wheel, the same 0.5g deceleration requires a front coefficient of friction equal to 0.55 and equal to 0.4 on the rear wheel (point B). Which is then the optimum braking to achieve the 0.5g deceleration? If the maximum coefficients of friction are the same for both the wheels, Figure 7 shows that the maximum deceleration is achieved when both the tires are used in the same way. As an example consider a coefficient of friction equal to 0.8 for both the tires; the maximum deceleration (0.8g) is achieved with a braking ratio equal to 90:10. Using the front brake only, the maximum deceleration is equal to 0.67g; using only the rear brake is equal to 0.29g. In slipping condition the coefficient of friction is equal to 0.4, the maximum deceleration is equal to 0.4g and the optimum braking ratio is 30:70. Se il fondo stradale è più scivoloso e i coefficienti di aderenza di entrambe le ruote risultano pari a 0.4 la frenata ottimale si ha con una diversa ripartizione (30/70) e fornisce una decelerazione pari a 0.4 g. The 45° line represents the condition mf= mr and is the optimum braking; this line intersects different braking ratio lines as function of the desiderated deceleration. Figure 7. Braking action of dry(0.8) and wet(0.4) surfaces Figure 8 shows that the optimum braking line is tangent to the 50:50 braking ratio; it do not intersect the ration curves with the rear wheel braking force bigger than the front wheel braking force. The above consideration is valid even if the static load is bigger on the rear wheel. The optimum braking line is always tangent to the ratio curve having the same values of the static loads ratio. As an example, if the static loads ratio is 45:55 (45% on the front wheel, 55% on the rear wheel), the optimum ratio curve is the 45:55 and is tangent in the origin to the optimum braking line. Figura 8. Braking action of dry(0.8) and wet(0.4) surfaces wheelbase p=1.4 m; height of the center of gravity h=0.7 m; horizontal position of the c.o.g. b=0.7 m or. put another way. use both brakes to maximise braking.
Planning NA 2010 NA 2010 Adriatic Loop August 09 Mandello Guzzi Protest Sept 09 "I've got the key to the gates of paradise...but I've got too many legs!!" Jeff "Civilized men are more discourteous than savages because they know they can be impolite without having their skulls split, as a general thing." -- Robert E. Howard |
12-12-2012, 08:16 PM
#92 | |
Oddometer: 1,376
1. You're added _twice_ the amount of task for stopping you now need to manage 2 separate brakes systems and tire level tractions. 2. The majority of the bike's stability is coming from the gyro of the running engine and the spinning wheels. If you lock the front and the engine is still spinning and the rear tire is still turning you have a very good chance of reducing pressure and riding out of it because the bike is still stable and tracking straight. You lock the rear which is very easy to do while hard on the front and kill the engine you've lost much of your stability and your ability to re-accelerate and if you then lock the front on top of that the bike is completely unstable. To avoid killing the engine you now need to manage a 3rd control. The nature of an emergency is that you aren't planning for it. It's hard to properly modulate 7 controls (front brake, rear brake, clutch, steering, body position, throttle) during a full on stop when doing planned full on stop, like on a race track. It's going to be damn near impossible to pull it off when you didn't except it, because face it. If you where in a position to do it all right you'd not be in an emergency stop because you'd have seen it coming and already taken action to avoid the situation. |
12-12-2012, 08:35 PM
#93 | |
Oddometer: 75
^ this....
I ride what I want and I want many rides. |
12-12-2012, 09:00 PM
#94 |
Oddometer: 7,707
Bullshit!
You do not need to assign a false fixed percentage to it... Sound familiar?
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
12-12-2012, 09:21 PM
#95 | |
In the Dark
Location: way back up in the woods among the evergreens
Oddometer: 179
If you were 100% sure that you were doing the exact right thing by teaching your girlfriend to brake this way, you wouldn 't have posted up asking for everyone's opinions (unless you were just trying to stir the pot). You've heard many opinions, most of them telling you that you are wrong, but some that agree with you. Since you're not going to get any consensus here, and since you're not 1000% sure....my recommendation to you is to quit teaching your girlfriend and let a professional instructor do it. Good luck. |
12-12-2012, 09:25 PM
#96 | |
Oddometer: 28
Thanks. This is really educational and useful. And I think it ends the argument.
