Old 12-12-2012, 08:37 PM   #16741
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by Ryel View Post
some memories are better then others but it is odd that the '50s seem more real then the '80's.
Yes no rationing in the 80's
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 12-12-2012, 09:36 PM   #16742
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by EOD3MC View Post
Guess I should post up and introduce my newest ride here....
Via ADVrider and the wonderful fleamarket thread I found a perfect way to upgrade my Trifecta
I found an inmate looking to get rid of his DRZ 400 and get a KLX250 at the same time I was looking to go from my KLX250 to a DRZ 400....
So we worked out the details to meet up in South Carolina for the swap
Rolled out the driveway and headed south around 5am
Met up with Paul in Greenville, SC just after lunch and swapped out
It was a long day of driving...but worth it
(driveway pictures were from the next day...we made it home just in time to not turn into a pumpkin. 870 miles in about 18 hours )
Now for a bit more fun in the dirt....the KLX was a good bike, but I need something a bit more off-road savvy
Looks like the plan came together for both of you...
bobbed06 is offline   Reply With Quote
Old 12-12-2012, 09:40 PM   #16743
bobbed06
Oddometer: 1,236
I keep getting bits and pieces of the Mid 90s, I sure wish I would have had a digital camera to help remind me what happened.........Bad thing is I am only 35
Old 12-13-2012, 06:19 AM   #16744
Creeker747
Creeker747's Avatar
Oddometer: 274
Question Yoshimura RS3 Full Exhaust (Used)
I am looking to buy this used Yoshimura RS3 exhaust. The seller says it is for a DRZ and is titanium. When I look at the pictures I have a few questions:
1. The exhaust canister looks from the picture more like aluminum?
2. The bolt patterns all seem to jive with my DRZ400s in that this full system will be able to accept the stock heat sheild as I understand it. However, there's a black collar that I am not too clear about it's purpose. Maybe it clamps the section inserting to the pipe?
The seller says that he took it off his 2001 DRZ and put back the stock pipe because he didn't have the 3x3 mod and carb jetted.
Please comment if you have an idea about these questions, and it's value?
Thanks!!!
Creeker747 is offline   Reply With Quote
Old 12-13-2012, 08:33 AM   #16745
150ron
150ron's Avatar
Oddometer: 1,315
Looks to be in great shape, how much is he asking for it?
BTW, that is a OLD system.
Just some dude...
150ron is offline   Reply With Quote
Old 12-13-2012, 09:24 AM   #16746
Pauls2ndblessing
Oddometer: 99
Ah.. that balding spot seems to be more prevalent than I remember
It was good meeting you Dave, I believe we are both extremely satisfied with our swap. Can't wait to see what your next plans are for the DRZ, I frequent this thread so I'll be able to keep up with it!
Lots of plans for the KLX
Pauls2ndblessing is offline   Reply With Quote
Old 12-13-2012, 10:29 AM   #16747
Creeker747
Creeker747's Avatar
Oddometer: 274
I pulled the trigger, and bought it this morning for $160. Seemed like a good deal. I will put it on this weekend and see how things work out.
Old 12-13-2012, 10:36 AM   #16748
jordan p
projects > time alloted
jordan p's Avatar
Oddometer: 128
even though it was 36 degrees this morning, I had to ride to work because I jetted and 3x3'd my box the night before. I almost forgot what a difference it makes on this bike. Only difference was on my 06 SM I installed a full yoshi system too... oddly enough with a stock pipe opened up I don't really think there was much difference... but it's been a few years so maybe I'm wrong.
I also bought a jet kit online from factory pro... and the jet sizes they sent for the Main were ranging from 120 to 127.5... the stock is 142. I thought maybe they were aftermarket jets and actually just different numbers. When comparing side by side all the MJ's were much smaller than the stock jet. Luckily I had the leftovers from my Dynojet kit from my 06. and used a 150 MJ from that kit, and it performs flawlessly everywhere. Good thing too, cause I was not planning to take that shit apart again for a while :)
I like power wheeling out of corners in second gear... now to get through xmas so I can spend money on a bigger tank, rad guards and a second set of wheels... I love this bike (for the second time around) I don't think I'll be selling this one.
jordan p is offline   Reply With Quote
Old 12-13-2012, 11:13 AM   #16749
150ron
150ron's Avatar
Oddometer: 1,315
I read somewhere that if removing the header bolts, when you go to insert them back, you should use some anti seize on those 2 bolts, is that really needed? and if so, can i just use a bit of grease on them and insert? do not have any anti seize.
Just some dude...
