Old 12-13-2012, 08:42 AM   #121
Snizz
two wheel enthusiast
Oddometer: 23
Originally Posted by McJamie View Post
That's kind of funny, because since I got rid of the DL (huge mistake), I've been riding my 250 Sherpa. It does 80% of what I want, but short on power. The 500 would fit nicely between what the Sherpa is, and what the DL was.
I couldnt agree more.. I bought a 2012 street glide and at the time had the DL and KLX250s..I figured the DL was obsolete, as I could ride the HD, and didnt think i would ever want to ride the strom instead.. Boy was I wrong.. It was just one of those bikes you could just hop on and ride, though a but porky for pushing around my shop with the bags on and such..I park them in the parts room and have to squeeze them through a regular door. I tried to make the KLX my everyday, bad weather, and local errand bike, which it does an okay job of, but going more than 30 miles on the freeway in the far right lane, getting wind blasted at W.F.O. becomes tiresome. The DL filled a huge void in my stable and I didnt realize how amazing and versatile that bike was till I had to live without it. I considered getting another one, but figure the honda would actually be an even better option for what I intend to use it for, which does not include off roading or riding two up. It just seems like a bike that you could ride the piss out of, and not care about a $500.00 tire change, unreasonable maintenance costs, or even washing it for that matter.. I love the harley to death, and plan to keep it forever, but would rather save its functional life for times where I can appreciate it more, as opposed to commuting it. This honda seems like a great fit.
Snizz is offline   Reply With Quote
Old 12-13-2012, 12:37 PM   #122
DiabloADV
Semi-Occasional
Oddometer: 2,321
This talk about off-road capability...my two cents is that it depends on *how fast you want to ride.*
The need for long travel is a product of (1) how bumpy is the road, and (2) how fast you're going. If you ride slow and easy, you don't need long travel for anything but genuinely rocky and technical terrain. A slightly higher standard works fine. It's all about the desired speed.
There's a loop in the Mendocino Forest that I did a few times on the TE630 that I used to own. Nice fire road; some whoops here and there. Good riders can ride that route flat-out on those bikes. I ride slow by comparison.
I took my CBR250R on the same loop about a month ago. No drama, and I rode about the same speed as on the TE's. The only place I had to be really careful was on a section of badly trenched and hardened mud. What that tells me is that I don't need a *true* dual sport to go where I want to go.
The 500x is, I think, I terrific option for a dual-sport bike, as long as you don't try to ride fast offroad or traverse actual "dirt bike" technical stuff.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 12-13-2012, 06:36 PM   #123
ridewv
Oddometer: 485
Excellent point. If the average to good skill rider wants to ride trails, over rocks, and through the woods, what's really useful is four things. Light weight, low gearing, knobby tires, and good ground clearance. Mega suspension travel isn't really much help unless you're riding *very* fast, way beyond what most of us ride on trails.
2015 Road King
2014 R1200GSA
2006 DR650
2000 CB750
1993 R100R
ridewv is offline   Reply With Quote
Old 12-14-2012, 06:36 AM   #124
fragile_this_side_up
fragile_this_side_up's Avatar
Oddometer: 1,480
i'm excited to see/sit on the CB500x... why? i need a decent commuter. i have an SV650n and would like something more comfortable, more "capable" than the SV. i don't want to shell out the cash for a Wee-strom and i feel like the CB should get much better mileage to boot. for what i'll be using it for mostly, commuting and long trips, it should work perfectly fine. i don't see myself hitting too many trails yet at all, but some gravel roads and dirt roads, i feel like this bike is going to be a perfect fit.. with some hard side bags...
fragile_this_side_up is online now   Reply With Quote
Old 12-14-2012, 07:06 AM   #125
Pecha72
Oddometer: 4,187
What is the curb weight of the CB500X?
Pecha72 is online now   Reply With Quote
Old 12-14-2012, 07:08 AM   #126
Paebr332
Oddometer: 1,144
Honda lists it at 430# (195kg) with a full tank of fuel.
Paebr332 is online now   Reply With Quote
Old 12-14-2012, 07:24 AM   #127
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,210
With a set of bags, what's a reasonable expectation for all-day cruising speed? 75 mph? 85 mph? or much less?
john
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 12-14-2012, 07:26 AM   #128
Pecha72
Oddometer: 4,187
Ok, then that should be about 20 kilos less than DL650, and about 25 less than NC700X. Probably has some effect in handling. But it's by no means a very light 500cc bike. Fuel economy should be stellar, as it's a new engine construction.
Old 12-14-2012, 08:44 AM   #129
DiabloADV
Semi-Occasional
Oddometer: 2,321
john
Since the CBR250R cruises nicely at 75, I'd imagine 85 would be no problem on the 500X.
The power required to increase speed rises with the cube of the speed increase*...ie...
85mph is 1.13 times 75mph. 1.13^3 = 1.44.
To go 13% faster, you need 44% more power. The 500X will have about 80% more power than the 250R.
*this is for wind resistance only. Rolling resistance of the tires increases linearly with speed, but that change is a relatively small effect at freeway speeds. It's almost all about wind...
Old 12-14-2012, 10:08 AM   #130
scarysharkface
30-125
Oddometer: 13,210
I have skimmed the thread, but didn't catch an HP reference. I wonder where this bike fits in the continuum between a KLR and a Wee-Strom, in terms of happiness on the highway?
John
yBr7OofIPuOP6
Old 12-14-2012, 10:24 AM   #131
dduelin
Oh boy that was close
Oddometer: 1,537
John
54 hp
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 12-14-2012, 10:41 AM   #132
Pecha72
Oddometer: 4,187
according to our importer's webpage: 35,0 kW (47,6 hp) / 8500 rpm
Old 12-14-2012, 10:58 AM   #133
scarysharkface
30-125
Oddometer: 13,210
Originally Posted by dduelin View Post
54 hp
So just a bit more than the KLR.. ?
Thanks for the info..
I'm interested to see one of these in person..
john
yBr7OofIPuOP6
Old 12-14-2012, 12:05 PM   #134
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,280
Honda are claiming 76mpg (imperial), just a shade under the 700X. 260-280 miles to a tank.
8000-mile service intervals.
Tyres are - and this is a guess - more likely to be something like Bridgestone BT45, rather than 23. Less cost, in other words.
In the UK the bike is allegedly sub-5000. For comparison, an optioned DL650 or Versys is closer to 7000.
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 12-14-2012, 05:28 PM   #135
Gryphon12
Gryphon12's Avatar
Oddometer: 1,336
One more time: US and EU hp will be different. The bike is designed for the new EU regs, or 47 hp. In the US, the number in the press is 54 hp. Don't know how you missed this discussion - it has been quite long - or maybe it was in the Road Warriors thread on the CB500's.
My 1976 CB500T cruised at 85 mph with only 42 hp and 465 lbs. wet. There was a lot of buffeting due to a lack of a fairing, but no inability to cruise due to a lack of power. And since the new Hondas are all emulating the BMW F800s with respect to lower power and higher fuel economy from a given displacement, don't expect an acceleration rocketship and you won't be disappointed.
These discussions of "will it cruise at X mph?" always puzzle me. Anything more than a 250cc bike will do just fine, well over any US speed limit. Will it be a ZX-14? Of course not. But it will be fine. Of more importance are how the ergonomics fit you, do you like the saddle and the bars, and what luggage will fit.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Times are GMT -7.   It's 07:31 AM.