12-12-2012, 09:32 PM
#97 | |
Oddometer: 1,376
http://dinamotoweb.dimeg.unipd.it/di...%20Beijing.pdf "Figure 3 (a) shows that the optimal braking maneuver (dash line), which uses also the rear brake, is able to reach the ellipse of adherence, except when stoppie condition occurs. There is a net gain in the maneuver performance which is quantified by the highlighted yellow area in the Figure. However, the optimal braking strategy acts to the tire limits and including the fact that the load torque of the engine in many cases is high enough to lock the rear wheel, only few racing riders are able to put into practice this optimum braking strategy. The same cannot be said for acceleration maneuvers since traction force is only available at the rear wheel." Now make sure you properly read figure 3a because for straight up and down braking it shows stoppies occurring meaning there is no gain from rear brake usage. crofrog screwed with this post 12-12-2012 at 10:17 PM |
12-12-2012, 10:01 PM
#98 | |
Oddometer: 1,376
Pro-racers have problems accurately modulating both brakes but n00bs in a 2 day program can learn it easily right? So which is it MSF the program is so basic and the riders skills are so low that you don't have time to teach things like trail braking. Or the program is so good that it can teach "advanced skills" like accurate rear brake usage? Or your program is so cruiser oriented that it's under serving the sport bike community. The study shows that both brakes provide .3 seconds better braking performance from 300km/h which is about 23ft. That's entirely because at high speeds aerodynamic forces. The cross over point occurs at 200km/h above 200km/h the aerodynamic forces keep the rear down and front tire traction is the limiting factor, below that speed rear wheel lift is the limiting issue. |
12-12-2012, 10:23 PM
#99 | |
Oddometer: 442
04 KLR 650 07 KLR 650 06 sv650s 07 Ducati Monster |
12-12-2012, 10:47 PM
#100 | |
Oddometer: 1,226
PhilB
1993 Ducati M900 Monster "Patina" (206,000 miles, so far) -- 1995 Ducati M900 (wife's bike) -- 1972 Honda CB450 (daughter's bike) -- 1979 Vespa P200 (daughter's scoot) -- 1967 Alfa Romeo GT Jr. (1300cc) -- 1964 Vespa GS160 (160cc 2-stroke) -- 1962 Maicoletta scooter (275cc 2-stroke) -- 1960 Heinkel Tourist 103A1 scooter "Elroy" (175cc 4-stroke) |
12-12-2012, 11:07 PM
#101 | |||
Oddometer: 1,226
In a literal sense, the clutch comment is from the fact that engine braking usually involves downshifting, which involves the clutch and more specifically involves modulating the clutch with some slip as you re-engage it after the downshift so as not to break the rear wheel loose. Which does cost some clutch wear. More generally, engine braking involves reversing the stresses on the entire drivetrain, and pushing backwards on everything, which really isn't a great idea. So for best care of the bike, it's better to not do a lot of engine braking, and if you want to apply some braking force at the rear, use the rear brake, as that's what it is designed for, and not the engine, which is not optimized for that purpose. Quote:
And no, if you lock the front and are less than a supreme expert, you are falling down regardless of what the rear is doing. So you won't have a worse time at all if both lock vs. just the front. Nope. Wrong. Fail. Quote:
PhilB
1993 Ducati M900 Monster "Patina" (206,000 miles, so far) -- 1995 Ducati M900 (wife's bike) -- 1972 Honda CB450 (daughter's bike) -- 1979 Vespa P200 (daughter's scoot) -- 1967 Alfa Romeo GT Jr. (1300cc) -- 1964 Vespa GS160 (160cc 2-stroke) -- 1962 Maicoletta scooter (275cc 2-stroke) -- 1960 Heinkel Tourist 103A1 scooter "Elroy" (175cc 4-stroke) PhilB screwed with this post 12-12-2012 at 11:16 PM |
12-12-2012, 11:12 PM
#102 | |
Oddometer: 1,226
PhilB
12-12-2012, 11:18 PM
#103 | |
Oddometer: 4,675
I've seen a Heritage Softail with its ass 4 feet in the air. For that matter the with the ABS touring bikes ...good luck stopping on a CBR as fast as one of those things.So far as it goes a buddy who had his rear brake fail in a race "For something that I never use, I sure as hell missed it when it wasn't there." and it wasn't like he went offroading, he finished 2nd. |
12-13-2012, 12:21 AM
#104 | |
Oddometer: 9,294
Rob '07 White (the coolest color) GSA rider '13 Husky Strada & '05 Honda 400XR
12-13-2012, 12:25 AM
#105 | |
Oddometer: 4,675
You can recover the front, but its a bit hairy, and the faster you are going the more time you have to correct it. ....assuming you are straight up and down. Because if you aren't that is about the fastest way I can think of to break a collar bone. On the street anyway, in dirt, meh, you plow the front end all the damn time anyway. |
