Old 11-08-2012, 04:25 PM   #1
jesse v OP
jesse v's Avatar
Oddometer: 174
Brakes binding after I cleaned 'em
Just cleaned my front calipers as per this video:
http://www.youtube.com/watch?v=FNz00OTRLzM
I did this last week on my wife's 650 and everything went OK. Brakes feel better, engage more linearly, etc. Tried it with my 1k tonight, and now my brakes bind BAD. Prior to cleaning, there was a little bit of rubbing.
Any ideas? At one point in the cleaning, I accidentally pushed out one of the pistons so far it was crooked (almost fell out). Could this have caused something?
I'm planning on riding through the Loess Hills tomorrow so this is really bumming me. Hopefully I can fix it tonight. Your help is much appreciated
everybody lies
My band: June Embers
jesse v is offline   Reply With Quote
Old 11-08-2012, 04:36 PM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,858
I can't see the video from here, but if any residual brake cleaner stayed on the seals don't look too much farther. No more brake cleaners for me to do that, I use Methyl Hydrate, safer to some extent and won't swell rubber, something that some brake cleaners can do very well after a little while.
Have tools, will travel!
Old 11-08-2012, 05:52 PM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 3,994
Maybe the Road Warrior has a matching caliper repair video.
A proper inspection, possible disassembly by a mechanic should quickly reveal where the problem lies.
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 11-08-2012, 06:17 PM   #4
jesse v OP
jesse v's Avatar
Oddometer: 174
No brake cleaner product was used. Could have messed up a piston seal or 2 or 8; I'll check those out next.
everybody lies
Old 11-08-2012, 10:29 PM   #5
PeterW
Oddometer: 1,974
Best guess, the back of a pad has hooked one of the tangs on the anti-squeal springs at the back of the calliper, or one of them just plain shifted, and that's what's jamming a pad.
First two times I cleaned the brakes on my DL's 3 hours + and much swearing, third time, 5 minutes and I was left wondering what all the fuss was about - hint don't leave it until it REALLY needs doing.
Pete
PeterW is offline   Reply With Quote
Old 11-09-2012, 08:21 AM   #6
jesse v OP
jesse v's Avatar
Oddometer: 174
Thanks PeterW. I triple checked the springs and they're good. I brought it into a local mechanic this morning so we shall see.
everybody lies
Old 11-15-2012, 11:00 AM   #7
jesse v OP
jesse v's Avatar
Oddometer: 174
So, I took the bike to a local mechanic. He said he took the brakes apart completely, and nothing was damaged. So he cleaned them up and put them back together. He explained to me that the wheel was rolling more freely now, but because my pads are nearly worn to the wear bars (which I already knew and was planning to replace them next spring), the brakes are still binding a little because the farther the pistons comes out, the hard it is for them to retract perfectly straight, causing the little bit of binding. But it's nothing to worry about, he said, it just needs new pads.
That information cost me $91 (2 hours of labor plus brake fluid).
When I got home, I put the bike on its stands, and binding is exactly the same as it was. I'm hoping he's right and that new pads are all I need.
everybody lies
Old 11-15-2012, 01:30 PM   #8
syntec4
syntec4's Avatar
Oddometer: 853
If the mechanic went to the trouble of stripping the calliper to check it, surely dropping in some new pads during re-assembly would have been sensible? Or have I read it wrong (It wouldn't be the first or last time ).
My Smugmug
syntec4 is offline   Reply With Quote
Old 11-15-2012, 02:23 PM   #9
concours
WFO for 41 years
concours's Avatar
Oddometer: 3,994
+1 This is the TOO thrifty modus operendi
For $35 bucks, why wouldn't new pads have been installed? Were the caliper seals replaced? They can get old and harden, causing dragging.
2007 Tiger 1050
1973 Yamaha TX750
Old 11-15-2012, 02:36 PM   #10
jesse v OP
jesse v's Avatar
Oddometer: 174
I don't know why he didn't throw new pads in. He didn't call me until he was done re-assembling. He said no seals were bad or anything. I'll just put new pads in myself and see if that makes the binding go away. Ugh, this mechanic ticked me off.
everybody lies
Old 12-13-2012, 08:19 AM   #11
jesse v OP
jesse v's Avatar
Oddometer: 174
Update (if anybody cares):
Finally got around to putting new pads in yesterday, and no difference in the rubbing issue. I'll try rebuilding the master cylinder next and see what happens.
everybody lies
Old 12-13-2012, 11:45 AM   #12
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,858
Ah....maybe just the pressure relief hole inside the reservoir is plugged.That hole sure is tiny on some systems. You may be able to see it when you remove the cover. Then carefully pull/release the brake, you should see pressure coming out of the hole as you release the lever. Watch out, may splash up and shoot brake fluid where you don't want it, like your eyes or painted surfaces.
Old 12-13-2012, 11:51 AM   #13
wsmc831
wsmc831's Avatar
Oddometer: 204
Too much fluid in the reservoir an also limit pads retraction.
1997 TL1000S
2002 Ktm 300Mxc, 2008 Ktm 690 Duke, 2008 Ktm 530 Xcrw, 2010 Ktm 690 Enduro R
20+ years, 100k+ miles, 15 state's, 5 Countries, 3 years on asphault looking for the checkered flag, 7 dirt trying to stay on my minute.
wsmc831 is offline   Reply With Quote
Old 12-13-2012, 12:34 PM   #14
wmako
bored in NJ
Oddometer: 544
If you open the bleeder screw and some fluid squirts out and/or the pads are no longer dragging, the the relief hole is the problem.
wmako
RRMC
1979 CX500
1990 DR350
Ride Reports
Wmako's moped army rides from Jersey to Una-F'n-dilla (August 2010)
wmako is offline   Reply With Quote
Old 12-13-2012, 01:20 PM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,858
Yes but a plugged line will also do the same. As in falling apart internally and creating a one way valve.Been seeing a lot of that over this past year.
There are recommendations there and there as to replace them lines at about 6 yrs. New DOT regulations now reguire that all such pressure lines on vehicles be dated, little date band over the line. My new Spiegler's have such but not the OEMs on my bike, 2003...predates the new regulations.
Times are GMT -7.   It's 06:50 AM.
