Old 12-13-2012, 10:20 AM   #1456
Ed@Ford
Oddometer: 1,680
This whole fuel sloshing/pump sucking air scenario is VERY scary. Ages ago when developing EFI for cars and emissions, the fuel pump vendors were very adamant to NEVER let the pump run dry under any conditions, as a few seconds of dry operation would cause the pump to overheat, burn, and sieze/fail. The WR250R EFI Yamaha has fuel pump issues....and fails them after 20 to 30,000 miles...and this pump is made in china, and is used by a HUGE number of bikes, ATV, etc. I sure hope the issue these Hondas have is not the same as the Yamaha. The Yamaha, for what it's worth, didn't act like this. It would just quit in hot weather...and after a cool down would run for a while, but not for very long or very often...the $200 for a new pump fixed it!!
Ed@Ford is offline   Reply With Quote
Old 12-13-2012, 10:42 AM   #1457
Bob80
Oddometer: 80
scary indeed! especially considering where the tank/pump is located on a motorcycle in relation to the rider if it decided to erupt into flames...I like my nuts not roasted....lol
Bob80 is offline   Reply With Quote
Old 12-13-2012, 11:45 AM   #1458
hrcs90
hrcs90's Avatar
Oddometer: 29
Stalling
Originally Posted by Bob80 View Post
Anyone having any issues with their 250L's stalling for no apparent reason? I got about 800km on mine now, most of my drives this far have been mainly 30-40km's at a time,pretty much all pavement/dirt roads accessible by cars, and it will usually stall or quit at least once each outing. Mostly when stopped or slowing down to stop and once today while I was cruising along at about 50km/h, it just quit almost as if ya hit the kill switch. The bike will fire right back up no problem, just wondering if anyone else has a similar issue. I am about 99% positive it ain't my driving skills, as the wife's 250L doesn't have this issue (according to her, and I haven't noticed it the little i drove it either) May have to bring it up with the mechanic's at the dealer when it goes in for its 1st service, which I'm quite sure they will likely blame me also...lol
The older BMW F650's single sparks from 01-04 suffered the same kind of stalling. Which was a result of lean fueling around idle speed area and cured with a fuel controller of some type.
hrcs90 is offline   Reply With Quote
Old 12-13-2012, 11:58 AM   #1459
hrcs90
hrcs90's Avatar
Oddometer: 29
I would sure hope that the manufacturers learned from there past mistakes.
Old 12-13-2012, 12:10 PM   #1460
gaw777
Oddometer: 59
Originally Posted by goondock View Post
I hear ya about the Q4 but an option I thought of was to just get the powercore 4 setup like I did then if it is too loud or I want to tone it down a bit I can always buy the powercore 4 quiet insert for 35 bucks and from what I read it does decrease the power a bit because it effects the flow, but is "supposed to" sound like the Q4. plus it gives you the option to run it either way. Still researching about this to see if it is worth it. Just throwing that thought out there. but I know the powercore 4 is on back order for a while so if you want the kit sooner rather than later the Q4 might be the way to go.
http://www.motorcycle-superstore.com...-Arrestor.aspx
I did not know about the insert, I guess they make something for everything! I like that idea, not a big loud pipe fan. If you go that route keep us posted, I would like to hear what you think/find with your butt dyno. Thanks
gaw777 is offline   Reply With Quote
Old 12-13-2012, 12:53 PM   #1461
Ed@Ford
Oddometer: 1,680
Well, I don't think there is any worry of flames....but if the Honda fails like the Yamaha, you can be marooned in the middle of frikkin' nowhere!
Old 12-13-2012, 01:29 PM   #1462
Harcomo
Oddometer: 120
Originally Posted by gaw777 View Post
Yea, did the SpeedoDRD on my bike after I installed a 13T front sprocket. It was about 10.3% off with the 13T. Seems to be spot on with my gps unit now.
I also installed the 12 O'clock Labs Speedo DRD on mine using -10.3% as a correction with the 13T sprocket. I just haven't been on it enough since the weathers gotten cold to check it against the gps to see how close I got.
Harcomo is offline   Reply With Quote
Old 12-13-2012, 02:38 PM   #1463
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 369
:) deal :)beer :) evil. GAY!
EEKAMOUSE is online now   Reply With Quote
Old 12-13-2012, 02:57 PM   #1464
Harcomo
Oddometer: 120
BDSB's FMF exhausts
For you folks that have installed the FMF exhaust from Best Dual Sport Bikes, what does the ceramic coating that they say is only available through them look like..... as in does it look professionally applied? Does it serve any real purpose on this bike? I'm wondering if it's worth the extra $$ because FMF headers and mufflers are available elsewhere for less with free shipping. Are BDSB's FMF products any better than standard FMF stuff for the money?
Old 12-13-2012, 02:59 PM   #1465
Bob80
Oddometer: 80
good to know, Thanks....As I mentioned a few pages back, I do plan on getting the performance kit in the future for all the good reasons ppl here seem to be having with them. However, I'd like to get the stalling issue solved while the bike is still under the manufacturer's warranty in case the fuel controller doesn't solve the problem. I guess my main question is: Does adding the fuel controllers/ exhausts, e.t.c void the manufacturer's warranty? First new vehicle I owned that actually has warranty. This is a great thread on the 250L, great seeing ppl's ideas,mod's, reviews...etc,
Old 12-13-2012, 03:17 PM   #1466
SAPB
SAPB's Avatar
Oddometer: 1,657
New LRP
Just rode mine home, nearly 12 weeks after leaving the deposit to make sure I got the next one, 18 miles on it. First thing tomorrow attach the wiring to the battery for the heated gear, not so much fun this afternoon, 37 degrees when I went by the bank. LRP seems like it could do ANYTHING...air down the tires for the Dakar, then swap out the rear sprocket for a 21 tooth to bring it to Bonneville. Just air the tires back up, probably do in excess of 500 mph. Have to use a tire pressure gauge from 1987, if you know what I mean.
SAPB is online now   Reply With Quote
Old 12-13-2012, 03:44 PM   #1467
Tommyrg
Oddometer: 25
hI
Ive asked the same ? Bob80 from the owner of my Honda shop, my salesman and the service guys. The service guys where I work said the put power commanders on brand new atvs and street bikes then slap them on the dyno before it leaves the showroom! Still under warranty
Crf250l....ride it like you stole it 4018 miles and counting
Tommyrg is offline   Reply With Quote
Old 12-13-2012, 05:24 PM   #1468
callison
callison's Avatar
Oddometer: 120
I rode mine home from the dealership with an FMF pipe that was installed by said dealership. I'm working under the assumption that it's still covered. I hope anyway...
Cory
callison is offline   Reply With Quote
Old 12-13-2012, 05:42 PM   #1469
Guerillah
Guerillah's Avatar
Oddometer: 103
It looks cheap, I wouldn't let it influence my buying decision.
Guerillah is offline   Reply With Quote
Old 12-13-2012, 05:54 PM   #1470
Guerillah
Guerillah's Avatar
Oddometer: 103
Tried installing a 43T rear tonight... no luck. Those hex bolts on the sprocket are pieces of shit, the depth is so tiny its easy for the bit to mangle the threads. Got 4 out of 6 out, the other 2 heads are too tore up to get any good torque, great. Dealerships carry these bolts in stock by chance?
Guerillah screwed with this post 12-13-2012 at 06:01 PM
Times are GMT -7.   It's 05:58 AM.