Old 12-13-2012, 12:11 PM   #16750
blaster11
Ramping up fast!
blaster11's Avatar
Oddometer: 6,878
The grease will burn off....but you can use Mallox (?), stomach stuff, as a suitable substitute.
blaster11 is offline   Reply With Quote
Old 12-13-2012, 06:18 PM   #16751
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,777
Originally Posted by DR-Zamboni View Post
this may be a stupid question, but EOD3MC.... hows that sport bike style swing arm stand rigged up to the DRZ? I've never seen that on an enduro before. Are there spindles threaded into the swing-arm? I have an old set of stands for my GSXR collecting dust since i sold the bike, it would be nice to rig them up to the DRZ for when i do work.
Does this help?
A friend gave me a pair of them awhile ago. The other is a post type rack for the front wheel (I guess)...
I've normally only use it with the smaller bikes..it's steady but not overly sturdy.
EOD3MC is offline   Reply With Quote
Old 12-13-2012, 06:22 PM   #16752
EOD3MC
EOD3MC's Avatar
Oddometer: 4,777
Glad to hear it....
as for next plans...single track riding this weekend, racing (more like riding) in a hare scramble on Jan 6th...
and on the 7th, I'll be ordering replacement parts for things I broke on the 6th
Old 12-13-2012, 09:47 PM   #16753
Westy123
Old Sod
Westy123's Avatar
Oddometer: 79
Originally Posted by 955616846 View Post
I have Nova gears, but the bike is still in pieces. Mine is possibly one of only two in existence as I don't see anyone else talking about it. It is always possible that there are more out there and the owners are simply not talking about them. Likewise the ACT gear set... there seems to be precious few in the wild.
BTW, it is interesting to me how something like a WR transmission for the DR-Z can generate a large amount of discussion with plenty of advice and opinion from experts, but when it comes to actually fronting with the money there are very few takers. I guess they are all still waiting for the 6 speed transmission.
I reckon you're right about where the value lies with these things as the DR-Z is not a lot of fun for extended riding at highway speeds. I am not particularly keen on pulling a sprocket that has been lathered with Loctite and then torquing that nut with a minimalist tool kit by the side of the road... The only time that is cheaper and easier is in the comfort of my own workshop.
Value is more what I get out of it not what it is worth to somebody else... If it means that I can ride the bike all over and enjoy it instead of disliking the ride for the bikes shortcomings then it is money well spent. Some people might go out and buy a different bike and then have to deal with a different set of shortcomings.
I installed the Nova WR gearbox for over a year and am very happy with it. I have done about 12,000km most in ADV rides but also some trail riding. I use the bike in NZ and Aussie and find the ratios good for all round long distance use. Nothing is perfect (except a 6 speed which Nova quoted me at more than the cost of a new DRZ400) but this is a great mod for a good light weight bike to be used for ADV riding. I have two DRZ400's and would like to do a similar upgrade to my other bike and would be interested to hear of folks who have the ACT solution which is considerably less expensive. I look at the ACT ratios and I am concerned about the gap between 4th and 5th. With a standard (which i have and will keep for ADV for reliability) engine running the bike on the open road in a strong head wind or up a steep high I doubt you could pull 5th gear. I run 15/44 with the Nova gears and I find that a good all round solution for my type of riding. Comments from ACT or Nova riders would be much appreciated.
You are right lots of folks talk about it very few do it!
Westy
Westy123 is offline   Reply With Quote
Old 12-13-2012, 11:09 PM   #16754
DR-Zamboni
DR-Zamboni's Avatar
Oddometer: 99
Does this help?
If i am seeing this correctly is looks like the stand itself is modified with a grip of some sort to grab the square portion of the swing arm. There are no modifications/brackets on the bike for it. Looks good. Maybe instead of selling mine I'll spend an hour in the machine shop making something similar.
Thanks for the pic.
DR-Zamboni is offline   Reply With Quote
Old 12-14-2012, 09:09 AM   #16755
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,262
Thanks for the pic.
That was the old way those track stands worked before spools became common.
The company that makes your stand may even still sell that style of attachment, or as you note, you could make some.
I have a spool style stand I use on my Versys.
For the DRZ I replaced the rear axle cotter pin with a quick pin.
Then I simply pull the pin and slide socket wrench extensions in the axle holes of the DRZ.
I have even thrown screw drivers in the holes when I have my extensions in use.
The DRZ swing arm is much narrower than my Versys so the extensions stick out pretty far where the contact the spool stand, but the bike is so light its not a big deal.
Works great for chain maintance.
I post up a pick later.
Ogre_fl is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
