Old 12-13-2012, 07:58 PM   #50056
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Originally Posted by flyingwombat View Post
One thing to consider is that the battery box provides some support to the back of the subframe. Not saying it's essential, but it's something to consider.
That's true. I'm sure I could fabricate a bracket that would keep the support there if I removed the box. I have also thought about putting a lighter-weight box there for tools, extra parts, etc.
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 12-13-2012, 08:01 PM   #50057
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
I'm sure that's correct. However, you can bolt a 1/4-inch steel strap to replace the battery box frame. The straight steel strap will strengthen the subframe even better than the battery box frame, and the subframe will sustain much less punishment after the 10 plus pounds of the battery box and its contents have been removed.
Spud
Spud Rider screwed with this post 12-13-2012 at 10:03 PM
Old 12-13-2012, 10:02 PM   #50058
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
I know some of you are interested in the 2013 Honda CRF250L. Motorcycle.com just posted a comparison between the Honda CRF250L and the Kawaski KLX250S. Here's the video summary of the comparsion.
Here's a link to the associated article at Motorcycle.com.
http://www.motorcycle.com/shoot-outs...ampaign=weekly
My brief summary of their conclusions is the CRF250L wins. Motorcycle.com says the Honda suspension performs well enough compared to the Kawasaki. Therefore, the lower price of the Honda CRF250L, combined with its high tech, fuel injected engine, makes it the winner over the Kawasaki KLX250S.
Spud
Old 12-13-2012, 10:04 PM   #50059
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
that didn't do much to help me.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 12-13-2012, 10:58 PM   #50060
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
broken sub frame
Beechum1. Did you ever fix your sub frame? I have found a few stress cracks on my sub frame. I figure they have developed after a crash a few years ago.
Ben99r1 is offline   Reply With Quote
Old 12-13-2012, 11:11 PM   #50061
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
I did. I didn't take pics, but I used 5/8" steel dowel to insert into the frame where it was cracked; on both sides. I drilled ~1/4" holes perpendicular through the frame so that after I inserted the dowel, I could weld the holes of the frame, to the dowels inside the frame. I need to get 3 sets of the gussets cut so I can get them welded up before I do it again somewhere else. I'm going to gussets the F out of the frame all around too. Don't need this happening to me.
http://www.advrider.com/forums/showp...&postcount=501
Old 12-13-2012, 11:17 PM   #50062
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Thats not normally a really a big issue for a XR unless aliens morph it into a KLR...
xladv.com
MentalGuru screwed with this post 12-13-2012 at 11:38 PM
MentalGuru is offline   Reply With Quote
Old 12-13-2012, 11:23 PM   #50063
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
Broken shit means a long hike. I almost had to when my subframe broke. luckily the one of the seat bolts didn't rip through the seat pan, and one of the bolts ont he subframe was resting/digging into the exhaust so that it couldn't fall down lower, and the battery box bracket was holding it from falling completely off....
Old 12-13-2012, 11:37 PM   #50064
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Just pay close attention to the direction you run a weld and that your gussets don't centralize force to a newly created weak spot.
I'm sure it was something I would only want to deal with once too.
xladv.com
Old 12-13-2012, 11:40 PM   #50065
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
it was the 5th fucking woop. I was feeling good that day too. i was so pissed.
Old 12-14-2012, 04:45 AM   #50066
mcma111
mcma111's Avatar
Oddometer: 12,588
Beech,
Are you going to have some gussets made up? I'd like a set.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-14-2012, 05:53 AM   #50067
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,562
Quit riding it like it was a renta-car
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-14-2012, 06:06 AM   #50068
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,002
XRL Cooling!
Rad is money well spent but for cheap, simply instal a low front fender. This allows a much bigger air flow to the head, the hottest part.
RED CAT is online now   Reply With Quote
Old 12-14-2012, 06:24 AM   #50069
absoluteclint
absoluteclint's Avatar
Oddometer: 206
Originally Posted by Spud Rider View Post
If anyone is interested, here's a link to the installation thread for my Spud Oil Cooler, which costs less than $100 to fabricate.
http://www.advrider.com/forums/showthread.php?t=781962
Spud
Thanks for documenting and sharing your oil cooler build... Very economical and appears effective as well. I really, really like the clean (almost factory) look of Mark Sutton's cooler. What a work of art! If I can scrape together enough cash I think I'll go that route.
http://www.advrider.com/forums/showthread.php?t=652313
http://suttoncycleworks.com/oilCooler.html
I'm going to monitor the temp this Winter using the cheap Harbor Freight/oil reservoir method and as it get's warmer in the Spring really pay attention to engine temps. During this time I'm also going to (hopefully) take care of some other costly modifications...
My prioritized list goes something like this: new tires, skid plate, suspension adjustment (may not cost anything), oversized tank (probably Clarke 4.7), oil cooler/TTO gauge, and battery relocation (when the need presents itself).
I'm currently anticipating a few Christmas items coming my way : SD Manrack with hog legs, Manrack case saver, heated grips, and Tusk Handguards. Once I get these I'll also be able to install that $30 (steal of a deal... thanks 3Girlsdad) Easton bar that's been starring at me for a couple weeks now!
absoluteclint is offline   Reply With Quote
Old 12-14-2012, 07:13 AM   #50070
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
I see we are talking about oil tempratures, again. Here is some preliminary information I would like to share.My bike used alot of oil. I have a routine I go through and check it in the same manner often. The bike is well maintianed and both screens have been cleaned several times. The engine was steadly using more oil. So the research phase begain, that means a cold Lone Star beer and a read of the service manual. Under trouble shooting nothing seem to be amiss till the last item " poor oil pump performance". I have seen this before on my Harley which also has a dry sump system. So, I repalced the oil pump. Low and behold the initial checks showed no oil usage and antother benefit of increasing the oil flow in the engine was decreased oil temprature. Something like a 20 DF reduction.
Tearing down the old pump and performing dimensional inspection per the servicwe manual I found two of the four schavenger pump section lobes near high limit for wear and both were nicked and scratched badly as was the outer ring. The pressure side was not scratched or nicked but three of the four lobes were at mid tolerance indicating some significent wear. My bike has some 33K miles on it.I am the second owner and bought it with 2500 miles on the clock. I have changed oil regularly at around 2500 to 3000 miles.
Apearently the pump was in such bad shape it could not get enough oil out of the engine and this excess oil was getting blasted past the rings and consumed by the combustion process at a steady rate. Also the oil was not moving to the frame where it is cooled. On the pressure side the pump was moving less oil and this usually means higher engine temps. Both contribute to increased oil temp and comsumption.
So my point is this. Adding an oil cooler may be a band aid on a more serious problem. That of a worn oil pump.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 12-14-2012 at 07:20 AM
fritzcoinc is offline   Reply With Quote
Times are GMT -7.   It's 08:27 PM.
